Topological Basis in l2 Space: Why?
  • Context: Graduate
  • Thread starter Thread starter LagrangeEuler
    Basis Topological
The discussion centers on the classification of basis vectors in the l2 space, specifically the vectors |1⟩, |2⟩, and |3⟩. Participants argue that these vectors do not form a topological basis or a vector space basis due to the necessity of finite linear combinations for vector spaces. The term "topological basis" is critiqued as misleading, with suggestions that "orthonormal basis" or "Schauder basis" would be more appropriate. The conversation highlights the confusion surrounding the terminology and the implications for understanding the structure of l2 as a Hilbert space.
  • Understanding of l2 space and its properties
  • Familiarity with vector space and topological vector space concepts
  • Knowledge of basis types: Hamel basis, Schauder basis, and orthonormal basis
  • Basic principles of functional analysis
  • Research the differences between Hamel basis and Schauder basis in functional analysis
  • Study the properties of Hilbert spaces, focusing on orthonormal bases
  • Explore the concept of uniform approximation in functional analysis
  • Learn about the implications of basis terminology in topology and vector spaces
Mathematicians, students of functional analysis, and anyone interested in the theoretical foundations of vector spaces and topology.
LagrangeEuler
Why in ##l_2## space basis ##|1 \rangle=[1 \; 0 \; 0 ...]^{\mathsf{T}}##,
##|2 \rangle=[0 \; 1 \; 0 ...]^{\mathsf{T}}##, ##|3 \rangle=[0 \; 0 \; 1 \; 0...]^{\mathsf{T}}##... is called topological basis?
Because, not every vector in ##l_2## is a finite linear combination of these basis vectors. Some are infnite combinations, convergence is needed, hence topological.
But they are not open, aren't they? And they aren't suited as a basis for closed sets. Your argument shows, that they cannot be a vector space basis since we needed finite linear combinations. Any open set is a union of ##|n\rangle ##, however, they are not part of the topology except for the discrete.
What I meant is that if you take the span of those vectors you don't get the whole space you need to take the closer of the span.
I think that this is an abuse of language. Those vectors do not constitute a topological basis, neither do they constitute a vector space basis. My assumption is therefore that the author uses topological basis in contrast to vector space basis, in order to get rid of the finiteness constriction of vector space bases, but they are neither.
They generate the direct product (not direct sum!) ##\ell_2=\mathbb{R}|1\rangle \times \mathbb{R}|2\rangle \times \mathbb{R}|3\rangle \times \ldots ##. To call it a topological basis is plain wrong in my opinion.
Not sure what you mean! No one was talking about the direct sum nor the direct product. And, yes, it is just i name the author uses. I think it is quite standard.
The basis of a topology is defined as subset of open sets. To distinguish it from a topological basis is hopefully not standard! And if, I will no longer use english and topology at the same time.
Unfortunately. This is what it is about.
No, it is not about bases of a topology, but about bases of topological vector spaces.
I still don't understand the ##l_2## space is not the direct sum nor the direct product.
In this case, the wording is more than confusing.
As ##\mathbb{R}##-module?
It can be, that's why the context is important.
The direct sum is the vector space of all finite sequences of real numbers. The direct product of all sequences. The ##l_2## of all square summable sequences.
That's what I said. They generate the ##\mathbb{R}## module. No basis in either meaning, and not very related to one of the structures of ##\ell_2##. All it does is: We can write the elements of ##\ell_2## as ...
Calling it a topological basis when a basis of a topology is something else, is a very bad choice.
I agree that topological basis is very bad use of language because you immediately think about a collection of opens in a topological space.
I also agree with @martinbn post #2. This is what the author had in mind.
Since ##l^2## is a Hilbert space, a more appropriate name would be "orthonormal basis".
But it's still not a basis by the regular vector space definition, which the author thinks is more important to distinguish.
I think this is often called a Schauder basis (https://en.wikipedia.org/wiki/Schauder_basis). I haven't seen the term "topological basis" used for this but it makes sense (although it's not a basis for a topology...)
Here's a page from nLab, where the term "topological basis" (not in the sense "basis for the topology") is used, and it seems to be differentiated from both the Hamel and the Schauder basis (although I'm not exactly sure I understand the difference):
https://ncatlab.org/nlab/show/basis+in+functional+analysis
@Dragon27 I think the difference is something like this: Let ##V=C([0,1])##, with the sup norm. Then ##1,x,x^2,\ldots## is not a Schauder basis because not every continuous function is a power series, but it is a topological basis according to your link because every continuous function on a finite interval can be uniformly approximated by polynomials (and none of these monomials can be uniformly approximated by others).
The link actually claims that you can uniformly approximate x on an interval with higher degree monomials at the bottom. But it does give a similar example using Fourier series.
Thanks, I should have read a bit further before posting...
  • · Replies 23 ·
