Three equal forces applied to a rectangle, find net torque direction?
30 replies · 6K views
paulimerci
Attached below.
T = F.d
This is how I interpreted the problem,
a) The net torque about point A is zero. This is because the forces F1 and F2 are equal and opposite, and they act at the same distance from point A. Therefore, they produce torques that cancel each other out..
The force F3 doesn’t does not produce any torque because it acts along the line of action of F1 and F2 and it passes through the COM.
b) The net torque about point B is counterclockwise because the forces F1 and F2 produce torques that are both CCW, while the force F3 doesn’t produce a torque.
c) The net torque at point c is zero, because it's moment is zero.
I'm not sure with the answers I gave, please point out what mistakes I did. Thank you!
Part (a)
F1 and F2 are not equal and opposite. Their sum is not zero. Also, when calculating torques be sure you multiply the magnitude of the force by the lever arm. What are the lever arms of F1 and F2?
Part (b)
You are correct that F3 produces no torque. Are you sure that F1 and F2 both produce ccw torques about point B? Check again.
Part (c) is correct.
kuruman said:
Part (a)
Part (b)
Thank you, for Part a) I know how to find a lever arm for forces but in this case I don't know how to do it. If I take c as the axis of rotation, the line of action for force F1 is crossing the point c in that case it has no moment. Which point should I take, should I take A the axis of rotation?
Yes, for part (a) you need to take point A as the axis of rotation because that is what the problem is asking you to do.
Thank you, If A is the axis of rotation, then F1 produces a CCW torque, and F2 is parallel to the moment arm, so it doesn’t produce any torque. where F3 will exert a CW torque. Correct?
The only statement that is correct is that F2 produces no torque. Also, it is not enough to say what the direction of the torques for F1 and F3 are. If they are in opposite directions, you need to find which is larger which means you need to find their moment arms in order to calculate the net torque.
The torque of F3 must be greater than F1 because the lever arm from point A is perpendicular to F1. Whereas the lever arm makes obtuse to the force F3.
Hi,
Are you aware you can shift a force along its line of action ? If you shift ##F_3## to point ##B## and ##F_1## to ##C##, which of the two has a longer 'arm'?
BvU said:
Hi,
I understand what you say but am unable to verbalize it. I think F1 has a longer arm.
Since F1 has a longer arm than F3, it makes more torque than F3. F1 is CW, and F3 is CCW. Right?
Part b): The forces F1 and F2 produce equal and opposite torques about point c, while the force F3 doesn't exert any torque. Hence, the net torque at B is zero. correct?
Yes.
Note that, because A is in the line of action of F2, you can instead treat F2 as being applied at A. This produces a symmetry.
Can't resist... does this help ?
##\qquad##
##\qquad\qquad##
[edit] spot the mistake: top red arrow in B is r2 , not r1
haruspex said:
Yes.
Thank you!
If you still have to ask, we haven't succeeded in explaining adequately ... ?
On the other hand, if you were in error, there would have been a 'gentle' nudge in the right direction :smile:
Sorry for prenudging you.
Is there any explanation that I need to provide?
Even though you don't have numbers, you know that the forces are equal in magnitude. Call that ##F##. As far a distances are concerned, call the side of each square ##L##. Then each torque will be some fraction or multiple of ##FL##. Add the two ##FL##s together and see what you get. Equations provide the most convincing explanations.
Just a different approach:
I would vectorially add the three forces.
The resultant force should be applied at the common point C.
Imaginarily locating the pivot point at A for a), B for b) and C for c), would allow me to intuitively see how the resultant force would make the rectangle rotate.
Note that there is a non-stable balance for the case that B is the pivot point, eventually causing a rotation (CCW or CW) until reaching a stable balance.
Thank you,
##F1 = F2 = F3 =F ##, ## L2=L3=L1=L4=L##
For part a)
$$ \sum \tau_A = -F L\sqrt 2 + FL$$
For part b)
$$ \sum\tau_B = F \frac {L \sqrt 2}{2} - F \frac {L \sqrt 2}{2}$$
For part c)
$$\sum\tau_C = 0 $$
Do the equations look convincing?
It looks like a good strategy! Thanks for sharing.
paulimerci said:
Thank you,
For part a)
For part b)
For part c)
$$\sum\tau_C = 0 $$
Does the equation look correct? Mistakes?
paulimerci said:
Thank you,
For part a)
For part b)
For part c)
$$\sum\tau_C = 0 $$
Yes, but you have not finished part b.
Thank you; I think I've included all the forces in the equation for Part B. What is missing?
What’s missing is your answer to the question asked.
Part b): The force F3 acting along the point B where its moment is zero is why I didn't include it in my equation.
$$ \sum\tau_B = F \frac {L \sqrt 2}{2} - F \frac {L \sqrt 2}{2} + F (0)$$
All you have to add is "therefore, of the three options, the answer is …."
