ArmoSkater87
- 253
- 0
jcsd, I though pretty much everyone agreed on true, true, true for the first stage. So why are u saying only the last statement is true.
To simplify a little for your sake, picture two clocks that are 300,000km apart and synchronized from Hurkyl's "picture frame." Each clock can send a signal to the other saying what time it is: since it takes 1sec for the signal to reach the opposing clock, each clock compares its own time to the signal it receives and concludes the other clock is a second behind. The paradox can obviously be resolved easily enough knowing the speed of light and the distance between the clocks and calculating the transmission delay.ArmoSkater87 said:thanks for the clarification! :P
actually it all suits my purposes. i don't care to retute SR as long as it sees things MY way ;D
)Earlier in this thread you saidram1024 said:all the clocks are synchronous in the stationary "picture-frame" as hurkyl would call it.
the clocks in all cases emit photon simultaneously RELATIVE TO EACH OTHER.
these clocks are perfectly aligned and synchronized and in all cases they move within the same inertial frame so they can stay calibrated.
ArmoSkater87 said:By the way, u just can't try to disprove the theory of one of the greatest geniuses of all time, SR has been proven correct in several experiments. (-_-)
jcsd said:It isn't/doesn't have to be though, relativistic kinematics are suprisingly easy to understand.
So which is it? Now, for cases 1 & 3 it doesn't matter, because the "picture frame" and the "clock frame" are one in the same.
But in case 2, the clock frame and the "picture frame move relative to each other, and thus the clocks can't emit their photons simultaneously in both frames. They can emit simultaneously in one or the other, but not both.
ram1024 said:no one's yet given me a reason to believe they'd emit photons non-simultaneously in EITHER frame, moving or not.
does the phrase "relative to each other" actually have a meaning in this case? i mean i just threw it out there without thinking of consequences because i cannot fathom the difference it would make.
so if you can, tell me what the difference would be if they emitted photons simultaneously in the "picture frame" and in the "relative to each other frame)
thanks in advance
Please read http://www.bartleby.com/173/9.html
ram1024 said:Hence the observer will see the beam of light emitted from B earlier than he will see that emitted from A. Observers who take the railway train as their reference-body must therefore come to the conclusion that the lightning flash B took place earlier than the lightning flash A. We thus arrive at the important result
this case depicted is actually case 3 of my list, not case 2. note the sources are "lightning flashes" which are not in any way tied to the train.
the train moving towards B)flash is equivalent to my guy running towards B)emitter on top of the train in case 3.
case 2 is the crux of the argument. if "stationary" doesn't exist how can case 1 yield that light hits the observer simultaneously, yet in case 2 if you take that frame as being stationary (inertially relative frame) you DON'T get hit by light simultaneously?
i'm not sure i explained that well enough for you to understand :( sorry if not, i'll do better
Yes, it doesn't matter whether the sources are tied to the train or not, because speed of light is independent of its source
The difference is: in case #2, the photons are emitted simultaneously relative to the emitters (which means also relative to the man). In case #3, the photons are emitted simultaneously relative to the emitters (as you said this is always the case), therefore they cannot be emitted simultaneously relative to the man
ram1024 said:i think you're confusing the emissions with the intercepts... if the sources do not matter in speed, remove them from the picture and view the motions of the observers in case 2 and case 3. they're identical. the photons from both frames were emitted at exactly the same time and place.
Yes.ram1024 said:i can see where you would get this confused.
go back to the link on the page. the lightning is synchronized simultaneous ACCORDING to the simultaneous intercepts of the embankment.
it is deriving simultaneity FROM that frame. and then comparing it to all others.
ram1024 said:the clock/emitters in my experiment are NOT deriving synchronization or simultaneity FROM any frame. they are synchronized together (let's say zero-distance) and then methodically placed into position using exacting methods to ensure they are never subjected to anything that would "unsynch" them
ram1024 said:in this case simultaneous MEANS true simultaneity not "according to how you look at the picture".
i'm going to take a wild stab in the dark that SR doesn't allow ANYTHING to be truly simultaneous unless it emanates from ONE location... right?
There is no such thing as true simultaneity or simultaneity in all frames [when events separated by distance]. That Enistein gedanken proves just that. Seems you didn't get the point from that page
[u](o) <-)|(-> (o)[/u]
You will either make me go insane, or I will give up on you. I'm not sure if you are reading what I'm saying. If you are thinking I don't qualify or something, just say so and I will leave you alone. Otherwise please try a bit harder and hopefully you will be able to answer your own questions.ram1024 said:i see I'm going to have to employ stricter methods to convince you :D
ram1024 said:Case #5
Code:[u](o) <-)|(-> (o)[/u]
One emitter simultaneously shoots 2 photons towards two ovservers equal distance from the center (where the emitter is). the observers carry synchronized clocks to time their photon receptions
SR predicts that since this is a "inertial frame" light will hit both observers at the same time. (True / False) ?
ram1024 said:Case #6
Same thing as case #5 except this time the two clocks use laser light and the distance between them to synchronize. They synchronize in such a way that the light from the center hits them both at what appears to them to be the same "time"
the train is them sped up FASTER in the direction it was traveling (let's say to the right) and another light is pulsed.
SR predicts they receive light non-simultaneous now (because of clocks getting messed up) even though nothing happened that changed clock synch relative to the other clock. (True / False)
David said:Straight line non-accelerated relative motion can’t slow down the rate of any clock. As Lorentz pointed out, a “force” has to be placed on a clock timing mechanism, or removed from it, to change the clock’s rates. “Kinematics” without force changes no clock rates.
thanks in advance
Its sloppy grammar to say clocks slow down in SR, though I admit I do it too. In actuality (and of course, you already know this, as you've been part of this same discussion many, many times), time itself passes at different rates for clocks in different frames, while the clocks themselves are, to a local observer, unaffected.David said:Straight line non-accelerated relative motion can’t slow down the rate of any clock. As Lorentz pointed out, a “force” has to be placed on a clock timing mechanism, or removed from it, to change the clock’s rates. “Kinematics” without force changes no clock rates.[emphasis added]
