- 9,573
- 2,692
Naty1 said:PAllen:
I don't doubt it if you say so, but wonder about the implications.
What does this mean? Can we attribute this to some physical characteristic? Also you mention 'independence'...and I wonder if in our FLRW cosmological model, and SR and GR, that condition is satisfied. Does 'independence' relate to isotropy and homogeneaty of
the FLRW model...
On orthogonality, I don't know if there is some cute analogy for the properties of Lorentzian space. Mathematically, a Lorentzian metric has the feature that for any timelike direction from a point, there is an orthogonal spatial 3-plane; and for any spacelike direction, there is an orthogonal 2+1 plane. But for light-like, by definition, this is a vector whose norm = dot product with itself = zero. Thus it is 'orthogonal' in some sense to itself and to not to any independent 3-surface . There is an independent spacelike 2-plane orthogonal to a light like direction; there is also an orthogonal 3 surface that can be formed from the light like vector cross the independent orthogonal spatial two plane. This surface is not independent and is neither spatial nor a 2+1 surface.[edit: corrected; see Robphy's post below, and a message] ).
The comment about independence simply means that the most common coordinates are based on orthonormal basis vectors, but this is not a requirement for coordinates. In GR, many common coordinates (e.g. Gullestrand-Panlieve) do not have an orthogonall basis (Schwarzschild coordinates are orthogonal in the region they cover; not orthonormal - this canpt be achieved except locally in GR) . If you see non-diagonal elements in the metric, you know that the basis there is non-orthogonal.
So, while orthogonality of basis is not required for a coordinate system, independence is what is required - if one basis vector is a linear combination of others, you will not be able to reach points not already reachable by the others. Thus, 4 alleged basis vectors, where one is not independent of the others, only covers a 3-space. This has nothing at all to do with isotropy, homogeneity, cosmology etc. - it is just a requirement for constructing coordinates.
