Too many programs running in background
In summary, you can try Ctrl+Alt+Delete to see what programs are running in the background, and you can disable them if you want.
z4955
111
I have windows me
would somebody please tell me how to check and see what programs are running in the background on my pc?
also how to get rid of extra stuff I'm not using in the task bar. I close them but next time I reboot they're all right back again. I looked in the startup menu to take them out, but nothing is there.
and what is the difference between RAM and memory??
Computer science news on Phys.org
z4955 said:
I have windows me
Did you try Ctrl+Alt+Delete?
You can take a look at http://netsquirrel.com/msconfig/. There's a link in the article to http://www.sysinfo.org/startuplist.php , which is very helpful.
START->RUN->msconfig
There should be a startup tab where you can disable any programs that start at boot.
Memory is just the generic term. Anything that can store information is memory.
RAM is a specific type of memory. In terms of speed it is slower than cache but faster than your hard drive.
http://computer.howstuffworks.com/ram.htm
when I Ctrl+Alt+Delete a box comes up with a list in it.. are all those the progs that are running? Here they are:
Explorer
Avgemc (avg antivirus)
Avgcc ( something else to do with avg I guess)
Propelac ( propell accelerator)
Loadgm (don't know what it is)
Weather (weatherbug)
Systray ( something that's necessary)
Acbtnmgr_x83 (don't know what it is but have a lexmark 83 printer/scanner/copier)
Printray ( something to do with the printer I assume)
Carpserv (don't know what it is)
Acmonitor_x83 (the monitor, I assume)
I use the printer frequently sometimes and sometimes not at all... does it have to be in startup to operate when I need it?
THANKS for all the neat and helpful sites! :)
Does Ctrl+Alt+Delete open 'Program Manager' or 'Task Manager'?
You can look up anything in the list at http://www.sysinfo.org/startuplist.php . It will tell you what the task does and give recommendations for what to do with it (keep, remove, etc.).
it doesn't specify what it is. A box comes up that says at the top: 'close program' and the list of progs is in a window. at the bottom is says: 'WARNING: pressing Ctrl+Alt+Delete again will restart your computer... "
I checked out that site and almost none of the progs listed are on my list.
Okay, I guess that's Program Manager. I don't know and couldn't find much about it - I've never had ME and don't remember older versions. According to http://ezinearticles.com/?Troubleshoot-Windows-with-Task-Manager&id=1036, Program Manager doesn't list or allow you to do as much as Task Manager, which comes with other versions. But you can download task manager programs if you really want one. Or there may be another way to access the information. I'll check in a bit.
Edit: No, I couldn't find anything. Maybe someone else knows. If not, you can always download one of the free utilities - or buy one.
:biggrin: That's just the first page. You have to search for your processes or browse alphabetically. The search may not return results if the names are a little different. If this happens, browse alphabetically. For instance, here's the http://www.sysinfo.org/startuplist.php?filter=Avgemc .
You can also try http://www.answersthatwork.com/Tasklist_pages/tasklist.htm or just google for them.
wow!
thak 4 tell us
oooooooooo
i noe why last time my com
have virus
bcz i let adware to came in !
1. Why is it important to limit the number of programs running in the background?
Having too many programs running in the background can slow down your computer's performance and use up valuable system resources. This can lead to longer load times, freezes, and crashes.
2. How can I check how many programs are running in the background?
In Windows, you can press Ctrl + Shift + Esc to open the Task Manager and view all the running programs. On Mac, you can use the Activity Monitor to see a list of running processes. Alternatively, you can right-click on the taskbar (Windows) or use the Apple menu (Mac) to access the list of open programs.
3. Can I stop programs from running in the background?
Yes, you can manually close programs that are running in the background. In Windows, go to the Task Manager and select the program you want to close, then click on "End Task". On Mac, you can use the Activity Monitor to quit the program. You can also prevent programs from automatically starting up in the background by adjusting your system's settings or using a third-party program.
4. What programs are safe to close in the background?
It is generally safe to close programs that you are not actively using or that you do not need for your current tasks. However, be cautious when closing programs that are essential for your system to run, such as antivirus software or system updates. It is best to consult with a professional or do some research before closing any programs that you are unsure about.
5. How often should I check and close programs running in the background?
It is a good idea to regularly check and close unnecessary programs running in the background, especially if you notice a decrease in your computer's performance. You can also set up scheduled maintenance tasks to automatically close programs or clear out temporary files and processes to keep your system running smoothly.
  • Computing and Technology
10K
