Torque and Angular acceleration
The discussion focuses on calculating torque and angular acceleration in the context of a physics coursework project investigating the torque effect on single propeller planes. The user is attempting to measure torque using a mock-up setup that includes a propeller, tachometer, and scales to measure the induced force on the wings. There is confusion regarding the definition of torque and its relationship to the forces acting on the plane, with participants clarifying that the torque generated by the propeller does not create a turning effect on the plane due to the symmetrical setup. Suggestions include using a torsion balance for more accurate measurements, as the current method may not effectively capture the torque dynamics involved. Understanding the relationship between angular frequency and acceleration is also a key point of inquiry in the discussion.
egroeg93
Hi all, first time posting so let's see how it goes!
My problems are with a piece of physics coursework I'm doing for my A-level courses. I chose to investigate the 'torque effect' on single propeller planes. (If you are unsure of what this is, its basically Newtons third law, reasoning that when a plane makes a propeller spin, the propeller makes the plane spin).
So i need a way to calculate torque so i can compare it to forces produced on the plane. The setup i used for the experiment is show in the picture:
[PLAIN]http://img827.imageshack.us/img827/1451/physicsforum1.png
Basically, its a suspended mock up of a plane, with a propeller on the front. I'm using a tachometer to measure rpm and scales to measure the 'weight' induced on the wing, which i could convert into a moment.
How can i find the torque of the propeller from this? I've spent ages trawling the internet. The variables i know are: rpm, length and mass of propeller. I also changed the distance alone the 'wings' of the mockup which i measured the force from, using the scales to measure the 'force' the torque effect applied on them.
So what i understand, is:
ω = 2*(pi)*f
a_tangential = Angular acceleration*R
τ = I*α
But how do i link angular frequency with angular acceleration. How could i do this? Could i just use the ideas in the picture and trigonometry?
[URL]http://upload.wikimedia.org/wikipedia/commons/5/56/Acceleration.JPG[/URL]
Many thanks to all!
welcome to pf!
hi egroeg93! welcome to pf! :smile:
egroeg93 said:
… How can i find the torque of the propeller from this? I've spent ages trawling the internet. The variables i know are: rpm, length and mass of propeller. I also changed the distance alone the 'wings' of the mockup which i measured the force from, using the scales to measure the 'force' the torque effect applied on them. …
i think you're misunderstanding both the word "torque" and the way the propellor is connected to the rest of the plane
"torque" can mean a couple (a pair of equal and opposite forces, not in-line), or it can mean the moment of a force
the torque of a propellor is the first type, but your distance x force calculation is the second type
each propellor exerts both a forward horizontal force on the wing, and a couple (a torque) on the propellor shaft
the moments (torques) of the forward horizontal forces of the two propellors (assuming the plane is symmetrical!) cancel out, so those forces don't turn the plane
the propellor shaft isn't connected to the wing or the body, it's connected to the engine … i don't know where that is or how it works, but i assume that either there's something in the engine that "absorbs the recoil", or that there is a torque, but its turning effect is very small since the moment of inertia of the plane is very large, and that that's catered for by a very slight adjustment to the rudder or to the plane's geometry
anyway, i think you'll need an apparatus that incorporates a torsion balance rather than the usual linear one :smile:
i was told i could calculate a torque force by my teacher :P
Its modeled on a single propeller plane, so there is no cancelation of forces.
This is a real scenario, and I'm just trying to experiment with it :)
If there's a single propeller, it's presumably in line with the centre of mass of the plane, so again there should be no moment (torque) about the centre of mass.
I think either you're misunderstanding your teacher's answer, or (s)he's misunderstanding your question.
  • · Replies 30 ·
  • · Replies 22 ·
  • · Replies 33 ·
