Is torque or horsepower more important in auto racing
109 replies · 197K views · last reply
Yes, I do agree that some people get heated over the topic. HP does sell cars from a marketing standpoint though. Similar to selling heads and bigger CFM numbers. But without a twisting force, torque, we can not generate power in a piston engine. We can have all the math in the world, but it still boils down to the crankshaft rotation in relation to combustion quality in a piston engine to get work done.
What I meant was if a manifold change would increase the torque throughout the rpm range and HP stayed the same throughout the rpm range, how would the vehicle operate in action? If low-end torque prevails coming out of the corners on an oval track, then torque itself is has a place, maybe at lower rpms but it isn't exactly useless from my perspective.
I am curious on your views as well Chris.
The way I read what you are saying is that the torque curve alters (same shape but a shift up in torque output throughout the range), but the power curve stays the same. Which is a situation that you just can't get, if you increase torque across the range power output must increase.
My view is it's pointless making the distinction between torque and power as they are both intrinsically linked, that it makes it a bit silly to make the distincition as to which is 'important'. You can't say one is more important as they are both equal in relevence and indeed directly affect one another, except in very very specific scenarios.
True, nothing is in fact, fixed. But does not mean its an absolute impossiblity. Would you happen to have any good article links off the top of your head I could read on this simple but entertaining subject?
It acutally does mean it's imposible. The power - torque relationship defines this.
http://en.wikipedia.org/wiki/Torque
P = T*w*2pi/60000 in SI units.
So say you had 100Nm @ 3000rpm
P=100*3000*2*pi/60000 = 31.41 kW
Now let's say we shift the whole torque curve up 20% (as you said) by adding some boost. So now we have 120Nm @3000rpm
P=120*3000*2*pi/60000 = 37.7 kW.
As you can see 120/100 = 1.2
37.7/31.41 = 1.2.
If you increase the torque at an RPM value the power output is altered by the same ratio.EDIT: You can read stuff like this on wiki. I don't have any articles to hand, but I am sure there was something in one of my old Racecar engineering magazines.
Fahlin Racing said:
If the torque curve rises from a manifold change & horsepower (or vice versa) does not on the engine dyno or chassis dyno, what is your view on how the car or truck might be different during operation?
Just like Chris said, at a particular RPM, you cannot increase the torque without increasing the power.
And if you mean:"What are your thoughts about raising the peak torque and decreasing the peak horsepower?" I would answer that this can be good or bad depending on what you do with the engine. By doing so, you have increased the low-end power[1] and lose some high-end power. If you usually use the engine in the low-end range (say a street car in city traffic) you may find your car more responsive. If you usually use the engine in the high-end range (like a race car), you working against your best interest in any case.
Fahlin Racing said:
but, you will need cylinder pressures to generate torsional rotation to begin & proceed with getting work done the quickest, equating to HP being the most concerned when accelerating and keeping vehicle momentum going.
Nope, as shocking as it may sound, you don't need torque to get power. Power is proportional to magnitude of the cylinder pressure (or torque) and the frequency at which it comes back (the RPM). A small force that comes back often is just as powerful as a big force that comes back once in a while.
For example, 400 lb.ft @ 2000 rpm produces the same power than 200 lb.ft @ 4000 rpm (152 hp in both cases). You will see absolutely no difference on the car's performance, assuming the car is at the same speed at those RPMs. If we look at the low-end power and, say, with the first engine, @1000 rpm (half-speed) you get 360 lb.ft (69 hp) and for the second one, you get 100 lb.ft @ 2000 rpm (38 hp), you will find the first one more powerful because your AVERAGE power throughout the RPM range is higher. But if you use the low-end rarely, you won't notice the difference between the 2 engines. It is all a matter of what you do with the engine. That is why peak power is a rather meaningless number, unless you are there all the time.
[1] Note that I do not use the usual expression 'low-end torque' even if it is true as well. But raising 'high-end power' also increases 'high-end torque'. Again, performance wise, torque is irrelevant, only power is of interest.
Despite the saying (or perhaps because of it), it seems to me that torque is what sells cars, especially in America. They chilled out with it lately, but for a long time it was the trend to shoehorn as big an engine as possible into every car, with no regard for the horsepower output. I still tell stories here in my country about how my first (and only) American car had an engine 2 times bigger than some Euro econo car they are driving...and it still managed to have less power. It did have a kick from it's massive torque. Just one, quick kick...and then it fell flat on its face.
