Thin rotating disc under constant acceleration.
yuiop
In a different thread the Herglotz Noether theorem was brought up and it was mentioned that this theory implies it is impossible for a cylinder rotating about its vertical axis to remain Born rigid in a gravitational field even at constant altitude. This is an extension of the claim that a Born rigid rotating disc cannot have linear acceleration and remain Born rigid. Now I accept and understand that:
1) A non rotating disc cannot be spun up and remain born rigid during the angular acceleration phase.
2) A vertical rotating cylinder that descends in a gravitational field cannot remain Born rigid.
What I do not understand is why a vertical cylinder rotating around its vertical axis cannot remain Born rigid if its rotation is constant and it remains at constant altitude in a gravitational field.
To try and break the problem down to its simplest elements, I would like to initially discuss/analyse the dynamics of an infinitesimally thin disc in the y/z plane that is rotating about the x axis, that experiences constant proper acceleration in the x direction.
First, in the context of artificial acceleration in flat (Minkowski) spacetime, the disc would appear to have increasing velocity in the x direction in a given inertial reference frame. To make discussion easier I will identify my statements/assumptions/considerations with letters.
a) I think we can also assume that as the velocity increases in the x direction, the rotation of the disc will slow down in proportion to the time dilation factor.
b) To an accelerating observer that remains at the centre of the disc, the rotation rate will appear to remain constant.
c) In the inertial reference frame, the increasing linear velocity and corresponding angular velocity slow down of the disc, implies that the radius and perimeter of the disc has to increase if the perimeter length of the disc is to remain constant as measured by observers on the rotating disc.
d) If (d) is true, then by the equivalence principle. this implies that a thin disc with constant rotation at constant altitude will expand or rip itself apart (if Born rigidity is not maintained). As far as I aware this effect as not been observed in everyday life or in a lab.
e) It may be that the expansion in consideration (c) does not occur. Study of successive Lorentz transformations of a rod shows that if the first transformation (to S') is parallel to the rod (say in the x direction) and the second (to S'') is orthogonal to the rod (say in the y direction), then Thomas precession does not occur and the length of the rod as measured in S'' is independent of the velocity component in the y direction and equal to the length of the rod as measured in the S' reference frame. This implies that if the disc is already rotating in the y,z plane about the x axis, and the constant linear acceleration is along the x-axis (or upwards in a gravitational field) then length contraction effects above and beyond those already present due the rotation of the disc, should not occur.
OK, that's enough musings for now. Can anyone correct/expand on my thoughts here and explain what exactly happens in the special case of a infinitesimally thin disc that is rotating with constant angular velocity and linearly accelerated with constant proper acceleration along its rotation axis?
Yes.
If by "descending" you mean "freely falling" (as in, the center of mass is freely falling in the gravitational field), this is not correct; there's nothing preventing a freely falling rotating cylinder from remaining Born rigid (at least as long as its size is small enough that tidal gravity doesn't affect its motion measurably). All of the results quoted in the other thread about Born rigid motion being impossible were for objects that were both rotating *and* linearly accelerated; none of them were for objects that were rotating but whose centers of mass were freely falling.
If by "descending" you mean "slowly descending but accelerated", then as far as the theorems quoted in the previous thread are concerned, there's no real difference between this case and the case of constant altitude. According to the theorems, as long as both rotation and linear acceleration are present, Born rigid motion is impossible. See further comments below.
The theorems referred to in the other thread say that for the motion of any object to be Born rigid, the worldlines of each of its points must all be integral curves of a single Killing vector field. So the basic answer to your question is that there is no KVF that corresponds to the state of motion you are describing. (Again, this is true whether or not the rotating cylinder remains at constant altitude; the key is the presence of both rotation and linear acceleration of the center of mass.) Unfortunately, I haven't come up with a good way of describing, in intuitive physical terms, why this is the case. (Mathematically, it's easy to see for the Minkowski spacetime case, because all of the KVFs for Minkowski spacetime are easily enumerated, and it's evident that the worldlines of an object that is both rotating and linearly accelerated don't match up with any of them.)
I need to think over the above some more before responding to the rest of your statements about the thin disk in Minkowski spacetime.
Just to clarify, do you accept that rotating disk cannot be uniformly accelerated in an inertial frame, with gravity ignorable, while maintaining Born rigidity? This is the essence of Herglotz-Noether. So if you don't accept this, then the place to start is a derivation of this theorem. A modern (but not elementary) derivation is given in:
The Rich Structure of Minkowski Space
If, instead, you accept this, then it really seems obvious why a spinning disk cannot remain at rest in a gravitational field: it is undergoing proper acceleration in the locally Minkowski space. It is the free falling, spinning disk that could, at first glance, maintain born rigidity. In fact, the only factor I see preventing a free falling disk from remaining born rigidity is tidal forces.
[edit: I see Peter Donis beat me to all these points.]
Yes, I meant "slowly descending but accelerated" and should of excluded the free falling case. Thanks for the correction ;)
Thanks. I look forward to your analysis. I am trying to find out if the none-infinitesimal thickness of a cylinder is an essential part of the failure of Born rigid rotation combined with linear acceleration. Is the infinitesimally thin disc a special exception?
Not according to the theorems I mentioned--at least, not if I'm understanding them correctly. Even the congruence of worldlines describing an infinitesimally thin disc is not a Killing congruence (i.e., the worldlines are not integral curves of a KVF).
Each point on the disk is described by a time-like curve so the disk itself is described a time-like congruence i.e. a time-like vector field ##V^{\mu}## whose integral curves represent the worldlines of the points on the disk. If we have a disk uniformly accelerating along the ##x## axis while rotating in the ##y##-##z## plane, then one can show that the expansion tensor ##\theta_{\mu\nu} = h^{\alpha}{}{}_{\mu}h^{\beta}{}{}_{\nu}\nabla_{(\alpha}V_{\beta)}## does not vanish identically for this congruence (here ##h_{\mu\nu}## is the spatial metric). What this means is that if we take a given point ##O## on the disk and connect it to an infinitesimally nearby point ##O'## using a connecting vector ##X^{\mu}## with ##X^{\mu}V_{\mu} = 0## initially and ##\mathcal{L}_{V}X^{\mu} = 0## then the squared length ##X^2 = (-X^{\mu} X_{\mu})## of ##X^{\mu}##, which initially is the squared spatial distance of ##O'## from ##O##, changes at the next instant i.e. ##\frac{d(X^2)}{d\tau} = V^{\mu} \nabla_{\mu} (X^2) = -2\theta_{\mu\nu}X^{\mu}X^{\nu} \neq 0##. Basically there are shear stresses that pull apart (or at least try to) neighboring points on the disk, on account of ##\theta_{\mu\nu} \neq 0##. Born rigid motion is defined as ##\mathcal{L}_{V}h_{\mu\nu} = 0## and not surprisingly it can be shown easily that Born rigid motion occurs if and only if ##\theta_{\mu\nu} = 0##.
