Undergrad Time is not an observable, but....
  • Thread starter Thread starter nomadreid
    Observable Time
The discussion centers on the nature of time in quantum mechanics, specifically its representation and measurement. It argues that while time is not an observable in the traditional sense, it can be calculated from measurements, particularly through the framework of unitary matrices in quantum mechanics. The conversation highlights that time intervals are not directly measurable like position, but rather inferred through changes in quantum states, akin to how classical time is measured using periodic phenomena. Participants express that time can be understood through its relationship to change, even if it lacks a direct operator representation. Ultimately, the dialogue emphasizes the complexity of defining time within quantum mechanics while acknowledging its practical measurement through various means.
nomadreid
It is one of the most repeated responses whenever the subject of time comes up. OK, point taken. But a time interval is (represented by) a unitary matrix, and therefore can be written as exp(iK) for K being Hermitian. So it sounds like although a time (interval) is not directly measurable, it is (theoretically) directly calculable from measurements, and is a real number. But many measurements have at least one step in their derivation which is actually a calculation, such as when we measure velocity. So is the identification of " observable" with "Hermitian" using the former term only in a technical sense but no longer one corresponding to our experience?
What do you mean by saying that a time intervale is represented by a unitary matrix?
Likes Demystifier
How??
Yes. Most things we measure are not directly Hermitian operators in the technical sense. For example life times, cross sections, line widths of spectra, etc.
Likes nomadreid
When I wrote that a time interval is represented by a unitary matrix, I was referring to the solution to Schrödinger's equation: U(t1,t2) ≡ exp[-iH(t2-t1)/ħ], where H is the Hamiltonian. No?
nomadreid said:
When I wrote that a time interval is represented by a unitary matrix, I was referring to the solution to Schrödinger's equation: U(t1,t2 ≡ exp[-iH(t2-t1)/ħ], where H is the Hamiltonian. No?
Well, this gives an operator depending on a time-difference, but it does not represent a time interval in a similar sense as ##q## represents a position. Instead, it is the operator that transforms a state at time ##t_1## into the corresponding state at time ##t_2##. Nothing is measured here or calculated from measurement.
Likes nomadreid
That is, whereas real time is measured by comparing measurements, using distance between events, the speed of light, etc., this is a kind of shadowy time that is represented by changes in states: a kind of clock for quantum states that is related to real clocks. Not to be used to cook eggs, but perhaps it is a heuristic to comprehend the nature of time, whatever that is?
The time to cook eggs is not different, not more or less shadowy than in quantum mechanics; both are equally real. You look at a watch to check the initial time (as a reading of a pointer or a counter), look again at the time the egg is deemed ready, and check if the time difference computed matches your goal. One does essentially the same when timing quantum events, except that the times are often much shorter and you need better equipment in place of a watch.
No quantum physics is needed to comprehend the nature of time. Time is the entity used to model in physics change or the lack of it. It is inferred by relating a change of interest to something that changes in an approximately periodic fashion - the position of the sun, the stars, the shadow of a pole, the pointer of a clock, or the counter of a digital watch.
Likes nomadreid
A. Neumaier said:
Time is the entity used to model in physics change...of something that changes in an approximately periodic fashion
Your previous remark that time in quantum mechanics is real would mean that one have to qualify "something" in the above quote by "something which can be assigned a real-number value", since otherwise the changes of a quantum state would fit this description. So, on one hand the unitary transformation does not represent any sort of time, yet on the other hand it corresponds to changes in time. Sorry, I am flailing a bit here, but I feel that the unitary transformation does represent something that is akin to time if not actually time, but the concept seems a bit slithery to my intuition.
It represents the act of changing in a given time interval the state of an arbitrary system of the kind modeled, in the same way as a 2 by 2 rotation matrix in the Euclidean plane (or the wall of a gallery, say) represents the act of changing an arbitrary figure in the plane by rotating it around the origin by a given angle. But the two times are external to the first act in the same way as the angle is external to the second act. They are just parameters in the description.
Likes nomadreid
Thanks, A.Neumaier. That is an enlightening analogy. This gives me something to mull over; also thanks for your patience.
Time is not an observable, in the sense that there is no time operator. But it doesn't mean that time is not measurable. Time is measured by a clock, and the state of clock is given by the space position of a needle. The space position is an observable.
