Time to reach terminal velocity
2 replies · 12K views · last reply
JC1
What is a formula I can use to calculate time to reach terminal velocity? Must account for air resistance during the time it took to reach terminal velocity.
Known:
mass of object
density of object
radius of object
magnitude of terminal velocity
height of fall (yes, it's high enough to reach tv)
variables necessary to calculate force of drag (done)
I have no idea what equation I can use to calculate the time it would take to reach terminal velocity
I have no idea how to attempt a solution without a formula to use. My text is awful.
You can apply Newton's 2nd law:
Fnet = ma = m dv/dt
Fnet = is the difference between the force of gravity and the drag force.
See if you can find equations for these.
Then you can sove
dv/dt = Fnet / m
for v(t).
If the drag force is proportional to v or v^2, which are the two most common scenarios, terminal velocity is never reached. Instead, the speed asymptotically approaches terminal velocity, and at some point becomes so close that, for all practical intents and purposes, it's equal to terminal velocity.
You can see this from the speed vs. time relationship for a F=-kv drag force. Integrating Newton's second law gives you an exponential relationship that asymptotically approaches mg/k, but never quite reaches it.