I still can't fully get the intuition for why that happens though. Gron and others have detailed papers on the analysis of rotating disks that have a uniform tangential acceleration, wherein the expansion tensor is yet again non-vanishing, but I can't find anything on the analysis of rotating disks that have a uniform linear acceleration.
No, it implies that a thin disk with constant rotation and constant altitude will experience shear stresses that will not be present in an accelerated disk that is not rotating, or a rotating disk that is not accelerated. The shear stresses would not necessarily have to exceed the breaking stress of the material.
These stresses could in principle be measured in a lab, but I think (though I haven't run any actual numbers) that with a 1 g acceleration, in order to make the additional shear stress measurable you would need to have an angular velocity well beyond what we could achieve with known materials (i.e., the disk would tear itself apart purely due to the stresses induced by trying to spin it up, even if it was freely falling, so we would never get to the point where we had it in a state where we could test for the additional shear stress due to the combination of rotation and acceleration).
yuiop said:
c)...implies that the radius and perimeter of the disc has to increase if the perimeter length of the disc is to remain constant as measured by observers on the rotating disc.
I don't quite follow this part. Even in a general setting, why would a dichotomy between two different observers solely lead to a coordinate independent fact about a certain tensor equation e.g. ##\theta_{\mu\nu} = h^{\alpha}{}{}_{\mu}h^{\beta}{}{}_{\nu}\nabla_{(\alpha}V_{\beta)}##? In this case, the expansion tensor ##\theta_{\mu\nu}## of the time-like congruence defined by the linearly accelerating, rotating disk is, in particular, not equal to 0 in the comoving coordinates attached to the center of the disk. So why physically does an observer comoving with the center of the disk measure shear stresses between neighboring points on the disk and, if the conditions are extreme enough, see the disk start to crack?
PeterDonis said:
... the key is the presence of both rotation and linear acceleration of the center of mass.) Unfortunately, I haven't come up with a good way of describing, in intuitive physical terms, why this is the case.
This is basically what I am looking for here. A good intuitive physical picture of what actually happens to the disc. Does it expand and experience stresses similar to those caused by reaction to centripetal forces.
This is good news. Can we assume that for constant angular velocity of disc and constant proper linear acceleration, that the H/N stresses are constant and do not increase without bound over time? If so, then it might be possible to conceive of a tall rotating cylinder in a gravitational field, as discussed in the other thread, that remains intact as long as the radius of the cylinder is small enough, the rotation rate is slow enough and the gravitational and tidal forces are not too excessive.
I agree this is a major hurdle for carrying out an actual experiment in a lab. I was hoping we discuss what would happen in principle (hypothetically) if we ignore centripetal stresses as is usually done when discussing the Ehrenfest paradox. i.e. assume a very strong (but not infinitely rigid) material. It might be worth considering a rotating molecule/nucleus/neutron star, although measurements would be difficult in practice.
I have much to learn before I can understand everything you have posted here, but I can see that we can get a yes/no answer to the Born rigidity question. However, we do not seem to be able to quantify the extent of these forces as we can with centripetal force for example.
WannabeNewton said:
... I still can't fully get the intuition for why that happens though.
THis is essentially what I was hoping to find out in this thread.
WannabeNewton said:
d) If (c) is true, then by the equivalence principle. this implies that a thin disc with constant rotation at constant altitude will expand or rip itself apart (if Born rigidity is not maintained). As far as I aware this effect has not been observed in everyday life or in a lab.
In statement (c) I was musing that the disc should expand if its rotation rate was slowing down according to the inertial observer, but on further analysis that is probably incorrect. To the inertial observer, the angular velocity is decreasing, but the linear velocity is increasing and both velocities affect the time dilation of an accelerating clock on the disc rim and in effect cancel each other so there is no corresponding change in length contraction. An intuitive way of looking at this, is to consider the case of a disc rotating at w rpm, whose centre of mass is at rest in ref frame S. If we boost to the POV of frame S' that is moving at 0.6c relative to S, the rotation rate is 0.8w rpm. If we now boost to the point of view of frame S'' traveling at 0.8c relative to frame S, the disc slows down to 0.6w rpm, but in all these reference frames the radius and circumference of the disc remains unchanged. Of course there is no actual proper linear acceleration of the disc in this example and that may be the crucial difference. Does a rotating disc effectively act as an accelerometer?
To further illustrate, consider 2 identical discs that are linearly at rest in S and wrt to each other and rotating at the same angular velocity w about the x axis. Now we accelerate one disc to 0.8c relative to the other and then let it coast inertially at 0.8c. By retrospectively looking closely at these 2 discs after everything has settled down and stabilised, can we tell which disc actually accelerated by looking for physical differences in the discs?
One aspect that has not really been touched on in this thread is Thomas precession. If we accelerate the disc linearly in the x direction and THEN rotate it around the x axis, then when looking at a short section on the edge of the disc, Thomas precession tends to twist that section out of the rotation plane. This does not rotate the axis of the disc as a whole because for each section on the edge of the disc there is a corresponding section on the opposite side of the disc that is trying to twist in the opposite direction. These opposing twists may cause stresses in the disc. However, if we rotate the disc first and THEN accelerate linearly along the rotation axis, there is no Thomas precession effect. In a gravitational field this could be achieved approximately, by initially rotating the disc very far away from the gravitational source (so that the linear acceleration is negligible) and then moving the disc lower into the gravitational well.
Just curious if anyone has seen this paper? http://arxiv.org/abs/0810.0072 It claims to simplify the analysis of rotating objects in GR by implementing the concept of Rigid Quasilocal Frames. Essentially they consider the surface of rotating solid rather than the interior and specify an alternative form of rigid motion that makes analysis easier, rather than give up when the Herglotz-Noether theorem suggests that Born Rigid motion is impossible.
I hadn't seen it but it looks interesting, thanks for the link!
One thing that occurs to me just on skimming the abstract is that, if we only consider the boundary of an object, not its interior, we have no way of taking into account internal stresses within the object, and since it's those internal stresses that signal the presence of "non-rigid" motion (e.g., shear stress), this method basically "solves" the problem by ignoring it. However, there might be more details in the body of the paper that address this, so I'll postpone further comment until I've read it in full.
That's what I think, based on the math (the shear tensor being nonzero), but I'm not entirely sure whether the stresses vary with time. See below.