Likes PaleMoon
Modern measurements of time intervals in quantum experiments typically do not involve a pointer (what you call needle).
It was just an example. Modern instruments of time intervals certainly involve something the measurement outcome of which can be reduced to a macroscopic space position of something.
Likes PaleMoon
How about a digital counter?
Each digit consists of a few black lines, and each black line has a well defined macroscopic position.
Sure, but each of the pixels of the black line has a position known in advance, hence no position is ever measured. Instead it is measured which pixels have which color!
A pixel is relatively small, but still sufficiently big to consider it macroscopic. I'm not sure how exactly a pixel becomes black, but it must be that something physical (call it Z) comes to the position of that pixel which makes it black. Hence it reduces to the position of Z.
In a modern LED display, the pixel brightness is controlled by an electric field that influences the degree to which polarized light goes through a liquid crystal. Thus the something is the electric field Z, not a particle. It is everywhere with different intensity at different positions.
Likes dextercioby and Demystifier
Which confirms what I claim that it is eventually the position of something that determines the macroscopic outcome of measurement. In this case, the position at which the intensity has this or that value.
But this is quite different from the quantum measurement of a position operator of something.
It's not different. For simplicity, let as assume that electric field is zero where the pixels are not black and non-zero where the pixels are black. Let ##|{\bf x}\rangle## be a quantum state of EM field such that
$$\langle {\bf x}|\hat{\bf E}({\bf x}')|{\bf x}\rangle \sim \delta^3( {\bf x}-{\bf x}')$$
(The exact meaning of ##\sim## is a mathematical subtlety, which is not so important here.) Then we can define the position operator as
$$\hat{\bf X}=\int d^3x\, {\bf x}|{\bf x}\rangle \langle {\bf x}|$$
Our measurement can then be reduced to measurement of the position operators of the form of ##\hat{\bf X}##.
I presume I am overlooking some fundamental point here, because it seems to me that saying that the time can be measured via distances is a bit circular, since the distances alone are not sufficient: that is, the distance between two events can be the same in two different measurements with two different time intervals. If we then say that we just need to throw in the speed of light ( and curvature and all that) to calculate the time once given a distance measurement, we then are implicitly assuming a time measurement in place so that the speed of light has a meaning.
I don't see how this can suffice, even assuming a discrete set of points ##x## to eliminate problems with a continuous spectrum. Without further assumptions you don't even get the states ##|x\rangle## to be eigenstates of your position operator.
For simplicity, let us take the discrete case. You can think of ##|{\bf x}\rangle## as a state with a significant (expectation value of) electric field near ##{\bf x}## and negligible electric field elsewhere. Then
$$\langle {\bf x}|{\bf x}'\rangle \approx \delta_{{\bf x},{\bf x}'}$$
so the position operator
$$\hat{{\bf X}}=\sum_{{\bf x}} {\bf x} |{\bf x}\rangle \langle {\bf x}|$$
satisfies
$$\hat{{\bf X}} |{\bf x}'\rangle \approx {\bf x}' |{\bf x}'\rangle$$
Hence my states are approximate eigenstates of the position operator.
$$\langle {\bf x}|{\bf x}'\rangle \approx \delta_{{\bf x},{\bf x}'}$$.
I don't see how something like this follows from your assumption.
For instance, coherent states of EM field satisfy an approximate orthogonality of that form.
Coherent states of the e/m field are not parameterized by a position, so I don't see how they can be used as your kets. Moreover, t make your argument about measuring, you need to get arbitrary close to orthogonality, which coherent states do not provide - they are well-known to be heavily overcomplete.
Arghhhh!
Coherent states are parameterized by expectation value of electric field (and its canonical conjugate), and I already said that my states have defined expectation values of fields. In my case, those fields are localized around certain point x.
I don't take all coherent states. I only take a discrete subset, those the electric fields of which are localized around a discrete set of points. In this way I get near orthogonality. The set is not complete in the full Hilbert space of QED, but I don't need that kind of completeness because I only need those states that can describe the states of discrete pixels.
Ok, so you take the subset of coherent states whose electric field is zero at all but one pixel ##x##. But for each ##x## this still leaves an infinity of coherent states with different intensity; which ones do you pick for ##|x\rangle##?
  • · Replies 24 ·
  • · Replies 35 ·
