Time independent perturbation theory
Time independent perturbation theory is defined by the Hamiltonian equation H=H0 + λ * W, where λ << 1. The matrix elements of W must be comparable in magnitude to those of H0, specifically, they should be of the same magnitude as the differences between the eigenvalues of H0. A common point of confusion arises regarding the interpretation of "same magnitude," which refers to the size of the matrix elements relative to the differences between eigenvalues. For example, if the eigenvalues of H0 are 1, 2, 3, 4, 5, 6, 7, 8, and 9, then a matrix element like 2.2 is comparable to the difference between eigenvalues such as 3 and 1.
  • Understanding of Hamiltonian mechanics
  • Familiarity with eigenvalues and eigenvectors
  • Basic knowledge of matrix theory
  • Experience with MATLAB for matrix manipulation
  • Study the principles of perturbation theory in quantum mechanics
  • Learn how to compute eigenvalues and eigenvectors using MATLAB
  • Explore the implications of perturbation theory in practical quantum systems
  • Review examples of time independent perturbation theory applications
Students and researchers in quantum mechanics, physicists working with perturbation theory, and anyone seeking to deepen their understanding of Hamiltonian systems and eigenvalue problems.
cks
H=H0 + lambda * W
lambda << 1 must hold and the matrix elements of W are comparable in magnitude to those of H0.
More precisely, the matrix elements of W are of the same magnitude as the difference between the eigenvalues of H0.
I don't understand what is the meaning of " the matrix elements of W are of the same magnitude as the difference between the eigenvalues of H0".
(the above explanation are obtained from the SChaum's Outlines of Quantum Mechanics)
cks said:
H=H0 + lambda * W
it means that the matrix elements (the entries in the matrix) are about that same size as the difference between that eigenvalues of H0.
What exactly is it that you don't understand? Are you having trouble understanding what exactly those matrix elements are and why they are called matrix elements or is it something else?
Let's say the matrix W=[2.2 3.1 4.1; 4.1 5.3 6.0; 7.3 8.2 9.3] (matlab code)
let's say the eigenvalues of H0 are 1 2 3 4 5 6 7 8 9
the matrix element 2.2 is roughly the same as the difference of the eigenvalues of 3-1. Am I understanding this correctly?
the matrix elements of W are of the "same magnitude"(don't understand what same magnitude means?) as the difference(difference? difference between which eigenvalues, in my example, there are 9 eigenvalues, which minus which is the difference the author is talking?) between the eigenvalues of H0".
  • · Replies 18 ·