That was my initial intuition, but on reflection I'm not sure. It's clear from the math that there is an effect due to the combination of rotation and linear acceleration, that is not present when either linear acceleration or rotation are present in isolation. The problem is distinguishing between stresses that are due to the individual pieces of the disc *responding* to this effect, and stresses that are due to the individual pieces of the disc *resisting* this effect.
Put another way, the problem is figuring out to what extent the congruence of timelike worldlines that I described, and that WannabeNewton wrote down equations for, describes the *actual* motion of the pieces of the disc, versus only the "idealized" motion of the pieces of the disc, which is then altered by internal forces within the disc. If the congruence that I described represents the actual motion of the pieces of the disc, then I think the internal stresses are *not* constant for constant angular velocity; they will increase over time until the disc is torn apart. (Basically, the situation is like that in the Bell Spaceship Paradox; the only difference is that here it is shear rather than expansion that causes the increasing internal stress.)
But an actual disc might have internal forces that resist this, and cause the pieces of the disc to follow different worldlines than those expressed by the congruence I described; however, I'm not clear about just how much leeway there is for the pieces of the disc to do that while still following timelike worldlines. It seems quite possible to me that there is *no* set of timelike worldlines that the pieces of the disc could follow which would lead to a constant shear stress, rather than one which grows with time. But I haven't yet come up with a way to resolve the question one way or the other.
Interesting question, I'll have to think about this one.
This isn't the way I understand Thomas precession. [Edit: Actually I missed something here--see follow-up post.] First, Thomas precession doesn't cause stress within a rotating disc; it's just a way of expressing what "non-rotating" actually means, in terms of Fermi-Walker transport. Second, Thomas precession acts wholly within the rotation plane of the disc.
Here's a way to visualize what Thomas precession means. Suppose I put a gyroscope on the edge of a rotating disc, supported by a frictionless bearing so that the gyro's orientation is not affected by the motion of the disc itself (the bearing applies a force at the gyro's center of mass to keep it riding around with the disc). At some time t = 0, the gyro is pointing directly at some distant object (such as a star), which is at rest relative to infinity.
If Newtonian physics were exactly correct, the gyro would remain pointing at the distant star forever, as it rode around on the edge of the disc. However, when we take relativity into account, the gyro will slowly precess in the retrograde direction: that is, the direction it points will slowly rotate, relative to the distant star, in the same plane as the disc itself, but in the opposite direction.
Now, suppose we paint a radial stripe on the disc; this stripe defines a spatial vector that always points "radially outward" relative to the disc. Suppose the outer end of this stripe passes directly underneath the gyro, and everything is transparent so we can see the relative orientation of the gyro and the stripe from above. If we look down from above, as the disc rotates and the gyro rides around on its edge, we will see the gyro and the stripe rotating relative to each other. However, there will be no stress in the tangential direction due to this relative rotation; the only stress, on either the disc itself or the gyro, is radially inward (because that's the direction of the proper acceleration).
Well to start with, take a look here: http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0753306
and here: http://www.nature.com/nature-physci/journal/v235/n61/pdf/physci235175a0.pdf
Also, Thomas precession is present even when the disk is not linearly accelerating but just rotating, relative to a global inertial frame (recall that the Thomas precession is due to the non-commutativity of successive non-parallel Lorentz boosts). Of course that isn't to say that the effect is exactly the same in magnitude as when the disk is indeed linearly accelerating.
EDIT: Thanks for the article, yuiop! I just saw that :)
Thinking this over, I think it can't be, and the difference might be what yuiop was referring to when talking about "twisting" the disk out of its rotation plane.
If the disk's CoM is moving inertially, then a point on the edge of the disk is subjected to Lorentz boosts all in the same plane, but with changing direction within that plane. So the resultant of the successive boosts will be a rotation about an axis perpendicular to the plane.
However, if the disk's CoM is being accelerated in a direction perpendicular to the plane of rotation, then a point on the edge of the disk is subjected to Lorentz boosts with two components, the one due to rotation, within the plane, and the one due to linear acceleration, perpendicular to the plane. Also, the 3-velocity of a point on the disk's edge is has a component within the plane of rotation and a component perpendicular to that plane (at least, it does once the disk has accelerated for more than an instant relative to a given inertial frame). So the cross product between the velocity and the acceleration vectors, and the magnitude of the velocity vector, will both change, and since those are what determine the Thomas precession, the latter will also change. (This means it will also change with time, as the disk accelerates.)
I don't think this can be right; if the disk is rotating while it is being linearly accelerated, then the argument in my previous post applies and Thomas precession must be (a) present, (b) not the same as for the case of a rotating disk whose CoM moves inertially, and (c) changing with respect to time.
I'm not sure, however, how any of this relates to stresses in the disk; as I said a couple of posts ago, Thomas precession by itself doesn't cause any stresses, it's just a definition of what a "non-rotating frame" means (more precisely, it defines how a local definition of a "non-rotating frame", using gyroscopes, *differs* from the Newtonian expectation that such a frame should always point to exactly the same location at infinity).
Yeah that's what I was thinking as well. The precession is given by ##\dot{S} = \frac{\gamma - 1}{\beta^{2}}S\times (\boldsymbol{\beta}\times \boldsymbol{\dot{\beta}})##. In 3-vector notation, the 3-velocity ##\boldsymbol{\beta}## would be like ##(0,\beta_{\phi},\beta_{z})## and ##\boldsymbol{\dot{\beta}}## would be like ##(\dot{\beta}_{r},0,\dot{\beta}_{z})## so the cross product would be like ##(\beta_{\phi}\dot{\beta}_{z}, -\beta_{z}\dot{\beta}_{r},-\beta_{\phi}\dot{\beta}_{r})##. So at ##t = 0## if we attach a gyroscope to a differential element of the disk such that it (and hence the associated spin vector ##S##) points radially outward, then initially (assuming that at ##t = 0## the disk is already in linear motion relative to the global inertial frame that this is all written in) the precession ##\dot{S}## is proportional to ##(0,-S_r \beta_{\phi}\dot{\beta}_{r}, -S_r \beta_{z}\dot{\beta}_{r})## so there would be a component of the precession pointing out of the plane of rotation.
WannabeNewton said:
... Also, Thomas precession is present even when the disk is not linearly accelerating but just rotating, relative to a global inertial frame (recall that the Thomas precession is due to the non-commutativity of successive non-parallel Lorentz boosts). Of course that isn't to say that the effect is exactly the same in magnitude as when the disk is indeed linearly accelerating...
