Time between max speed and max acceleration in spring oscillation
  • Thread starter Thread starter Student3.41
10 replies · 5K views · last reply
Student3.41
An object attached to a horizontal spring is oscillating back and forth along a frictionless surface. The maximum speed of the object is 1.11 m/s, and its maximum acceleration is 6.65 m/s2. How much time elapses between an instant when the object's speed is at a maximum and the next instant when its acceleration is at a maximum
Not sure where to start
You can use equation for a simple harmonic motion (distance as a cosine or sine function), and keep differentiating it to find the time of maximum speed and acceleration.
or use energy conservation
at which position do you think speed and acc. be max
Vmax will occur when x=0
Amax will occur when V=0
V is not a position.
well Amax will occur at xmax
Jow can you write the energies of body at x=0 and x=max?
Yes, and what position is that, where position means angle(s).
In simple harmonic motion the displacement follows a sine (or cosine, your choice) function. You should have seen this in class or in your text.
