To reduce cost and weight, power transmission lines are made
The discussion revolves around calculating the resistance of a power transmission wire, the current flowing through it, and the power loss during transmission. The problem involves a 30 km long aluminum wire transferring 1000 MW of power at a potential difference of 500 kV.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of resistance using the formula R=ρ(l/A) and question the validity of the resistance value obtained. There are inquiries about the units for area in the resistance formula, with some confusion regarding the use of m² versus mm². Additionally, participants express concern about missing information that may be necessary for solving the problem.
There is active engagement with participants questioning the calculations and assumptions made by the original poster. Some guidance has been offered regarding unit consistency in calculations, and there is a recognition of the need for additional information to proceed effectively.
Participants note that the wire's material is aluminum and mention its diameter, which may influence the resistance calculation. There is an acknowledgment of potential missing information from earlier parts of the problem that could be critical for accurate calculations.
g98
Determine the resistance of a 30 km long wire. b. Assume that the line transfers 1000 MW of power at a potential difference of 500 kV. What is the current through the wires? c. How much power is lost during transmission? What fraction of the transmitted power is lost?
R=p*l/A P=I*deltaV P=I^2*R
so, for the first one i determined the resistance to be 4,23*10^14 ohm, the current through the wire is 2000A . I am not quite sure for the above values and because of that, i get weird values for the lost power in c) I would very much appreciate a bit of help with the exercise
The wire resistance can't be 10^14 ohms. You have done something wrong. Show us how you did the calculations of the wire resistance.
I think there must be some important information we're missing, probably given in a "part a" portion of the problem?
That can't be determined unless the resistance of the line is specified.
The thing i didn't mention is that the wire is aluminium and the diameter is 4cm
I was wondering for the formula R=p(l/A) (p being the specificity) what should be the units of the area? i though it should be m^2 but i checked in internet and in many places i saw mm^2 and i got slightly confused
OK, You're right that the resistance is given by R=ρ(l/A). You can use any units you want as long as you are consistent. If your value for resistivity is in Ohm-m, then you would want to use m for the length and m^2 for the area. Why don't you set up this calculation and show us the values you are using and the results.
  • · Replies 20 ·
12K
  • · Replies 16 ·
