Time Dilation and Space Travel: Is Wikipedia example wrong?
The discussion revolves around the concept of time dilation in the context of space travel, specifically addressing the interpretation of time dilation effects as presented in a Wikipedia quote. Participants explore the implications of time dilation for hypothetical scenarios involving high-speed travel and the potential for time travel into the future.
  • One participant argues that the Wikipedia interpretation of time dilation is incorrect, suggesting that round trips would negate the effects of time dilation, making future travel impossible.
  • Another participant asserts that the Wikipedia quote is correct and clarifies that time dilation is dependent on speed in an inertial frame, not on direction, challenging the first participant's reasoning.
  • A participant questions the interchangeability of observers A and B, suggesting that since speed is relative, it could be perceived that A is the one moving away from B.
  • Another participant counters that A and B are not interchangeable due to the effects of acceleration, referencing the "twin's paradox" to illustrate the difference in experiences of time between the two observers.
  • A different perspective is introduced, explaining a scenario with synchronized clocks on two planets and a spaceship traveling between them, emphasizing the role of simultaneity and how it affects the perception of time between different frames of reference.
Participants express disagreement regarding the interpretation of time dilation and its implications for time travel. There is no consensus on whether round trips would cancel out time dilation effects or on the interchangeability of observers in different frames of reference.
The discussion highlights the complexity of time dilation and simultaneity, with participants referencing various scenarios and thought experiments that illustrate different aspects of relativity. Limitations in understanding and assumptions about the nature of time and acceleration are evident.
kornelma
Quoting from Wikipedia:
"Time dilation would make it possible for passengers in a fast-moving vehicle to travel further into the future while aging very little, in that their great speed slows down the rate of passage of on-board time. That is, the ship's clock (and according to relativity, any human traveling with it) shows less elapsed time than the clocks of observers on Earth. For sufficiently high speeds the effect is dramatic. For example, one year of travel might correspond to ten years at home. Indeed, a constant 1 g acceleration would permit humans to travel through the entire known Universe in one human lifetime.[14] The space travellers could return to Earth billions of years in the future. A scenario based on this idea was presented in the novel Planet of the Apes by Pierre Boulle."
From my understanding of time dilation, this is an incorrect interpretation of its effects.
Observer A's clock on Earth would experience a slowing of the clock on Spaceship B (traveling close to speed of light) as it moves away from A. However, should B turn around and come back towards A with same speed, A would then experience that B's clock is speeding up the same amount. Hence, when spaceship lands, A and B clocks would show the same time.
This would make the notion of time travel into the future by boarding a fast spaceship that travels with speeds close to speed of light an impossibility.
Time dilation is not about actual slowing of the passing of time on an object traveling close to speed of light, but the about the slowing of THE EXPERIENCE of that time that a relatively stationary object has.
If that is the case, then roundtrips must cancel out this effect, making travel into the future a logical impossibility no matter what kind of propulsion we can invent for spaceships.
Hi kornelma, welcome to PF!
The wikipedia quote is correct.
This is not correct. Time dilation depends only on the speed in an inertial frame, not on the direction.
I think that you are thinking of the Doppler effect where receeding objects are redshifted and approaching objects are blueshifted. The relativistic Doppler effect is slightly redder than the classical Doppler effect due to time dilation, but time dilation does not depend on direction.
I understand about doppler effect.
What I'm questioning is that since speed is relative, somebody observing both A & B, could actually conclude that it was A that was speeding away from B and then returning...or that both A & B were speeding away from each other then back. With other words, A & B are interchangeable, so B could not travel into A's future...
Only uniform speed is relative like that. Basically you hit on the "twin paradox" issue: a change of velocity is "absolute" in the sense that it breaks the symmetry.
If you understand the Doppler effect then you can figure out for yourself that these are physically different situations: the effect of you changing velocity instantly changes your observation of the other's frequency, but not immediately the other's observation of your frequency.
Actually it is more simple then acceleration. Imagine two planets A and B separated by 1ly who have Einstein synchronized clocks. A spaceship traveling at a constant 0.99c in a straight line from planet A to planet B, passes planet A when the clock on the planet reads zero in both frames, and the clock on the spaceship synchronizes to zero. When the spaceship passes planet B, the clock on planet B reads a few days over 1yr in both frames. Yet the clock on board the spaceship reads a little under 2 months. Time dilation by itself does not account for this. The confusion results since planet B's clock should have ticked more slowly from the spaceship's perspective, and yet should be synchronized with planet A, so one might conclude that it should read less then the spaceship's clock, not more. The missing fact is that way back at planet A, planet B's clock appears to already be set ahead by about 10 months in the spaceships frame, a consequence of simultaneity being relative.
  • · Replies 65 ·
13K
  • · Replies 42 ·
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 29 ·