I set up a little spreadsheet to calculate successive Lorentz boosts to study the non commutative nature. It was here that I discovered that if we boost a rod lying on the x-axis in the x direction and then boost it in the y direction, that Thomas precession does not occur (but it does if we do the boosts in the opposite order). I am not sure if that is widely known. I am also not always sure how we know which boost occurs first in non trivial situations. As for the difference between boosting to different reference frames and actually accelerating the disc linearly, that is the big question! This is what Peter is addressing below.
PeterDonis said:
... However, if the disk's CoM is being accelerated in a direction perpendicular to the plane of rotation, then a point on the edge of the disk is subjected to Lorentz boosts with two components, the one due to rotation, within the plane, and the one due to linear acceleration, perpendicular to the plane. Also, the 3-velocity of a point on the disk's edge is has a component within the plane of rotation and a component perpendicular to that plane (at least, it does once the disk has accelerated for more than an instant relative to a given inertial frame). So the cross product between the velocity and the acceleration vectors, and the magnitude of the velocity vector, will both change, and since those are what determine the Thomas precession, the latter will also change. (This means it will also change with time, as the disk accelerates.)
I tentatively agree, although I not sure that it changes over time.
That leaves me wondering what does cause the stresses in the disc. I guess one important difference between successive Lorentz boosts and continual proper linear acceleration is how spatial measurements are made by disc observers. If radar measurements are made between two neighbouring points on the disc, the linear and angular velocity of the disc at the time the radar signal is emitted is different from the velocities when the radar signal return. This may be the crucial difference from constant inertial velocity case.
P.S. I would love an opinion from either of you on my gravitational differential gear thingy in the tall cylinder thread ;)
See WN's latest post, he writes out the math, which makes it easier to see: the components he writes out are obviously changing with time (remember he's writing them in a single inertial frame, in which the velocity and acceleration of any point on the disk both change with time).
Which stresses? As I said before, Thomas precession by itself doesn't cause any stresses; it's just a way of making precise what a "non-rotating" frame is, and how the definition differs from the Newtonian expectation when relativistic effects are included.
Yes, I think this is an important difference.
I haven't posted on that because I don't think it really raises any new issues that weren't raised by the original cylinder scenario, and I'm not sure I'm ready to tackle the curved spacetime case again until we've beaten the flat spacetime case, if not to death, at least to within an inch of its life. :wink:
Let there be a small thin plate, rotating around a long pole, the radius of the orbit is large.
Picture:
O .
(On the left plate from above, on the right pole from above.)
We accelerate the plate linearly along the pole, so that it stays as Born rigid as possible, by giving every part of the plate a push, simultaneously in the plate frame.
This will cause the plate to tilt, according to the pole. The trailing edge tilts in the direction of the push. (because that side is pushed first, in the pole frame)
Now we weld many plates together, so that they form a ring. We make the ring to rotate. Then we apply same kind of force to each plate as I described above. Those forces would make the plates to tilt, to various directions, but the internal stresses keep the plates alingned.
Edit: Oy yes, that kind of tilting may happen when we are increasing the linear acceleration, but the question was about constant acceleration.:blushing:
I'd agree
I agree (though I don't have a textbook reference for this point, which would be nice to mae sure I'm not overlooking something).
I disagree, and your mixing up of frames (the inertial frame and whatever it is you mean by "measured by observers on the rotating disk") is going to confuse the issue massively.
The rest of the argument hinges on this point.
I'd say that d most likely isn't true. Assuming I'm understanding you correctly.
I think I paraphrased too much. Let us say there is an inertial frame S, that the centre of the rotating disc is initially at rest in. The inertial observer O remains at rest wrt to S and the disc rotating around the x-axis of S, is accelerated along the x axis. Observer O' is comoving with the centre of the disc and remains at rest wrt reference frame S' which is moving linearly wrt frame S along the x/x' axes. The last observer O'' is at rest in the rotating reference frame S'' of the disc and is positioned on the edge of the disc. Observer O'' measures distances between reference points on the disc. If these remain constant then he confirms that Born rigidity is maintained.
You agreed that the angular velocity of the disc slows down as measured by O as the linear velocity of the disc increases relative to frame S. Ordinarily when the rotation rate of a disc is changed (no linear motion) the ratio of the circumference to the proper radius has to change. This is the well known concept that it is impossible to spin up a disc and maintain Born rigidity of the disc. However, if we have a disc with constant angular velocity but linearly at rest in a given irf and then do a Lorentz boost along the spin axis of the disc, the outcome is different. The angular velocity appears to change, but there is no corresponding changes in the proper dimensions of the disc and Born rigidity is maintained in this case. The question is which case best represents the disc that experiences proper linear acceleration? As mentioned in an earlier post, performing a Lorentz boost with velocity -v does not necessarily produce the same results as actually physically accelerating an object to velocity v relative to the initial unboosted irf.
I think Peter is tending to the opposite conclusion, but the jury is still out.
If we look at the disk in what you call frame S', the frame that's co-moving with the disk, it doesn't "slow down".
I'm not sure how you are defining "the" circumference of the disk, the term is notorious for different definitions. But if we use a definition that is independent of the observer, then it seems obvious to me that the circumference must remain the same - because it's really easy to compute in frame S', and in frame S' it's constant.
[add]
Basically, we just have a disk, and [strike]we are[/strike] I am demanding that what we define as "the circumference" be the same before and after a Lorentz boost. The problem is formulated in terms of an "active" boost, which confuses things a bit, but if we start by demanding that our definition of "circumference" be unchanged under a passive boost I think we will start to see some resolution.
So ultimately I suspect the whole argument is about how to compute the circumference of a disk. Which has been the topic of a lot of other threads, and is notorious for causing a lot of confusion (due to the problem previously mention of defining precisely what it actually means in a manner that allows one to actually calculate it.)
I'm not sure how much I want to rehash all that, but I suppose if you go to the trouble of spelling out your defintion, I might get motivated to try and spell out mine.
On a related note I suppose I should review the expansion tensor approach and see what I get with the congruence that I mentioned earlier.
I am wondering about different approach to understanding this problem (unfortunately, I only pose it - I don't have time now to pursue it), via Fermi-Normal coordinates. Fermi-Normal coordinates can be specified for a world line undergoing arbitrary motion and rotation (the more extreme, the smaller the region covered). The origin of such coordinates can be taken as the 'center' of a body. A (not necessarily born rigid) body can be defined as the congruence of constant coordinate position world lines, within a boundary. Questions:
1) For cases where Born rigid motion is possible (e.g. uniform acceleration; rotation without acceleration), is this FN-coordinate body a Born rigid body?
