Throwing a die 7 times: Probability of specific outcomes
  • Thread starter Thread starter binjip
    Dice
The discussion revolves around calculating probabilities related to throwing a die multiple times, specifically focusing on the outcomes of rolling a die 7 times. The original poster presents two probability questions: one regarding the occurrence of the number 6 twice and all other numbers once, and another about obtaining all six numbers in the rolls.
  • Participants explore different methods of calculating the probabilities, including permutations and multinomial coefficients. There are discussions about the correct interpretation of the conditions for the outcomes and the implications of having an additional die roll.
Participants are actively questioning the correctness of each other's calculations and reasoning. Some have offered alternative perspectives on how to approach the problem, particularly regarding the arrangement of outcomes and the application of probability formulas. There is a recognition of the complexity involved in the calculations, and some participants express clarity after considering different viewpoints.
There are indications of confusion regarding the arrangement of outcomes and the assumptions made about the number of rolls. Some participants suggest that the original calculations may overlook certain outcomes or arrangements, prompting further exploration of the problem's constraints.
binjip
Throw a die 7 times.
i) What is the probability that you get number 6 twice and all other outcomes once. (e.g. one possible set of outcomes would be 6, 6, 5, 4, 3, 2, 1)
ii) What is the probability that you get all the numbers of a die? (e.g. 6, 5, 4, 3, 2, 1, x where x is {1, ..., 6})
P() = # relevant outcomes / # of all possible outcomes
i)
There are 67 possible ways of arranging the set of 7 outcomes (# of permutations).
There 6*5*4*3*2*1*1 = 6! ways of arranging the numbers under the given conditions.
P(two 6, and all other outcomes) = 6! / 67 = 5! / 66
ii) # of permutations is 67. No change here.
The # of ways to arrange the numbers under give conditions changes:
6*6*5*4*3*2*1 = 6*6!
P(all 6 numbers of a die) = 6*6! / 67 = 5! / 65
Is this correct? Would appreciate any comments. Thanks
This is wrong, try calculating the probability of getting all 6 sides with just 6 dice and you would see why. You are missing some dice outcomes.
Hi Klockan3,
ok, suppose I had only 6 turns throwing a die (or as you suggested having only 6 dice).
There would be 6*5*4*3*2*1 possible ways of arranging the numbers so that I have each number exactly once. This is 6!. So the result would be 6! / 6^6.
Now, I argued that I have an additional turn in which I can throw whatever comes up. So the denominator becomes 6^7. The nominator changed to reflect the possibility of getting any number - I multiplied by 6.
Ok, you are saying that I'm missing some dice outcomes. What I can think of is that the possibility of throwing any number extends to each of the 7 turns (or, alternatively, to each of the 7 dice). So I would multiply by 7.
This would change the result to 7*6*6*5*4*3*2*1 / 6^7.
Do you agree?
Think of tossing 7 balls into 6 bins. You want the number of ways of having two balls in bin 6 and one ball in bins 1-5 each. You can do it sequentially: first think of it as bin 6 and not bin 6. How many ways are there of having 2 balls in bin 6 and 5 balls in bins not 6? For each such way we are tossing 5 balls in bins 1-5. How many ways are there of doing that? Altogether, you ought to end up with the *multinomial coefficient* C(7;1,1,1,1,1,2).
RGV
I am sorry I didn't see this earlier, thought that the two sixes in the first statement had to be next to each other for some reason... So it is also wrong.
RGV
Thank you Ray, I didn't think of it this way, but it seems much clearer now.
Ok, so I have 7! / (1!*1!*1!*1!*1!*2!) = 7!/2 = 2520 ways of arranging the 7 balls into 6 bins.
There are 6^7 of arranging the balls when there are no conditions.
P({1,...5} comes up once and 6 twice) = (7! / 2) / 6^7 = 0.009.
Now the second problem was the probability that I have 5 numbers once and one number twice. This could be stated as putting 7 balls into 6 bins and adding the multinomial coefficient for each case.
P(2-6 once, 1 twice) + P(1, 3-6 once, 2 twice) + ... + P(1-5 once, 6 twice) = 6 * C(7; 1,1,1,1,1,2) = 6*7!/2 = 15,120
So the final probability is (6*7!/2) / 6^7 = .054Do you agree? Thanks.
Ok, I run a simulation and the results are correct. Thanks.
  • · Replies 16 ·
