Time dependent perturbations and method of succesive approximations
The discussion revolves around the method of successive approximations in time-dependent perturbation theory as outlined in Griffiths' Quantum Mechanics. A key point of contention is whether the coefficients ca and cb should be expressed as a sum of approximations or if they converge to a limit with increasing n. The initial conditions lead to confusion regarding the value of ca_1, which Griffiths states is 1, while others argue it should be 0 based on the integral of zero. The conversation also touches on the differences between this method and other series like the Born series and Dyson series. Ultimately, the participants clarify their understanding of the method and its implications for solving quantum mechanical systems.
mattlorig
In chapter nine of Griffiths' Quatum Mechanics text, he talks about the method of succesive approximations as a method for solving a two level system in time dependent perturbation theory.
d(ca)/dt = f(t) cb --> ca_n = int[ f(t') * cb_n-1, dt', 0 t]
d(cb)/dt = g(t) ca --> cb_n = int[ g(t') * ca_n-1, dt', 0 t]
So, for the case were ca(0) = 1 and cb(0) = 0 one would get:
ca1 = int [f(t') * 0, dt', 0, t] = 0
cb1 = int [g(t') * 1, dt', 0, t]
but griffiths says ca1 = 1.
So, my question is the following. Is ca = ca_0 + ca_1 + ca_2 + ...
or, is ca ~ ca_n (with larger n being more precise)?
I hope my question was clear. I should really learn LATEX.
Maybe I should clarify my question. Regarding the method of successive approxiamtions griffiths talks about in time dependent perturbation theory, is ca
= SUM (ca_n)
= LIM {ca_n}
Hopefully that's easier to understand than my first post.
Nope,i don't really follow.Why would c_{a,1} be 0...?
Daniel.
because the integral of zero is zero.
Okay,alright.What page of Griffiths ?
Daniel.
p 302 of the (my book is black...I think it's the second newest edition). Griffiths does say "ca_2 includes the zeroth order term; the 2nd order correction would be the integral term alone". But, I think griffiths use of ca_n is ambiguous here. In any case, I'm pretty sure that if I just substitute cb_n-1 into the integral for ca_n, and let ca = SUM( ca_n), that would be correct.
\left\{\begin{array}{c} \dot{c}_{a}(t)=\frac{1}{i\hbar}H'_{ab}(t)e^{-i\omega_{0}t}c_{b}(t)\\ \dot{c}_{b}(t)=\frac{1}{i\hbar}H'_{ba}(t)e^{i\omega_{0}t}c_{a}(t) \end{array}\right(1)
Initial conditions
\left\{\begin{array}{c}c_{a}(0)=1\\c_{b}(0)=0 \end{array}\right (2)
Zero-th approximation
c_{a}^{(0)}(t)=1 (3)
c_{b}^{(0)}(t)=0 (4)
First order.Plug (3) & (4) in the equations (1) and integrate
\frac{dc_{a}^{(1)}(t)}{dt}=0\Rightarrow c_{a}^{(1)}(t)=\mbox{const}=c_{a}(0)=1 (5)
\frac{dc_{b}^{(1)}(t)}{dt}=\frac{1}{i\hbar}H'_{ba}(t)e^{i\omega_{0}t} \Rightarrow c_{b}^{(1)}(t)=\frac{1}{i\hbar}\int_{0}^{t} H'_{ba}(t')e^{i\omega t'} \ dt (6)
Second order.Plug the first order approx given by (5) & (6) into the system (1).
\frac{dc_{a}^{(2)}(t)}{dt}=\frac{1}{i\hbar}H'_{ab}(t)e^{-i\omega_{0}t}\frac{1}{i\hbar} \int_{0}^{t} H'_{ba}(t')e^{i\omega t'} \ dt \Rightarrow c_{a}^{(2)}(t)=\mbox{const}-\frac{1}{\hbar^{2}}\int_{0}^{t} H'_{ab}(t')e^{-i\omega_{0}t'} \left[\int_{0}^{t'} H'_{ba}(t'')e^{i\omega t''} \ dt'' \right] \ dt' (7)
Imposing the condition c^{(2)}_{a}(0)=1 (8),you get the formula (9.18) from Griffiths.
You try now for c_{b}^{(2)}(t).See if you get what Griffiths says:it stays unchanged.
Go for the 3-rd order.:wink: Make sure you got it all clear.
Daniel.
Thanks Daniel for the help. I will find the 3rd order approximations to ca and cb today. I think my main mistake was just not realizing why ca_1 = 1. Now that that's clear, the rest should be fairly simple.
Also, after doing a bit more research, I found this method in my old Diff Eq book. Apparently it is known as Picard's Iteration Method.
Lastly, I wanted to thank you for always being kind and helping me through the (many) problems I've asked about. You've been extremeley kind and helpful on a number of occasions, and I appreciate it very much.
Thank you.Well,it resembles in a way the method of iterations when solving the integral equation which gives birth to the Born series.
But it's different.In that case,u get the solution as an infinite sum of perturbative approximations.In this case,it's not a sum anymore.
c_{a}(t)\neq c_{a}^{(0)}(t)+c_{a}^{(1)}(t)+c_{a}^{(2)}(t)+...
,but c_{a}(t)\simeq c_{a}^{(0)}(t) \ \mbox{in the zero-th order}
c_{a}(t)\simeq c_{a}^{(1)}(t) \ \mbox{in the first order}
and so on.I hope u see the difference.U'll have to compare this case with the Born series (as i said before),with the Dyson series and with the series which appear in the stationary perturbative theory for the nondegerate energy levels and see where they look alike and where they are different.
Daniel.
  • · Replies 16 ·
