To transmit from 2 counter-rotating shafts into 1 perpendicular shaft?
The discussion revolves around the challenge of transmitting power from two counter-rotating shafts into one perpendicular shaft. Participants explore various mechanical solutions, including the use of gears, differentials, and hydraulic systems, while addressing constraints related to shaft orientation and speed ratios.
  • Some participants suggest using a car differential to manage the rotation of the shafts, but others clarify that the input shafts must rotate in opposite directions.
  • There is a proposal to use bevel gears to couple the shafts, with some participants suggesting offsetting the shafts to simplify the gear arrangement.
  • One participant mentions the possibility of using hydraulic pumps and motors as an alternative method for power transmission.
  • Concerns are raised about how three bevel gears could function effectively given the counter-rotating nature of the input shafts, with questions about the necessary tooth counts for fixed speed ratios.
  • Participants discuss the concept of a reversing gear and its role in counter-rotation, with varying levels of understanding about its mechanics.
  • There is a suggestion to consider a pancake differential followed by a right-angle drive to the output shaft as a potential solution.
Participants express differing views on the feasibility of various mechanical solutions, with no consensus reached on the best approach to transmit power from the two counter-rotating shafts to the perpendicular shaft. The discussion remains unresolved regarding the effectiveness of specific configurations and components.
Participants note limitations regarding the unspecified constraints on the speeds of the input shafts and the requirement for the output shaft speed to be the sum of the input speeds. The discussion includes assumptions about the arrangement and interaction of gears without definitive conclusions.
Al-Layth
TL;DR
How do I transmit power from two shafts, rotating in the opposite directions at different speeds to one shaft perpendicular to both of them?
Well it's kind of what a car differential does. You'd have to reverse one of the two to get them rotating the same way, but if you can't figure out how to do that, you're in the wrong business.
you mean make the two input shafts rotate in the same direction?
I can't do that, they absolutely have to rotate in the opposite direction heh
You have a 'mystery transmission element' in the picture. You mean you're not allowed to put gears or other moving parts inside that? If you are, then what restriction is preventing you from doing so?
no
i can put anything in the mystery area
I'm afraid a mystery area containing a vacuum is probably not going to meet your needs.
Do the two input shafts have to be coaxial? If you can offset them a bit from each other perpendicular to their axes, that would make it simpler.
yes i can move them anywhere but they have to remain horizontal
1) I misread your reply and thought you said there could not be anything in there. Hence the vacuum reply. Scratch that.
2) If you can put anything in there, put in a gear to reverse the rotation direction of one of them, and then put in a differential, just like the one on the old rear-wheel drive cars, and only a little different than the one on the front-wheel drive models. Both serve the same purpose, but only the former has one shaft perpendicular like that.
I know all about differentials, having built a couple out of toys, and having melted one in my Grand Marquis. It was a sight to behold
Great. If you offset them you can use fairly simple gears in that transmission, IMO. Offset one shaft up and the other one down and use bevel gears or similar to couple the two input shafts to the output shaft. If the two input shafts need different gear ratios, use separate bevel gears to do the coupling.
https://m.media-amazon.com/images/I/613n+C3ARML.jpg
Actually, if the different gear ratios are the only issue, then you may be able to just offset one of the input shafts up the output shaft a bit to couple via a different set of bevel gears with a different ratio compared to the bevel gears at the end of the output shaft...
Let us assume that the perpendicular output shaft speed must be the sum of the speeds of the two counter-rotating, independent, input shafts.
1. Three bevel gears.
2. One reversing gear and a differential.
3. Two hydraulic pumps, in parallel, driving one hydraulic motor.
4. Two DC voltage generators, in series, driving a DC motor.
5. Two shaft encoders, a microcontroller, and a servo or stepper motor to drive the output shaft.
for 1.
How could 3 bevel gears work here?
if one is mounted on each of the shafts and the input shafts both interlock with the output shaft then won't the input shafts just subtract from each other?
(here's I have artistically illustrated how I imagine ur three bevel gear idea. ignore the gearboxes )
I swear Im not playing dumb
Whats a reversing gear ?
It is the simplest, but limited solution. The bevel gears would need tooth counts that allowed for a fixed ratio of input shaft speeds.
One pinion drives a second pinion on a parallel side shaft, called a counter-shaft, which must then counter-rotate.
If your two input shafts are coaxial, then the other shaft will also need to be offset by the same amount. That can be done using two slightly smaller pinions, coupled by an intermediate idler pinion of any convenient size.
You might consider using a pancake differential to combine the two axial shafts, followed by a right angle drive to the perpendicular output shaft.
Since the input shafts are counter-rotating, the subtraction would become an addition.
The constraints on the speeds of the input shafts are unspecified.
Are they operating at a fixed speed ratio, or are the speeds quite independent.
