Tips on finding LCM in radians?
  • Thread starter Thread starter Giu1iano
    Radians Tips
7 replies · 4K views
Giu1iano
Lets say I want to find the LCM of -5π/3 and π/2; Also let's say these points are on the Unit Circle.​
It's easier to convert to degrees then back to radians but I don't want do that anymore because it's tedious
Thoughts?
Please explain: in my perception these numbers are not on the unit circle. And points don't have an LCM
But if you mean the LCM of ##{180\over \pi}\displaystyle \arg(e^{-i {5 \pi\over 3}}) ## and ##{180\over \pi} \arg(e^{i { \pi\over 2}}) ## then there's light ! You can forget the common factors and look for the LCM of -5/3 and 1/2. I think that's 5 (-5?), so in your lingo ##\pm 5\pi## is the answer :rolleyes: which I am in fact forbiddden to give because of the PF rules and guidelines. Or perhaps more explicitly ##{180\over \pi} \arg(e^{i { \pm 5\pi}}) ## (which still is a tedious conversion...)
But I count on your having found that already in the 'tedious' manner... ?
After a beer, I see something else that escaped me: what is -300 degrees if you want to find an LCM ? Should I replace that with +60 (which in fact is equal to ##
{180\over \pi}\displaystyle \arg(e^{-i {5 \pi\over 3}})\ \ ##) and end up with 180 as LCM ?
I realized that say -(5π/3) is the same as -(10π/6) and (π/2) is the same as (3π/6), now I have a LCM or lowest common multiple. I can now do 3π - 5π/6 = -(2π/6).
I was plotting a sine graph at the time.
It would help if you were to explain exactly what you were doing and why it came down to finding the LCM of two angles. We would then have a better understanding of what LCM would mean in this context.
Are you trying to find how long before two waves of different wavelengths get back into phase?
No.
Your question really has nothing to do with radians or degrees or anything about angles -- it is a simple question about arithmetic; specifically how to add fractions.
How much is ##3 - \frac 5 6##? According to your work above, it would be ##-\frac 2 6##. Does that even make sense? If you subtract a number that is less than 1 from 3, would you get a negative number?