2) For other cases, is there a meaningful attribute (less abstract than, e.g., the expansion tensor) of this FN defined body that shows how it is not Born rigid?
I would like to think the answer to (1) is yes, and that thus this FN body is the 'closest you can come' to a rigid motion; and it is Born rigid when that is possible.
In reference to the above idea, I found the following paper:
http://arxiv.org/abs/1103.4475
It is of interest in general for this thread. Further, it suggests (1) above is true, but that final idea is not useful. It provides an alternative to Fermi congruences that can be achieved by perturbation of Fermi congruences that the author's argue is 'as rigid as possible' for cases more general than Born rigid motion.
I don't think this is quite right. A single worldline can't undergo "rotation"; that requires a congruence of worldlines. And F-N coordinates can't be constructed in the way you are describing for an arbitrary congruence, only for one in which the spatial basis vectors that point from one worldline to "neighboring" worldlines in the congruence are Fermi-Walker transported, i.e., in which the spatial basis vectors are "nonrotating". In other words, only a non-rotating congruence (one whose twist is zero) can be described by a set of worldlines that maintain constant spatial coordinates in the Fermi Normal chart that is centered on the "origin" worldline of the congruence.
Interesting, it looks like this covers somewhat similar ground to the paper that yuiop linked to earlier in the thread.
For non-rotating Born rigid motions (i.e., linear accelerations), yes, I agree. I'm not sure I agree as you state it for the case of rotating Born rigid motions (i.e., rigid rotation but with the center of mass moving inertially), for the reason I gave in my previous post: if you set up a F-N coordinate chart about the central point of the rotating object, the other points in the object will not have constant spatial coordinates in this chart.
No, this is an over-restrictive definition. It is certainly true that an arbitrary congruence can't be handled. But any proposed worldline (to become the spatial origin) combined with an ascribed rotation can be handled.
See page 2 of the paper I linked above for confirmation:
"Generalised Fermi coordinates [5] are defined on the basis of an origin worldline γO and three
spatial axis that are Fermi-Walker transported along γO, with an arbitrary ascribed rotational
motion."
I have seen this generalized definition of FN coordinates in most papers and sources dealing with them (but not in wikipedia).
Not if the Fermi-Walker transport criterion is met. F-W transport constrains the spatial basis vectors so they can't rotate. The standard definition of Fermi Normal coordinates, at least the one that I'm familiar with from MTW, Wald, and other references, requires the spatial basis vectors to be F-W transported.
The definition of "generalized Fermi coordinates" that you quote is a bit unclear:
PAllen said:
"Generalised Fermi coordinates [5] are defined on the basis of an origin worldline γO and three spatial axis that are Fermi-Walker transported along γO, with an arbitrary ascribed rotational motion."
If they really mean the spatial axes are F-W transported, then it is impossible to have "an arbitrary ascribed rotational motion". I haven't read the full paper, but I suspect what they really mean is spatial axes defined as F-W transport *plus* an arbitrary ascribed rotational motion; i.e., the actual spatial axes are *not* F-W transported, but F-W transport is used to set the standard of "no rotation" to which the actual spatial axes are compared to give a well-defined meaning to the "rotation" of the axes.
Say we have a time-like congruence described by a time-like vector field ##\xi^{\mu}## and assume it is in Born rigid motion. We take an origin worldline ##\gamma_0## that is an integral curve of ##\xi^{\mu}## and imagine an observer described by ##\gamma_0##. If the observer's chosen tetrad contains spatial basis vectors that are Fermi-Walker transported along ##\gamma_0## (i.e. the observer is described by a locally non-rotating frame) then relative to this observer, the only motion of the particles described by infinitesimally nearby worldlines in the congruence will come from the twist ##\omega^{\mu} = \epsilon^{\mu\nu\alpha\beta}\xi_{\nu}\nabla_{\alpha}\xi_{\beta}## which will make the particles rotate relative to the (Fermi-Walker transported) spatial basis vectors of the observer following ##\gamma_0## (there is no other relative motion because of Born rigidity).
The only way for these particles to be at rest relative to said observer (and hence have constant spatial coordinates as represented in the observer's comoving Fermi-Normal coordinates) is for ##\omega^{\mu} = 0##; in other words, if the observer attaches connecting vectors ##\eta^{\mu}## to these infinitesimally nearby particles in the congruence then their velocities relative to him/her will be given by ##\xi^{\mu}\nabla_{\mu}\eta^{\nu} = \omega_{\mu}{}{}^{\nu}\eta^{\mu}##, where ##\omega_{\mu\nu} = h^{\alpha}{}{}_{\mu}h^{\beta}{}{}_{\nu}\nabla_{[\alpha}\xi_{\beta]}## is the rotation tensor (we have Born rigid motion so we will necessarily only have rotational velocity relative to the spatial basis vectors carried by the observer), and ##\xi^{\mu}\nabla_{\mu}\eta^{\nu}= 0## iff ##\omega_{\mu\nu} = 0## which is equivalent to ##\omega^{\mu} = 0##. This for example will fail for a stationary rotating disk in Minkowski space-time.
If the observer's tetrad doesn't contain Fermi-Walker transported spatial basis vectors then I don't see how the infinitesimally nearby particles in the congruence could have constant spatial coordinates in the observer's comoving Fermi-Normal coordinates (because now the observer is described by a frame which rotates relative to the local standard of non-rotation and said observer will then attribute Coriolis accelerations in his comoving Fermi-Normal coordinates to the nearby particles in the congruence, see MTW p.332) unless the twist of the congruence is such that the nearby particles rotate exactly along with the frame rotation.
This is what I believe Peter was also referring to.
That is what they mean, and what is described in MTW and numerous other sources. The paper shows that Fermi coordinates for rotation around inertial world line describe Born rigid motion.
The MTW discussion of Fermi coordinates encompassing rotation is section 13.6.
Here are two more references on Fermi-Normal coordinates including rotation:
http://arxiv.org/abs/gr-qc/9402010
http://adsabs.harvard.edu/full/1988CeMec..44...61F
  • #31
Ah, yes, this does discuss what they call the "proper reference frame of an accelerated observer", where the "accelerated" can arise from any arbitrary combination of linear acceleration and rotation. But I don't see them using the term "Fermi coordinates" here (though that's really an issue of terminology, not physics). They do make it clear that the spatial basis vectors are Fermi-Walker transported only in the case of zero rotation.
Yes, but not for rotation around a linearly accelerated worldline.
  • #32
Yes, but many later writers (as exemplified by a couple of my references - I have seen many others over the years) call this simply Fermi-Normal coordinates or generalized Fermi coordinates. Anyway, it is just terminology.
