Topologist's sine curve is not path connected
  • Thread starter Thread starter math8
    Curve Path Sine
10 replies · 6K views
math8
This example is to show that a connected topological space need not be path-connected.
S={ (t,sin(1/t)): 0 <t <= 1 }
A={ (0,t): -1 <= t <= 1 }
let T = S U A
with the topology induced from R^2.
I show T is not path-connected. Assume to the contrary that there exists a path p:[0,1]-->T with p(0)=(1/pi, 0) and p(1)=(0,0). Let
k = Inf{ t in [0,1] : p(t) in A}.
Then p([0,k]) contains at most one point of A. I want to show Closure of p([0,k]) contains all of A. So p([0,k]) is not closed, and therefore not compact. But p is continuous and [0,k] is compact, so p([0,k]) must be compact,which is a contradiction.
How do I show Closure of p([0,k]) contains all of A?
Your notation is about as confusing as you could possibly make it. A path p(t) going from p(0)=(0,0) in T to p(1)=(1,sin(1)) in T must approach a definite limit as t->0. But it has to follow the curve (t,sin(1/t)) to get there. Of course the Closure(p)=A. Pick an e>0. There is a point on p(t) within a distance e of any point on A. It oscillates infinitely often between -1 and 1 as t->0.
The definition I have for X being path-connected is that for any 2 points of X, there is a path connecting them. So if the continuous map p:[0,1]-->X is the path connecting x and y in X, we have p(0)=x; p(1)=y.
Here I chose the points x=(1/pi, sin(1/(1/pi)) )= (1/pi, 0) and y = (0,0) in T and I assume T is path-connected so there is a path p:[0,1]-->T connecting x and y.
I don't see how my notations are confusing (unless the definitions I have are wrong).
For some reason I'm not getting the proof. Is there a simple way to show A is contained in the Closure of p([0,k]) where k = Inf {t in [0,1] : p(t) in A}?
Perhaps I'm just easily confused. The point is that p(t) must contain all of the points O={(t,sin(1/t)) for t in (0,1/pi)}. Can you prove that? Now can you show that for any point a in A, and any e>0 there is a point in O whose distance from a is less than e?
what do you mean by p(t) must contain all of the points O={(t,sin(1/t)) for t in (0,1/pi)}, is p(t) a set? How does it relate with Closure of p([0,k]) where k = Inf {t in [0,1] : p(t) in A}?
The image of p(t) is a set, yes. I am saying that p(t) must follow the curve (t,sin(1/t)). And all of the points in A are limit points of that image set.
So does it mean that A is contained in the closure of Image of p (i.e. closure of p([0,1])), but does it imply that A C closure of p([o,k])?
I wouldn't worry about p([0,k]). The point is that A is contained in the closure of p([0,e)) for any e>0. This is going to make it difficult for p to have a limit as t->0. The main ingredient is showing that the image of p must contain all of the points in O.
I am trying to think this way.Let a be any point of A. Let B be a basic neighborhood of a. We show there exists x in p([0,k])intersection B. By drawing I can see that if I can show p(k) is in A, then it works but how can I write it analytically?
Suppose B has radius e>0. Pick a smaller e0>0 such that there is one full cycle of sin(1/t) (i.e. the value passes through -1 and 1) between t=e0 and t=e. Like e0=1/((1/e)+2pi). Though you don't have to be that detailed. There are an infinite number of sine cycles less than any e>0. The curve must intersect B since the x coordinate of a is 0 and the y coordinate of a is between -1 and 1.
