How Do You Determine the Implicit Equation of a Plane from a Line and Origin?
  • Thread starter Thread starter Loppyfoot
    Difficulty Vector
The discussion focuses on determining the implicit equation of a plane that contains the origin and the line defined by L(t) = <1+t, 1-t, 2t>. The key vectors identified are P = (1, 1, 0) and v = <1, -1, 2>. The implicit equation is derived as x - y + 2z = d, with the origin (0, 0, 0) being used to find d, resulting in d = 0. The discussion also emphasizes the necessity of using the cross product of two non-parallel vectors to find the normal vector to the plane.
  • Understanding of vector representation in three-dimensional space
  • Knowledge of the implicit equation of a plane in the form ax + by + cz = d
  • Familiarity with the cross product of vectors
  • Ability to compute gradients and parametric equations
  • Study the properties of the cross product and its application in finding normal vectors
  • Learn how to derive the implicit equation of a plane from given points and vectors
  • Explore the concept of gradients and their role in determining tangent lines to curves
  • Investigate computational methods for finding points in a plane without sketching
Students studying multivariable calculus, geometry enthusiasts, and anyone involved in vector analysis or 3D modeling will benefit from this discussion.
Loppyfoot
Find the implicit form for the plane that contains the origin and the line:
L(t) = <1+t,1-t,2t>
So, the point P = (1,1,0) and vector v= <1,-1,2>.
To find the implicit equation for the plane using the form ax + by + cz = d , I will substitute the vector values in for a, b, and c. So I get
x -y + 2z = d.
My question is, should I use the origin points, (o,o,o) and substitute them in for x,y, and z to get d=0, or is there another process to this?
__________________________________________________________________________________________________________________#2. The function f(t) = (t^@,1/t) represents a curve in the plane parametrically. write an equation in parametric form for the tangent line to this curve at the point where t= 2.
So I solve the gradient: <2t, -1/(t^2)> and at t=2 the point is (4, 1/4).
and the gradient normal to t=2 is <4,-1/4>.
So would the parametric equation be (4,1/4) +t<4,-1/4> ?
Thanks a lot in advance!
L(t) = <1+t,1-t,2t>
What about them? A clearer way of saying this is that P = (1, 1, 0) is on the line, and the vector v = <1, -1, 2> has the same direction as the line.
What you know about the plane is that it contains the point (0, 0, 0) and the line.
To find the equation of a plane, you need one point on the plane and the normal to the plane. If you have two vectors that lie in the plane, how can you get a third vector that is normal to the plane?
x -y + 2z = d.
Ok, so since the vector is pointing in the same direction as the line, I understand that I should use the cross product between two vectors. I understand that I have one vector, <1,-1,2> but how would I find the second vector? Should I use the vector <-1,1,-2> and take the cross product between those two?
No. If you cross those two vectors you will only get the zero vector, since the 2nd vector is just -1 times the first vector.
Draw a sketch of the plane and identify three points that you know are in the plane. From these three points, form two vectors that aren't parallel (or antiparallel, as are your two vectors).
Is there a way to find that point computationally without sketching?
Well, could I use the points (0,0,0), (1,1,0) and (2,0,2)? I got (2,0,2) by f(1).
Is that the process that should be done?
Maybe, but why would you want to handicap yourself by using only half of your brain on the problem?
Sure, those are all points in the plane. Now form two vectors and use them to get a third vector that is perpendicular to the plane.
  • · Replies 21 ·
9K