I never said otherwise. Here is the exact quote of mine you initially questioned:
"1) For cases where Born rigid motion is possible (e.g. uniform acceleration; rotation without acceleration), is this FN-coordinate body a Born rigid body?"
Then, after I wrote that, I found I found the paper which confirmed that this is true: whenever FN coordinates (including rotation) are applied to scenario where Born rigid motion is possible, the congruence of constant spatial coordinate positions describe Born rigid motion.
The paper also showed the authors entertained my other suggestion: FN (extended, if you will) congruences are as close as possible to rigid motion for other cases. Unfortunately, they showed this was not so - you can do better with a more complex construction (without, of course, fully achieving Born rigidity; there is no dispute with Herglotz-Noether)
  • #33
I've been busy recently, but had a few thoughts on the topic.
It's helpful to consider the case of a block sliding along the floor of an Einstein's elevator before tackling the rotating case. There is some discussion by me in another thread https://www.physicsforums.com/showthread.php?t=701257, the discussion includes a derivation of the trajectory of the moving block in an inertial frame, and a convenient set of coordinate transforms and an associated metric.
It's a bit sketchy, but the supporting math is there, though the "convenient" coordinates aren't Fermi-normal coordinates. One could get Fermi-normal coordinates at the expense of making the metric time dependent, but I'll leave that to the interested reader (my personal guess is that the approach I took will be easier to manage and understand).
I'll summarize the results a bit less mathematically.
In Fig 1, we see the usual picture of the block sliding along the elevator floor. The solid and hatched block represents the position of the block at two different times.
A gyroscope attached to the block will rotate, because of effects similar to Thomas precession, whose axis is in the a (cross) v plane, cross being the vector cross product. The plane of rotation is the a^v plane, i.e. it is the plane formed by the accleration vector and the the velocity vector. It's not particularly obvious why the block is rotating viewing this diagram.
In Fig 2, we see the block in an instantaneously co-moving inertial frame. The elevator floor now appears curved, due to the relativity of simultaneity. The block is stationary, and the floor slides in the other direction, without rotation. The block itself rotates so that it's bottom of the block is always parallel to the curved floor - this is again due to Thomas precession, it's not caused by any torque from the floor. It's a bit more obvious in this diagram why the block must rotate.
The main effect of the motion of the block as far as dynamics go will be an increase in its weight.
If we consider the rotating disk case now, I believe the following should be true (I haven't done separate detailed calcuations)
1) We will have the same increase in weight at the edge of the disk relative to the center of the disk. This could be regarded as stresses on the disk (though the stresses will be immediately translated to the floor).
2) There will be additional Thomas precession due to the centripetal acceleration and the velocity of the disk (one might argue that this is in fact the true meaning of Thomas precession). This will induce some stress on the disk as well, though I find it difficult to vizulaize the details. However, these stresses would be present in a rotating disk that was NOT in an Einstein's elevator, so I don't think these stresses are of interest to the Born rigidity question.
I don't see, at the moment, a source for any other stresses than 1) and 2).
  • #34
All your inputs are gratefully received and worth any wait :approve:
This is a useful simplification that may assist in resolving the question raised in this thread. Your metric is interesting although I have not fully grasped it yet. Can you confirm that the the proper length of the block along the x-axis remains constant or are their issues with rotation that make this unclear?
This is exactly the precession I was trying to describe in the last paragraph of post #9. I have attached a diagram to show the various vectors you describe as applied to the rotating disc. It is easy to see from the diagram that the Thomas rotation effect of opposing sides of the disc counteract each other and there is no net rotation of the disc, although there may still be additional internal stresses induced within the disc as a result.
Agree. With a properly supported disc on suitable bearings, this should have no effect on the geometry or Born rigidity of the disc.
Again I agree. It is difficult to see any intuitive reason why a disc with constant angular velocity, at constant altitude with constant proper linear acceleration should have a breakdown of Born rigidity.
  • #35
As I've stressed before (pun intended :wink:), the key issue isn't stress, it's shear--not shear stress, but shear in the congruence of worldlines describing the disk. I think your picture makes it clearer where the shear comes from in an accelerated, rotating disk. I'll approach this in two stages.
(1) First consider a rotating, accelerated *ring*--i.e., a circular object with negligible thickness in the direction of its linear acceleration, *and* negligible annular thickness (i.e., radial dimension perpendicular to its linear acceleration). As the papers linked to earlier in this thread show, Born rigid motion *is* possible for this object.
But *how* is Born rigid motion realized for this object? First consider the case of a rotating ring whose CoM is moving inertially, but which has to be "spun up" from the non-rotating state. Can this be done in a Born rigid manner? Yes, it can (remember this is a *ring*, not a disk!). All we need to do is adjust the acceleration profile of each little piece of the ring so that everything stays "in step" as it spins up. From the standpoint of the inertial frame in which the ring is initially at rest, what we're doing is a sort of circular analogue of the Rindler congruence; but instead of the acceleration varying in space (with the x coordinate), it varies in *time*--we *change* the acceleration of the disk as it spins up, in a way that just compensates for the length contraction and time dilation of the disk relative to the global inertial frame, so that the distance between neighboring pieces of the ring, as measured by observers riding along with the pieces, remains constant.
The case of a rotating ring that is linearly accelerated works similarly; the only difference is that now, we add an acceleration component perpendicular to the ring plane (in the above case, the acceleration was entirely within the ring plane). But we can still keep the ring's motion Born rigid, provided we are allowed to *adjust* the ring's acceleration--i.e., we need to be able to add an arbitrary *tangential* acceleration, just as we would if we were "spinning up" the ring, in order to compensate for the changing length contraction and time dilation of the ring, due to linear acceleration, relative to a global inertial frame. (Note that we have not yet discussed, in this thread, the fact I just mentioned, that Born rigid motion of the ring requires this tangential acceleration.)
(2) Now consider the case of a rotating, linearly accelerated *disk*. We can think of the disk as a set of concentric rings with different diameters. But that at once shows us the key difficulty with trying to make the disk's motion as a whole Born rigid: the tangential acceleration component that we have to add in, per the above, in order to keep each individual ring's motion Born rigid, is *different* for the different rings! This is because the magnitude of the required tangential acceleration varies with the radius of the ring.
But this change in tangential acceleration from ring to ring must produce shear between the rings--in other words, it's impossible to both keep each individual ring's motion Born rigid, *and* to maintain the rings stationary relative to each other. It's the same problem encountered in trying to spin up a disk (instead of a ring) from a non-rotating to a rotating state in a Born rigid manner: each ring within the disk requires a *different* tangential acceleration profile to keep it Born rigid within itself as it is spun up.
