Three corollaries to a well-known theorem
  • Context: Graduate
  • Thread starter Thread starter snipez90
    Theorem
The discussion centers on the proof of a theorem regarding the greatest common divisor (gcd) of two integers, denoted as (a,b). The proof establishes that there exist integers x1 and y1 such that g = (a,b) = a*x1 + b*y1. Three corollaries are derived: (1) (a,b) is the least positive value of ax + by for integers x and y, (2) (a,b) is divisible by every common divisor of a and b, and (3) if an integer h can be expressed as h = ax + by, then (a,b) divides h. The discussion concludes with clarification on the intuitive nature of the first corollary.
  • Understanding of greatest common divisor (gcd)
  • Familiarity with linear combinations of integers
  • Basic knowledge of integer properties and divisibility
  • Experience with mathematical proofs and corollaries
  • Study the properties of the Euclidean algorithm for finding gcd
  • Learn about linear Diophantine equations and their solutions
  • Explore the implications of Bézout's identity in number theory
  • Investigate the relationship between gcd and least common multiple (lcm)
Mathematicians, students studying number theory, educators teaching algebra, and anyone interested in the properties of integers and their relationships.
snipez90
Hello, I need help verifying a few corollaries that follow from the following proof. I will attempt to reconstruct the proof as given in the textbook. Although the theorem is not particularly intuitive, at least to me, I think I fully understand it.
Theorem: Let g be the greatest common divisor of integers a and b and denote it (a,b). Prove that there exist integers x1 and y1 such that g = (a,b) = a*x1 + b*y1.
Proof:
Consider the linear combinations ax + by where x,y range over all integers. Fix a and b. This set of integers contains negative and positive values, as well as 0 by the choice x = y = 0. There must exist a least positive value L in the set and let L = a*x1 + b*y1.
Now we show that L|a and L|b. Assume on the contrary that L does not divide a. Then there exists positive integers q and r such that a = qL + r where 0 < r < L. Then we have r = a - qL = a - q(a*x1 + b*y1) = a(1-q*x1) + b(-q*y1). Hence r is also a member of the set ax + by, which contradicts the minimality of L. Thus L|a. Similarly, we can show that L|b.
Since g is the greatest common divisor of a and b, there exists integers A and B such that a = gA and b = gB. Then we have L = a*x1 + b*y1 = g(A*x1 + B*y1), which implies that g|L. Since g > 0, L > 0, g \leq L. If g < L, then we have a contradiction since g is the greatest common divisor of a and b(remember, L|a and L|b). Thus g = L = a*x1 + b*y1. QED.
Now for the three corollaries:
1. The (a,b), the gcd of a and b, is the least positive value of ax + by where x and y are integers.
2. (a,b) is the common divisor of a and b that is divisible by every common divisor
3. If an integer h is expressible as h = ax + by, then h is not necessarily (a,b) but (a,b)|h and particularly if h = 1, then (a,b) = 1.
The second corollary is most intuitive I think. To prove it, suppose d is any common divisor of a and b. Then d|a and d|b which implies that d|(ax + by). Thus we can choose x and y such that d|(a,b).
In fact, now that I take a closer look, the proofs for the second and third corollary rely on essentially the same property I think? Let g = (a,b) then g|a and g|b so g|(ax+by). Since ax + by = h, g|h. If h = 1, and g > 0, then g = (a,b) = 1.
Then that just leaves the first corollary. I think I'm confused. Does it immediately follow from the proof? In the proof, I assumed L was the least positive linear combination ax + by and deduced that it equaled the gcd so logically the corollary must follow?
corollaries
Hi snipez90! :smile:
Corollaries are usually such easy proofs that they don't deserve to be recognised as separate theorems.
In this case, it follows from the definition of g:
g divides both a and b, so it divides all ax + by, so they can't be less than g. :smile:
Hmm, thanks for that perspective. Now the theorem is intuitive after all and the motivation behind the initially mysterious proof is clear.
I think I'll try not to get too caught up on my "formal" textbook heh.
  • · Replies 0 ·
  • · Replies 26 ·
