Thermodynamics - obtaining quenching entropy
The forum discussion focuses on calculating the total entropy change during the quenching of a metal, specifically a 20 kg metal at 800°C and 1000 kg of water at 30°C. The specific heat capacities are given as 0.4 kJ/kg K for the metal and 4.18 kJ/kg K for the water. The derived temperature after quenching is 304.6 K. The total entropy change is calculated using the equation s2 - s1 = mmCpm ln(T2/T1m) + mwCpw ln(T2/T1w), confirming that the entropy change of both the metal and water must be summed.
  • Understanding of thermodynamic principles, specifically entropy.
  • Familiarity with specific heat capacity (Cp) calculations.
  • Knowledge of temperature conversion between Celsius and Kelvin.
  • Basic skills in logarithmic functions and their applications in thermodynamics.
  • Study the derivation and application of the entropy change formula in thermodynamics.
  • Learn about the implications of entropy changes in closed and open systems.
  • Explore the relationship between temperature, pressure, and specific volume in thermodynamic processes.
  • Investigate the concept of the second law of thermodynamics and its relation to entropy.
This discussion is beneficial for students and professionals in thermodynamics, mechanical engineers, and anyone involved in heat transfer and material science, particularly those working with quenching processes.
mouser
I'm having a problem determining the total entropy change in a metal quenching problem. Here is the information I am given (subscript 'm' is for metal, 'w' is water):
mm = 20 kg
mw = 1000 kg
T1m = 800 C
T1w = 30 C
Cpm = .4 kJ/kg K
Cpw = 4.18 kJ/kg K
With this information, I found T2 to be 304.6 K.
How can I obtain the entropy change with this information? I have no pressure values, and all my entropy equations involve pressure, or specific volume which depends on pressure. Thanks for any help.
Do you know of an equation that connects dS to Cp that you might be able to integrate?
I did find a relationship, but it is returning negative values for me, so something is amiss...
s2 - s1 = Cp ln(T2/T1)
I'm trying to find the total entropy change. Would that mean that I sum the entropy change in the quenched metal and the water?
Yes.
CS
Yes. It's not unusual for entropy to decrease; it happens whenever a hot object cools down.
You'll need to consider the mass of each as well in your equation.
CS
Caveat:
But the total change in the universe will always increase.
CS
Wow, thanks for all the responses everyone :). OK so here is what I came up with, and it seems to be giving me the right answer, but just for future reference:
s2-s1 = mmCpm ln(T2/Tm1) + mwCpw ln(T2/Tw1)
  • · Replies 40 ·
