What Steps Are Needed for Determining Molar Mass by Titration?
The discussion focuses on the steps required to determine the molar mass of an unknown acid through titration using a standardized NaOH solution of approximately 0.1 molarity. Key methods include confirming the unknown sample's acidity with a pH meter or indicators like phenolphthalein and methyl orange, accurately weighing the sample using an analytical balance, and selecting an appropriate solvent, typically water, for dissolution. The importance of precise measurements and calculations for titration analysis is emphasized, particularly in determining moles of titrant and analyte equivalents.
  • Understanding of titration techniques and principles
  • Familiarity with pH indicators and their color changes
  • Experience with using an analytical balance for precise measurements
  • Basic knowledge of molarity and molar mass calculations
  • Research the use of pH meters in acid-base titration
  • Learn about the principles of using analytical balances for accurate weighing
  • Study the solubility of various acids and bases in water
  • Explore titration calculations, including moles and equivalents
Chemistry students, laboratory technicians, and researchers involved in analytical chemistry and titration methods.
adhiluhur
In lab I have.
200 mL of a standardised solution of NaOH (of appoximately 0.1 molar concetration)
labeled sample tube containing unknown acid or unknown base.
Indicator: phenolphthalein, Universal, methyl orange.
The aim of this laboratory is to determine the molar mass of an unknown acid by titration, and demonstrate the ability to choose laboratory equipment to allow you to perform a titration.
My questions are:
1. How will you confirm that your unknown sample is an acid.
2. How will you quickly, and accurately, weigh a sample of your unknown solid into appropiately, named, piece of laboratory equipment.
3. What solvent do you think would be most appropriate for the titration (the volume of solvent that should be used, and whether this volume should be accurately measured or approximately measured should be addressed when you discuss this point).
4. What steps should be taken to ensure that all of the unknown solid has dissolved.
5. What equipment, and other chemicals, might be used and how they should be used in the titration.
6. The measurement that must be recorded to enable you to determine the molar mass of your unknown sample and how you calculate error percentage.
From adhiluhur:
Use a pH meter if this is allowed. If not, then check your textbook or a reference book on the colors expected for different pH's for each indicator which you have available.
As part of titration planning, knowing approximately what molecular or equivalent weights to expect would be helpful. Start with maybe 0.1 gram to about two decimal places just to try a quick titration, but predict, if possible, how much titrant you'll need.
(Did you need help on the titration analysis calculations? Moles of titrant equals moles of analyte (or should I say, "equivalents" of analyte?))
What level of course are you studying? You probably expect to dissolve the material in water. Probably! Testing solubility would be a good idea first. Would half a gram of sample give a reasonable sized titration? Would this amount of sample dissolve in water? Calculations will help.
Note, that calculations may also indicate if you have a need for making a dilution and take aloquot to titrate.
When you finally know how much sample to titrate, you should use an analyical balance and weight at least to the nearest thousandths place.
12K
33K
