How Does Reducing Time Intervals Affect Accuracy in Numerical Integration?
  • Context: Undergrad
  • Thread starter Thread starter walking
    Accuracy
The discussion centers on the impact of reducing time intervals on the accuracy of numerical integration, specifically using Euler's method as illustrated in the Tipler & Mosca textbook. Participants agree that while the choice of a 0.25s interval is somewhat arbitrary, it serves to approximate the values as the interval approaches zero. The consensus is that comparing results from different intervals helps estimate the accuracy of the original interval, with smaller intervals yielding more precise results. Additionally, the importance of method accuracy is highlighted, as it can significantly affect computational efficiency.
  • Understanding of numerical integration techniques, particularly Euler's method.
  • Familiarity with the concept of time intervals in computational simulations.
  • Knowledge of error estimation in numerical methods.
  • Basic principles of calculus, especially regarding limits and approximations.
  • Research "Euler's method for numerical integration" to deepen understanding of its application.
  • Explore "error analysis in numerical methods" to learn about accuracy and precision in computations.
  • Investigate "adaptive step size control" techniques to optimize numerical integration processes.
  • Study "comparison of numerical methods" to evaluate efficiency and accuracy across different algorithms.
This discussion is beneficial for students and professionals in mathematics, engineering, and computer science who are involved in numerical analysis, simulation modeling, or any field requiring precise computational methods.
walking
In the Tipler & Mosca textbook we are shown how numerical integration (the Euler's method species of it) is done using a spreadsheet program. The authors then go on to say on page 138 that the accuracy of this program can be estimated by first calculating the values for a time interval of 0.5s, then repeating this for a time interval of 0.25s and comparing the values obtained for the two intervals.
I believe that the second interval is arbitrary and the authors simply chose it as an example. It seems that any interval which is small compared to the first one would be sufficient. I think that the purpose of the second run of the program using the "small" interval is basically to mimick what the values would look like if the interval tends to zero. Thus by comparing the original interval to this "zero" interval, we can estimate the accuracy of the original interval with the "actual" values of the variables.
Am I interpreting this correctly?
Edit: The passage in question is the second paragraph on the second page here (the one starting "but how accurate..."):
https://www.dropbox.com/s/ltkcj6wcayd6m7v/tipler mosc accuracy.pdf?dl=0
Hmmm. Wouldn't the 'zero' interval be perfectly accurate for any valid method used? Even if not, I think the point of the 0.25 s interval is to show how accurate the method gets as you decrease the interval. Since we can't actually do a 'zero' interval, the accuracy of different methods is extremely important. If your accuracy goes up by a factor of two every time you halve the interval, while another method's accuracy goes up by a factor of three, then the second method can be run with a longer time interval for the desired accuracy and simulations and calculations performed using it will run faster.
That's my thoughts, but I'm not an expert in this matter.
I have attached the relevant passage and some context. Does it help?
If the difference in the results between 0.25 and 0.5 was negligable, then you know that the step size is small enough.
If the difference is large enough to be significant. Try a step smaller than 0.25 and then do the comparison again.
You want the largest step size you can (it makes the program run faster) such that the error is acceptable. Then use 1/10th of that step size to give yourself a safety margin. You have to decide for yourself, how much inaccuracy is acceptable.
There are strategies that can minimize the number of trials you have to make, but that may not be important to you.
Be aware that in real life it is common that nonlinearities and uncertainty in coefficient values contribute more error that step size.
But for academic purposes, comparison of results with any two step sizes proves the point.
Yes. I believe you are correct in that the 0.25 s time interval was chosen on a semi-arbitrary basis. Doubling the time steps only resulted in a difference of 0.4% in position and 0.05% in velocity. This likely indicates that the original time interval resulted in a final value that is close to the 'true' value.
Yes - it's arbitrary and possibly the result of experience with the particular type of data being used.
To get a good estimate of the error, repeat the numerical integration with smaller and smaller intervals, until the differences settle down within some arbitrary range (the limit as Δx → 0). This is the equivalent to comparing the numerical method with the Integral Calculus result (for which there may not be a simple analytical answer, of course)
  • · Replies 146 ·
10K
  • · Replies 40 ·
