Topology question; examples of non-homeomorphic metric spaces
  • Thread starter Thread starter notmuch
    Metric Topology
The discussion centers on identifying non-homeomorphic metric spaces X and Y, along with continuous bijective maps f: X->Y and g: Y->X. Participants suggest using the real numbers with the usual topology for X and the discrete topology for Y, but they encounter challenges in proving that the functions are continuous bijections. A successful example is proposed with X = [0,1) and Y as the unit circle, demonstrating that the mapping does not yield a homeomorphism. The conversation highlights the necessity of understanding the properties of compactness and Hausdorff spaces in relation to continuity and homeomorphism.
  • Understanding of metric spaces and their properties
  • Familiarity with the concepts of continuity and bijections
  • Knowledge of compact and Hausdorff spaces
  • Basic understanding of topological definitions and theorems
  • Research the properties of non-compact metric spaces
  • Study the implications of the Hausdorff condition on homeomorphisms
  • Explore examples of continuous bijections that are not homeomorphisms
  • Learn about the role of topology in defining continuity and homeomorphism
Mathematicians, topology students, and anyone interested in advanced concepts of metric spaces and their properties.
notmuch
Hello,
Here's a problem that I'm having trouble with:
Give an example of metric spaces X and Y and continuous maps f: X->Y and g: Y->X such that f and g are both bijective but X and Y are not homeomorphic.
I can find plenty of examples where I can find one such function, but finding the second is always a problem.
Let X be the real numbers with the "usual" topology: d(x,y)= |x-y|.
Let Y be the real numbers with the "discrete" topology: d(x,y)= 0 if x= y, 1 otherwise.
Let f(x)= x.
HallsofIvy,
Thanks for the reply, but that won't work with this definition of continuity:
f:A->B is continuous if
f^(-1)(U) is open in A for every open set U of B.
I suggest you re-examine the definition of homeomorphic. Given any space X and two topologies S and T, (X,S) and (X,T) are never homeomorphic.
Matt,
I understand that. I was not refuting the fact that those two topoligies are not homeomorphic. Finding such examples of non-homeomorphic spaces is easy, but finding the functions satisfying the conditions is the hard part.
You can form a topology on R from the basis of half open intervals whose endpoints are integers. Can you think of anything to do with this? EDIT: I don't know if this will work- in the example I had in mind it turns out the spaces are homeomorphic.
notmuch said:
Matt,
Did you stop to think about which topology we take as that on the domain and the range? The map f(x)=x is a bijection from R to R, with obvious bijective inverse. Give one copy of R the norm topology, the other the discrete. Done.
If you've found one bijective function, then it is invertible, as a function. That is either the definition of bijective, or a trivial consequence of the definition of bijective.
I don't think HallsofIvy's example will work. For every y in Y, {y} is open. For any bijection from X to Y, the inverse image of {y} is a one-point set, which is not open in X, so there are no continuous bijections from X to Y.
Ah, see the question properly now.
Remember that any continuous bijection from a compact space to a hausdorff space is a homeomorphism (or perhaps I mean from a hausdorff space to a compact space), thus one will need to find and use a non-hausdorff space, or a non-compact space.
Matt,
Sorry for the confusion. I was a little confused by your response so I didn't reply, I was trying to see if I was understanding you correctly. AKG expressed what I meant to say.
You're right about the Hausdorff/compactness conditions... we are stuck with finding both X and Y being noncompact spaces, since they must also be metric spaces (thus Hausdorff). I still have problems finding such an example.
Let X = [0,1) with the normal metric on R
Let Y be the uinit square, ie: Y = \{(x_1,x_2): x_1^2 + x_2^2 = 1\}, with the normal metric on R^2
Let f:X \rightarrow Y, \ \ \ \theta \mapsto (cos2 \pi \theta, sin2 \pi \theta).
Take U = [0, 1/2). U is open in X but f(U) is not open in Y.
nocturnal, do you understand the stated problem? You've found a continuous bijection from X to Y and shown that it isn't a homeomorphism. This is almost entirely pointless. You don't need to show that one particular continuous bijection from X to Y isn't a homeomorphism, you have to show that no continuous bijection from X to Y is a homeomorphism. Although you haven't done this, it can be done. More importantly, you have to find a continuous bijection from Y to X as well. This cannot be done.
oops, I misread the question.
do you really think that problem is true,
I thnk it is wrong, it is a different defination of homemorphizm
  • · Replies 43 ·
