Time dependent Resistance in an RC-circuit
The discussion revolves around an RC-circuit with a time-dependent resistance, specifically defined as R(t) = R_o(t/τ + 1)^-1. The original poster seeks to derive the charge on the capacitor during discharge, given by the equation q(t) = q_o e^(-t(t/2τ + 1)/R_oC), where q_o is the initial charge.
  • Participants discuss the application of Kirchhoff's Laws and the relationship between current and charge. There are attempts to substitute the time-dependent resistance into the standard equations for an RC-circuit. Some participants suggest verifying the given charge function against the voltage across the capacitor and resistor.
Participants are actively engaging with the problem, offering suggestions and clarifications. There is acknowledgment of mistakes in notation and understanding, and some participants express a desire to explore alternative methods of solving the problem.
Some participants note the original poster's lack of experience with differential equations, which may impact their approach to the problem. There is also mention of confusion regarding the notation used for the time-dependent resistance.
gonzalesdp
You have an RC-circuit with emf E, resistance R, and Capacitance C. However, R = R(t) = R_o(t/tao+1)^-1, where R_o is the intitial resistance. Assume that other than the time-dependent resistance, the circuit behaves normally.
Show that during discharge the charfe at time t is given by
q(t) = q_oe^{-t(t/2tao+1)/R_oC} where q_o is the initial charge on the capacitor.
I know to find q(t) of a simple RC-circuit you need to use basic differential equations. (a course which I have not taken yet). I've tried to simply substitue R(t) for R in the equation
q(t) = q_oe^(-S dt/RC)
(the "S" is the great s for integration, I'm not sure how it should be notated.)
This isn't working though.
Kirchhoff's Laws give: ℇ ‒ IR ‒ q/C = 0.
I = dq/dt .
Not quite sure about your R.
Is it: R(t)=R_0\left(\frac{t}{\tau}\ +1\right)^{-1}\ ?
If you did not learn how to solve a differential equation, do the opposite thing: show that the given q(t) function yields the same voltage across the capacitor (Q/C) and the resistor (IR). I hope you have learned to differentiate and you know that I=-dQ/dt in case of discharge. (The magnitude of charge removed from the capacitor in unit time (dQ/dt) is equal to the charge flowing through the loop in unit time (that is the current I). ehild
Thanks Sammy. I'll work on it a little more with your suggestions.
Thanks ehild. I don't know why but when I worked it out on my paper, I didn't realize the t/tao. I keep using t/(tao + 1). Such a dumb move on my part. Thanks again.
Yup it worked out. It's amazing that I worked on that problem for hours without realizing I wrote it down wrong to begin with. Thanks SammyS and ehild.
I'm still going to try it your way SammyS. I'd like to see how it unfolds that way. It's always good to know another way to solve a problem.