Anyway, torque is a good thing, but they point of a car engine is power. As long as you have power, you can engineer your way out of even the crappiest torque curve. Might not be pretty, and might not be comfortable, but it's possible to make it go.
However, even if you have a million torques (of whatever unit you want), if you don't have the power to back it up that thing is not going get anywhere in a reasonable time, even if God himself designed the rest of the drive train.
Here is how I came to realize to some extent how things relate to each other,...
In my younger days, Don Garlits broke 200mph with a 392 CI hemi that made about 1250HP @ 8,000 or more RPM.
Around that same time we built a push boat that had two 1250 HP Caterpillar engines that turned about 400 RPM, these required a quite large crane to set them in the boat.
When the understanding really started to become clear was when I realized why the two engines could not work in the different enviornments, (speed, weight and time duration).
I think in those early days dragster engines lasted two or three runs before rebuilding or replacing, nowdays I think each run uses an engine to it's max.
Our boat engines, if on an oil tow job, would run nonstop for up to a year or more stopping them only for oil changes or if they started showing low oil pressure it would require a lower bearing changeout. Almost always one engine running while the other was being serviced. Fog and sometime wind would put the boat against the bank.
If you look through power transfer catalogs and study speed and horsepower ratings, you will start to see a pattern of shaft sizes and unit weight, these can be good indicators of the difference between HP and Torque.
This works pretty well for me without too much number crunching, maybe it will help someone else.
Ranger Mike said:
RonL
good to know there is another gear head here...
nice to meet you
rm
Thanks Mike,
I was able to attend the Spring Nationals in Baytown Tx two years ago and found out just how far out of touch I was:eek: My first event in over 20 years, I was not prepared mentally for the sounds or the speeds, last time I had looked they were struggling for 250 MPH now they were around 330.
To add insult to injury, I made the mistake of asking a few very savy younger fans around me if they knew anything about Leonard Hughes (response was never heard of him):frown:
Then lo and behold there pops up Joe Tueton running in class (don't remember what) I did not have time to see him in the pits afterwards, I did not know him well, but he might have been able to give me a few updates about people from the Houma area.
It was a great day for an old geezer with locked gears:biggrin:
Thanks Chris & jack. I appreciate the help with the physics here. I am new to the world. I will continue to read this thread when I can to learn more.
The value of torque versus the value of horsepower in vehicle performance has been and will be debated forever.
When we list torque and hp we usually list maximums and the rpm at which they occur. These values help to cloud the issue because someone has an engine with higher peak torque and hp than another but in identical cars the one with the lower peaks wins races. A higher average torque and hp can easily win against an engine with higher peak values.
Torque is necessary to produce hp - that has been said if not so plainly.
Peak torque is produced at an engine speed where the cylinder is most efficient at moving air in and out and cylinder pressures are the highest.
Horsepower is a direct result of the amount of torque produced and provides movement for the vehicle.
Which is more important depends a great deal on the vehicle and its purpose.
A drag racer that uses a light car with a huge engine burning nitro-methane has one purpose - acceleration. It needs rpm to get to a top speed that is competitive and has to survive 1/4 mile at a time.
A slolom car that has to accelerate out of tight corners and achieve speeds of over 150 mph on the rare straights needs a flatter torque curve and rpm to get to those speeds while surviving for 500 miles.
A daily driver - "grocery getter" - needs to operate well at rpm less than half that of the slolom car and perhaps a third the rpm of the drag racer and continue to run for 100000 miles or more.
The car is an operational system that has to be engineered and built for a given purpose. Asking which is more important referring to a single component in that system makes no sense without including its use and the rest of the components that are wrapped around the engine.
Ranger Mike said:
RonL
was that Len Hughes of Candy and Hughes rail fame?
Yes that's correct. (Candies and Hughes)
http://www.ottocandies.com/current_projects.html
Here's a link to his sponsor in those early days, he had a little single bay repair shop on the side of Terrebonne Bayou which ran through Houma, he would push that first funny car outside while he worked on cars for some of his customers.
Before the funny car he ran the sweetest little chevy, I think it was B stock.
I think I might be able to end the debate. It keeps going back and forth. Folks are using and changing terms, perspectives, vantage points, and it all gets pretty confusing.
I mentioned in another related thread, when I was asking this physics group, of what really came first, the HP or the torque. It got a little off track and then I think we all came to an agreement.
