Calculating Minimum Thickness of a Thin Film Using Interference Patterns
The minimum thickness of a thin film of benzene (n = 1.50) floating on water (n = 1.33) can be calculated using the wavelength of light reflected most strongly, which is 565 nm. The correct approach involves determining the effective wavelength in the film, calculated as λfilm = λ / n(benzene), resulting in λfilm = 3.77 x 10^-7 m. The minimum thickness is then derived using the equation 2t = mλfilm, leading to a minimum thickness of 9.42 x 10^-8 m for the first order of interference (m=1).
  • Understanding of thin film interference principles
  • Familiarity with refractive indices and their implications
  • Knowledge of monochromatic light and wavelength calculations
  • Proficiency in using equations for optical path differences
  • Study the derivation of thin film interference equations
  • Learn about the impact of refractive indices on light behavior in different media
  • Explore practical applications of thin film interference in optical devices
  • Investigate the effects of varying wavelengths on interference patterns
Students and researchers in physics, particularly those focusing on optics and materials science, as well as anyone involved in experiments related to thin film measurements and interference phenomena.
LippyKa16
A researcher measures the thickness of a layer of benzene (n = 1.50) floating on water by shining monochromatic light onto the film and varying the wavelength of the light. She finds that light of wavelength 565nm is reflected most strongly from the film. What does she calculate for the minimum thickness of the film?
Values:
λ = 565*10^-9m
n(benzene) = 1.50
n(water) = 1.33
I have tried both of these equations:
2t = mλ
2t = ½mλ
Subbing in the values needed, I get
t = (1 * 565*10^-9) / 2
= 2.825*10^-7m
or
t = (½ * 1 * 565*10^-9) / 2
= 1.4125*10^-7m
Values:
λ = 565*10^-9m
n(benzene) = 1.50
n(water) = 1.33
2t = mλ
2t = ½mλ
These are not the relevant equations. Do you think the refractive indices do not count?
I wasn't too sure.
Would that mean I would have to calculate the relevant wavelength through the film?
Would that mean:
λfilm = λ / n(benzene) (λ = 565 and n(benzene) = 1.5)
λfilm = 3.77*10^-7
*EDIT* I realize the mistake I made, and I did need to calculate λfilm.
The answer I got was 9.42*10^-8 and that was correct.
How did you get the correct answer? Please do show the working out. I am lost in this question. Thank you heaps
Nevermind, i have figured out the answer.
Can you please demonstrae your working for Q9,10,11 if you remember or its available thanx
