Titration Question
  • Thread starter man0005
man0005
58
How would adding too much indicator to a base being titrated by an acid affect the result?
Can I list it as a possible error?
If not, can someone please suggest another one? please also say how it would affect the outcome of the experiment and how i would be able to minimise it.
Answers and Replies
symbolipoint
Education Advisor
1,499
The indicator itself is either a weak acid or a weak base. Adding too much indicator will force your titration to significantly include the indicator an an interfering analyte component competing with your titrant against the acid or base which you are expecting to measure.
If you can comfortably do the titration monitoring with a pH meter, then you could titrate without a colored indicator.
man0005
58
we used methly orange
NEILS BOHR
79
it can also alter the volume...
symbolipoint
Education Advisor
1,499
Just what level of material quantity is meant by "too much indicator"? A 100 ml. quantity of titration solution would usually be given no more than about 3 or 4 drops of indicator solution, hardly meaningful to the volume of the contents in the titration vessel. Greater concern for concentration would be from adding maybe 5 or more milliliters of indicator solution, but then of great concern is still how much actual indicator was present in the titration vessel to compete with the actually sought material.
Based on volume alone, I would not expect even 7 to 10 ml. of indicator to mean much; it is the amount of indicator compound that would be more of an interference.
Borek
Mentor
29,003
3,669
That's exactly the problem. Changes in volume are rarely important - many titration procedures call for dilution of the sample up to 100 or 200 mL, but it is rarely exact number, so even adding 10 mL more or less doesn't matter.
man0005
58
so whats the general consensus?
is it a possible error?
what im mainly concerned is whether or not it would affect a base
being titrated, since the indicator itself is a weak acid.
i know it would affect an acid (it shifts pH)
Borek
Mentor
29,003
3,669
Have you read the link provided?
man0005
58
yeah..doesnt really specify though :/
just says that it will modify the results
sorry i just want to be sure that it is a possible error :S
symbolipoint
Education Advisor
1,499
Methyl Orange will be in its salt form in alkaline and neutral water solution. The salt form would be yellow, but at about pH 4 and below it will be orange. Some information may be found here: http://en.wikipedia.org/wiki/Methyl_orange
If you had a solution of Methyl Orange but of uncertain concentration, yet high enough to perform a titration, let's say, of the salt form, then the solution would be yellow, probably strong yellow. You would titrate this with an acid to a color change from yellow to orange. You could determine the amount or concentration of the salt-form Methyl Orange in your sample or your solution.
Now, what if your alkaline Methyl Orange solution had a small amount of some other alkaline material present and you titrate with your acid titrant? Your color change pH transition may now depend on two materials: the large amount of Methyl Orange salt, and your other alkaline material. One or both of these materials may have steep pH changes either near or at pH 4.
man0005
58
so...in simple terms..?
would it be a source of error?
man0005
58
so in this case, would be right in saying that adding too much indictor would be a source of error since it is a weak acid and would react with the base being titrated, thus affecting the end point determined.
Or should i say something about the pH?
Borek
Mentor
29,003
3,669
You should try to evaluate how large error it can produce, but you are right when it comes to general idea.
Something what?
man0005
58
as in the fact that it can shift the pH and subsequently the end point?
or does not that apply to this case since it is being added to a base not an acid?
Borek
Mentor
29,003
3,669
Earlier you stated you have read the page I linked to, now you are asking things which clearly show you didn't.
Suggested for: Titration Question
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