I started that thread out by specifically stating that power dictated torque at the rear wheels. Sure, you could figure it out in reverse as well, but generally, there is this argument of what is more important, engine torque or engine HP? Also, the misconception that torque gets you out of the turns and HP down the straight, (as well as hp sells cars, torque wins races) .
Basic physics 101 guys. acceleration = power/(mass x velocity)
This says acceleration is directly proportional to power and inversely proportional to speed.
He who has the most power at any given vehicle speed, will have the greatest acceleration at that speed (regardless if its out of the turn, corner, or down the straight), and therefor, the greatest torque at the driven wheels. No one can debate this. So, most all the talk then becomes relating to the shape of the HP curve over the operational range. (i.e. between all the gears). he who uses the most HP-seconds, will win the race in a straight line. (ignoring the drag racing factors and all other variables kept the same). this is the reason for close ratio gear boxes, and big beefy v8 and v10s with flat HP curves.
What I thought was a more philosophical debate, ended up being not really answered in the previous thread. The though was that it all started with power. doesn't the potential energy of the gas start the process? it rapidly expands as it combusts and pushes down on the piston, that heat energy is converted to mechanical energy (ie force). To the discussion, that can be applied to little tiny pistons that spin a small crank REAL fast. (like a porsche GT3RS engine with 500rwhp, spinning 9000 rpm) or a Viper with an engine making the same 500hp but with the engine spinning only around 6000rpm). Flat torque curve for the porsche, but peaky HP curve, vs the flat HP curve of the viper. who wins? depending on the shapes of the curves and the closeness of gears used, sometimes the viper, sometimes the porsche. But, both at ANY vehicle speed, if they are making 500rwhp, will produce the same rear wheel torque, (not engine torque, measured at the rear wheels) as would be measured at the wheels, after the gear reductions.
So, the bottomline is you want a powerplant that maximizes your HP-seconds. it can be done with big engine torque or small engine torque. if you are comparing two like engines, then you want the one that has more lower end torque, because it will have a flatter HP curve and produce more HP-seconds over the useable range.
My main question to the field here, is what other terms or equations can you use to approximate the time element in a HP curve. from a laymans perspective, you will be accelerating over a longer period of time as you run toward the top of the rpm range of an engine, that's why i though HP-seconds was a applicable term. what do the physics guys think or suggest to incorporate this time element into comparisons. area under the HP curve doesn't work completely for that reason.
Thoughts?
Yep, and God would use a IVT(Infinitely variable transmission) then, it wouldn't matter what the torque of the engine was, only the HP. :)
Thoughts?
This is exactly my answer in https://www.physicsforums.com/showpost.php?p=2823175&postcount=88".
As for comparing 2 engines, you must begin by defining what is your useable RPM range. Here is an example with 2 power curves from fictitious engines:
Two line graphs of engine horsepower: top plots HP against RPM from 0 to 10000, bottom plots HP against RPM as a percentage of RPM max; a red and a blue curve each rise, peak near 500 HP, then fall.
When comparing the 2 power curves based on the ratio RPM / RPM max, one would be tempted to say that the red curve is better than the blue curve. But that is only true if you go in the RPM range below 60%. If you can keep the RPM range above that (for example a race car on a track with no sharp turn), then both engines will produce exactly the same performance (though, with different gear ratios).
The important number is the AVERAGE power throughout the useable RPM range. And that last one depends greatly on what the engine is used for.
zanick said:
Thoughts?
My thoughts are you've just repeated the roundabout of 'arguments' that's been happening for 7 pages. The entire debate is pointless, torque and horsepower are both intrinsically linked making this vs debate a waste of time.
As you say for any given vehichle speed max acceleration occurs at peak power. But in a specific gear max acceleration occurs at maximum torque.
This could be avoided by using a CVT (constantly variable transmission) which could keep engine rpms at peak power regardless of vehicle speed.
Chris, I know that you understand correctly the physics of it, but this is the statement that doesn't make this debate pointless or a waste of time. That statement, even though it is true, leads to the conclusion that if a driver keeps his engine's RPM around maximum torque in any given gear, he will get maximum acceleration for the vehicle. And that is not true (except for the 1st gear, since you cannot downshift further).
So in the debate Torque vs Horsepower, there is one clear winner and it is Horsepower. This doesn't depend on a "feeling", a driving technique or an old wife's tail: It is pure science and undisputable. That's what must come out of this debate.
In this quote:
xxChrisxx said:
As you say for any given vehichle speed max acceleration occurs at peak power. But ...
There shouldn't be a 'but'.
