Torque Requirement for 25mm dia Shaft 600mm Length w/ Gear
  • Thread starter Thread starter Analysis
    Torque
The discussion centers on calculating the torque requirement for a 25mm diameter, 600mm length shaft with a gear attached, driven by an external load applied via a lever arm. The user, Prakash, seeks clarification on the correct approach to determine the required torque, considering factors such as friction coefficients and reaction forces at the bearings. Key points include using a friction coefficient of 0.0025 for bearings and a coefficient of 0.3 for the materials in contact. Prakash also inquires about the relationship between running torque and starting torque for motor selection, suggesting a multiplier of 1.5 for the starting torque.
  • Understanding of torque calculations in mechanical systems
  • Familiarity with friction coefficients and their impact on torque
  • Knowledge of gear mechanics and their influence on shaft torque
  • Basic principles of motor selection based on torque requirements
  • Research "Calculating torque for rotating shafts" to understand the fundamentals
  • Study "Friction coefficients in mechanical systems" for better insights on material interactions
  • Explore "Gear design and its impact on torque transmission" for practical applications
  • Learn about "Induction motor and servo drive motor specifications" for effective motor selection
Mechanical engineers, design engineers, and anyone involved in the design and analysis of rotating machinery and torque calculations.
Analysis
Dear all,
I need clarification regarding torque requirement in the following arrangement.
Imagine a shaft 25mm diameter 600mm length simply supported and one end
gear is attached to drive the shaft.
Load is externally applied via lever arm and different material(polymer) same
diameter is in contact.
My query is what is the torque required to drive this shaft arrangement.
Load,shaft geometries,speed are the known values.
My approach is assumed that at static condition load is applied over shaft, finding
the reaction force at each bearing end and from this force multiplied by bearing
mean radius with co efficient of friction of bearing which is normally(0.0025max).
Is the approach is correct?
1)My suspect is when applying force to the bearing, friction coefficient will
increase how to change of friction is accommodated?
2)Rollers in contact with pressure to overcome frictional resistance will be less
only i.e. shaft in contact assume that 100 N is acting,to overcome this force we
will multiply with friction coefficient of two materials say 0.3 and the calculation is
100 x 0.30=30N is enough to overcome the force of 100 N
3)To find reaction force at the ends can i use of 30N instead of 100N?
4)Suppose reaction force will changes in each end,say one end is 50 N and
another end is 35N can i take higher value?
5)Above is that running torque what will the empirically starting torque to select
induction motor or servo drive motor specification.can i take say 1.5 times
running torque for both? Can i use T=IxAlpha approach?
6)In this gear is going to drive the shaft gear PCD has any influences?bcoz gear
radius is used to drive the shaft torque?
Thanks in advance
Prakash
(Since image is not uploading i am narrating the problem)
Hello, Prakash. You continue to try to get someone else to do your work, don't you? I have to say, I am amazed at your persistence!
Dearsirs,
Sorry in the case of wrong ,whatever my clarifications /doubts only posting i am not the person getting my work done thro others.Also my posts are narrating the approaches of my work and seeking others comments that's all.This is to enhance my theoretical knowledge.From ur point of view what are the questions can we post?
From the above In the torque requirement querey my suspect is while rotating we can easily overcome the load applied by top roller,comparitevely taking total load used to finding reactions from that am calculating the torque...?
Thanks for ur comment
Prakash
  • · Replies 19 ·
  • · Replies 18 ·