I think this is the intuitive picture I was looking for earlier; thinking over pervect's scenario helped to break it loose.
  • #36
Thanks Peter, that's great! But is there a way to make more explicit the need for a tangential acceleration of the ring when the ring is linearly (and uniformly) accelerated along the axis perpendicular to the plane of rotation? Also what is the nature of this tangential acceleration e.g. is it constant?
  • #37
As the ring linearly accelerates, if no tangential acceleration is applied (i.e., if the angular velocity of the ring remains constant, as seen by an observer at the ring's center of mass), the locally measured distance between neighboring pieces of the ring will change, because their motion has a component in the same direction as the linear acceleration, and that component changes as a result of the linear acceleration. (This is the same thing that gives rise to the "out of plane" Thomas precession that yuiop referred to.)
In other words, the ratio of the (constant) tangential velocity of the ring (due to its constant angular velocity as seen by a comoving observer) to the total linear velocity of a given piece of the ring, *changes* as a result of the linear acceleration, if no tangential acceleration is present. But for a Born rigid motion, that ratio must remain constant; so tangential acceleration has to be applied to change the ring's tangential velocity "in step" with the change in its velocity due to the linear acceleration.
I haven't done the math, but I think it will have to vary with time if tangential Born rigidity is maintained (i.e., if each "ring" at a given radius perpendicular to the linear acceleration maintains Born rigidity).
Likes 1 person
  • #38
Actually, thinking it over some more, this may not be right; the tangential acceleration has to vary with radius in the disk, but I'm not sure it has to vary with time.
  • #39
I agree that Born rigid spin up of a ring is possible, but surely you meant centripetal acceleration towards the cetre of the ring is required rather than tangential acceleration. Just to be sure we are on the same page I am using these definitions:
Here is how I think Born rigidity of a ring is maintained during spin up. Hopefully we can agree that for a ring Born rigidity is acheived if the proper circuference (measured by an accelerated observer riding on the ring) remains constant and we ignire measurements of the radius.
First, consider the point of view of a non rotating inertial observer ##O_1## that remains at rest with the centre of the ring. Initially the ring is at rest and the circumference ##C_1## is ##2*\pi*R_1## as per the Euclidean expectation. The ring is then spun up by applying acceleration tangential to the ring in the plane of the ring as per the above diagram, until the tangential velocity ##v_1## of the ring is a constant non zerovnalue. According to observer ##O_1## the radius and the circumference of the ring remains constant, whatever the angular velocity of the ring. (Assume just the right centripetal acceleration is applied to ensure the radius remains contant). Now according to an accelerated observer on the ring (##O_2##) the circumference (##C_2##) varies with the tangential velocity of the ring according to ##C_2 = 2*\pi*R_1*\sqrt{1-v_1^2/c^2}##. In order to retain Born rigidity, the radius will have to shrink (as measured by ##O_1##) and this can be acheived by applying additional centripetal acceleration over and above that required to maintain constant radius as measured by ##O_1##.
Note that changing thr radius changes the tangential velocity for a given angualar velocity so will have to bear in mind what type of velocity we are reffering to.
This would be along the rings rotation axis or the z axis as labelled in the drawing in my last post in this thread, which is consistent with the axes convention used by Pervect in the metric he introduced earlier.
You have lost me a bit here. If in a given inertial reference frame (S) a rod of proper length L is moving along its own length in the x direction at velocity ##v_x##, then its coordinate length is ##L*\sqrt{1-v_x^2/c^2}##. Now if the rod is accelerated in the z direction, orthogonal to its length, then its coordinate length does NOT change as measured by the observer at rest in S and its proper length does not change either. However, the velocity in the x direction does slow down to ##v_x*\sqrt{1-v_z^2/c^2}## as measured in S.
  • #40
These are what I was using as well, no disconnect here.
Yes, agreed. In fact the radius will have to change, which is an important point. See below.
Yes. But this is tangential acceleration, and will remain tangential acceleration as seen by an observer moving with the ring; so it can't be that there is no tangential acceleration, as you appear to be claiming. But perhaps I'm misunderstanding exactly what you're claiming. See further comments below.
I was confused on reading this at first, because it's obvious that, for the ring's circumference to remain the same, as seen by an observer moving with the ring, as the ring spins up, the ring's radius, as seen by ##O_1##, must decrease. Then I saw that you say just this later on:
I think this is right: while the ring is spinning up, the centripetal acceleration seen by a small piece of the ring will be larger than it is when the ring's angular velocity is constant. But that doesn't take away the tangential acceleration during the spin-up. (Of course there is no tangential acceleration once the spin-up is complete and the ring's angular velocity is constant.)
It does, however, mean that my later disclaimer about the tangential acceleration was probably correct: the tangential acceleration doesn't have to change with time to keep the spin-up Born rigid, since the additional centripetal acceleration is what's compensating for the increasing length contraction of the ring, as seen by ##O_1##. So if that's what you were referring to when you said there should be centripetal acceleration instead of tangential acceleration, I think I agree. (I still haven't worked through the math in detail, though; there may be other things waiting to bite. :wink:)
Yes, good point.
Yes.
Well, in view of the above, I was a little lost myself, since when I wrote that post I was still thinking in terms of a changing tangential acceleration being required to maintain Born rigidity in the spin-up case. So now we need to re-think the linear acceleration + rotation case in the light of the above. I'll have to ponder that some more.
  • #41
Hi Pervect, I looked at your derivation https://www.physicsforums.com/showpost.php?p=4445483&postcount=9 of the coordinates in the accelerating frame in the relativistic weight thread and everything seems in order. I think the transformation you gave from the accelerating frame to the inertial frame https://www.physicsforums.com/showpost.php?p=4466113&postcount=25 would be useful to this thread, if we had the reverse transformation, i.e. (t,x,z) -> (T,X,Z) but I was unable to derive the reverse myself. Is it possible?
  • #42
Two papers have been noted in this thread that propose generalizations of Born Rigid motion to situations where it is impossible per Herglotz-Noether, by relaxing the Born rigid conditions in some minimal way:
The approach of these two papers is completely different.
Epp et.al. derive that for closed two surface bounding a spatial volume, a 2-parameter congruence of timelike world lines representing the boundary are able to meet the full Born rigid condition. The problem arises trying to extend this to the interior, which is impossible. The interior (except the special cases covered by Herglotz-Noether) must be allowed to deviate from Born rigid motion (to flow and compress as needed). This suggests (to me) that what makes a disk of zero thickness impossible to rotate and accelerated rigidly is the absence of an interior to 'compensate' for the boundary. Alternatively, the the boundary and the interior are the same. I would sum this conclusion as: rigid motion of a shape is generally possible, but not rigid motion of body as a whole.
