This question can be answered using the formula D=VT for both cyclists.
  • Thread starter Thread starter Turkishking
7 replies · 23K views
Turkishking
Member advised to use the homework template for posts in the homework sections of PF.
A bicylist is finishing his repair of a flat tire when a friend rides by a constant speed of 3.5 m/s. Two seconds later the bicylist hops on his bike and accelerates 2.4 m/s^2 until he catches his friend.
a) How much time does it take until he catches his friend?
What I did was:
v=v0 + at
solved for T..
V-V0/a = t
3.5 - 0/2.4 = 1.6s
(b) how far has he traveled?
Can I use D=VT? or should I use the formula x=x0 + 1/2(V0 + V)t?
I'm confused when I can use D=vt..
The formula:
##d=vt##
should only be applied when ##v## is constant, otherwise you should use:
##d=\overline{v}t##
where ##\overline{v}## is the average speed. When there is constant acceleration, then we know:
##\overline{v}=\frac{v_i+v_f}{2}##
MarkFL said:
The formula:
##d=vt##
##d=\overline{v}t##
can i use x=x0 + 1/2(V0 + V)t?
Yes, if you'll notice we can write:
##d=\overline{v}t\tag{1}##
Now, suppose we use
##d=\Delta x=x-x_0,\,\overline{v}=\frac{v_0+v}{2}##
Then (1) becomes:
##x-x_0=\frac{v_0+v}{2}t##
or:
##x=x_0+\frac{v_0+v}{2}t##
So, the two formulas are really the same thing just written in different ways.
Now, suppose we use
Then (1) becomes:
or:
thank you :)
Turkishking said:
3.5 - 0/2.4 = 1.6s
i presume you mean (3.5 - 0)/2.4.
That equation will tell you how long it takes for the cyclist to reach 3.5m/s, but that is not the question asked.
Your mistake is to apply equations just because they involve the right types of quantity, in this case an acceleration, a time and two speeds. An equation is meaningless divorced of the context to which it applies.
So then what am I doing wrong
I have told you what you did wrong. What you would like to know is what you should have done.
At time 0 the second cyclist passes the first. At time t, >2s, how far has each cyclist travelled?
