What is the Entropy Change When Water Freezes to Ice?
The entropy change when 10 kg of water at 293 K freezes to ice at 263 K is calculated to be -13.8×103 J/°C. The calculation involves three components: the latent heat of fusion, the cooling of water from 293 K to 273 K, and the cooling of ice from 273 K to 263 K. The specific heat capacities used are 4180 J/kg-K for water and 2090 J/kg-K for ice. The final entropy change is derived from the formula ΔS = ΔS1 + ΔS2 + ΔS3, confirming the negative value due to heat loss during the phase transition.
  • Understanding of thermodynamics concepts, specifically entropy.
  • Familiarity with specific heat capacities, particularly for water and ice.
  • Knowledge of latent heat of fusion for water.
  • Ability to perform logarithmic calculations and integrals related to temperature changes.
  • Study the principles of thermodynamics, focusing on entropy and phase changes.
  • Learn about the latent heat of fusion and its implications in thermodynamic calculations.
  • Explore the use of specific heat capacities in various materials and their impact on thermal processes.
  • Practice solving entropy change problems using different phase transitions and temperature ranges.
Students in thermodynamics, physics enthusiasts, and professionals in engineering or environmental science who require a deeper understanding of entropy changes during phase transitions.
Another
10 kg water temperature 293 K change to ice ( 263 K) at constant pressure. Calculate the entropy change of system
Answer is ##-13.8×10^3 J/°C##
##c_p = 4180 J/kg-K## (water)
##c_p = 2090 J/kg-K## (ice)
##l_{water→ice} = 3.34×10^5 J/Kg##
##ΔS = \int \frac{dQ}{T} ##
##ΔS_1 = \frac{ml}{T}## ;Latent heat ##Q=ml##
##ΔS_1 = \frac{10×3.34×10^5}{273}=12234.4 J/K = 12234.4 J/°C##
##J/°C## equal to ##J/K##
http://www.endmemo.com/convert/specific heat capacity.php
I thank ##ΔS_1 ## should be negative. because water change to ice (lost heat)
So ## ΔS_1 = -12234.4 J/°c##
##ΔS_2= \int \frac{dQ}{T} = mc_p\int \frac{dT}{T}## integral 293 K to 273 K
##ΔS_2= mc_p \ln \frac{273}{293} = 10×4180×\ln \frac{273}{293} = -2955 J/°C##
##ΔS_3= mc_p\int \frac{dT}{T}## integral 273 K to 263 K
##ΔS_3= mc_p \ln \frac{263}{273} = 10×2090×\ln \frac{263}{273} = - 780 J/°C##
So ##ΔS_{sys} = ΔS_1+ΔS_2+ΔS_3 = -12234.4 -2955 - 780 = -15968.4J/°C##
My answer incorrect. Please help
I think you are correct. The answer of -13.8 x 105 is equal to - (10 x 4180 x 20) - (10 x 2090 x 10) - 3.34 x 105. So it looks as if they have calculated ΔH, but forgotten to multiply the latent heat by 10 kg.
I’m sorry. It was my fault. The answer of a question is ##-13.8×10^3 J/°C## I typed wrong. am so sorry
I still agree with your answer. Textbooks can be wrong.
thank you very much
  • · Replies 17 ·