Llosa et.al. instead keep a strictly local definition of (extended) rigidity that extends throughout a volume. They find one inspired by Born conditions, but weaker, that is always possible, but non-unique. To make it nearly unique they show how to find an instance of the congruence that is a perturbation from Fermi-Normal coordinates (with rotation), for a chosen world line and rotation. This automatically leads to Born rigid motion whenever FN coordinates don't need to be perturbed to be one of their extended congruence class. Otherwise, this process leads to a nearly unique choice among their congruence class. In sum: a notion of near rigid motion of a body as a whole is possible (by relaxing Born conditions and using Fermi-Normal coordinates as a disambiguating 'framework'.)
  • #43
I hate to be the bearer of bad news, but I recall an argument (I believe by Gron, but I don't recall the details that you can't change the rotation rate of a rotating ring in a Born rigid manner.
I'll paraphrase the argument very loosely from memory.
Since I am doing this from memory, it's possible my recollection is flawed, (of course if I spotted any flaw I wouldn't post the argument!).
Let's start with a simpler case, just a small bar.
If you have a small bar, and you want to accelerate that small bar in a Born rigid manner, you need to apply an acceleration at the front of the bar and the rear of the bar 'at the same time".
If you apply the accelerations at different times, the bar doesn't maintain it's rigidity, the front moves first (or the rear moves first) and the length of the bar changes.
Now, when you try to apply accelerations "at the same time" on a ring in a Born rigid manner, using the Einstein convention, as you work your way pairwise along the ring you find you can't accelerate all parts of the ring "at the same time" :-(, because it's impossible to Einstein-synchronize all the clocks in a rotating ring.
You can make the amount of stretching as small as you like by making the change in rotation slow enough, but it's never truly "Born Rigid".
  • #44
One of the papers that PAllen linked to just now argues that you can--not in so many words, but it argues that a closed 2-surface can undergo a Born rigid motion with arbitrary acceleration. That implies that a ring, which is a closed 1-surface, should also be able to undergo a Born rigid motion with arbitrary acceleration.
I don't think this is the correct general way of characterizing the constraint. One reason is that the acceleration varies in space as well as in time, so just saying that the two ends have to be accelerated "at the same time" isn't sufficient. Also, the characterization should be invariant, and "at the same time" isn't. Also, the characterization should be local.
Here's how I think the Born rigidity condition could be characterized to meet the above conditions: in the local inertial frame of a particular small segment of the bar, at a particular instant of that segment's proper time, the proper acceleration of the bar varies in space according to the Rindler formula (##a = 1 / x##, possibly with some constants thrown in)--i.e., in just the right way to keep all the local distances the same. In the case of the bar, the local inertial frames all happen to "line up" globally in a simple way, so all of these local conditions can be "stitched together" into a single global Rindler chart.
However, I don't think the latter condition is required for Born rigid motion, and of course it isn't satisfied in the case of the ring. But I think the former condition can still be satisfied for a ring being spun up, *if*, as yuiop pointed out, there is an extra centripetal acceleration imposed (so that the radius of the ring gradually shrinks as it spins up). The extra centripetal acceleration corrects for the fact that the tangential accelerations applied to neighboring pieces of the ring are not exactly in the same direction, so that the end result, when viewed in the LIF of any individual piece of the ring, shows the proper accelerations and velocities of neighboring pieces varying in space in just the right way to keep all the local distances the same.
I haven't done the math to compute this, so it's just a heuristic argument, but if the paper PAllen linked to is correct, something of this sort must be going on.
  • #45
Actually, I think Pervect may be right here. My non-rigorous argument is as follows. The Epp et.al. paper I linked (on rigid motion of a closed 2-surface) has a strong reliance on the genus of the 2 surface being zero. Thus, despite the over-broad abstract, general, quasilocal rigid motion (as they've defined it) is not possible for a teacup. Within 3 or 4 space, I think a ring is more appropriately considered the zero volume limit of a torus than a dimensional reduction of a 2-sphere to a 1-sphere.
Anyway, a full argument needs to mathematical - either using the techniques of one or another proof of Herglotz-Noether, or setting up the differential system of Epp et.al. and seeing if it is not over-constrained and has solutions.
  • #46
Hm, I'll have to read through the paper again, I didn't see that restriction when I read through it before.
I think it depends on exactly how the genus of the surface comes into the argument. For example, does their argument still work if it is restricted to a great circle on a 2-sphere?
  • #47
The section where they explicitly rely on genus of the 2-surface is page 6, as follows"
"The first equation
tells us that F (the radial perturbation) is determined
by the vector field fi (the tangential perturbation),
and the second tells us that fi must be a conformal
Killing vector (CKV) field on the unit round sphere.
It is well known that any two-surface with the topology
S2 admits precisely six CKVs (compared with two
CKVs for a torus, and zero CKVs for any closed surface of
higher genus[18]), and as generators of infinitesimal diffeomorphisms
they form a representation of the Lorentz
algebra.[12]"
[edit: This is how they ensure enough degrees of freedom for the motion of the boundary. So, I would think the thing to do is try to recast their argument in terms of a closed curve rather than a 2-surface, and see what happens. Obviously, all closed curves are topologically identical. ]
  • #48
Hm, ok, I'll have to think about this. The intuition behind my thinking that if the argument works for a 2-sphere, it should work for a ring, is this: suppose I have a way to spin up a 2-sphere about a single axis in a Born rigid manner (which, by their argument, should be possible). Then the restriction of this method to the "equatorial plane" of the 2-sphere should give a way to spin up a ring (the equator of the 2-sphere) in a Born rigid manner, since the motion of the equator should lie entirely in that plane. But if this is right, there should be a way to formulate it in terms of the degrees of freedom argument; that will take some more consideration.
  • #49
I like this argument intuitively, but it seems to lead, with only a little stretch, to the following argument for the ability to Born rigidly spin up zero thickness disc, which is well known to be impossible:
Consider a thick disc bounded by two plane discs orthogonally connected by cylinder section. Then, your argument seems to show that we should be able to Born rigidly spin up one of the bounding discs, because all its motion should be in one plane. There is something mysterious going on here.
  • #50
No, the argument doesn't carry over to a disk, because the point of just having a ring--and the point of only having a bounding 2-sphere instead of a 2-sphere plus its interior--is to allow the surface (2-sphere or ring) to adjust itself radially as well as tangentially. In other words, the absence of the interior--more precisely, the absence of a requirement to maintain constant proper distance to any neighbors in the interior direction--adds crucial degrees of freedom.
