Why Is the Force for T1 Doubled in the Torsional Deflection Problem?
The force for T1 in the torsional deflection problem is established as 4000 in-lb. The 3-inch section of the beam is responsible for resisting both loads, while the 2-inch section only resists the outer load. This distinction in load distribution clarifies why the force for T1 appears to be doubled in the analysis of the problem.
  • Understanding of torsional deflection in beams
  • Familiarity with load distribution concepts
  • Knowledge of beam section properties
  • Basic principles of mechanics of materials
  • Study the principles of torsional deflection in structural engineering
  • Learn about load distribution in composite beams
  • Explore beam section properties and their impact on load resistance
  • Review mechanics of materials focusing on shear and torsion
Mechanical engineers, structural engineers, and students studying mechanics of materials who are analyzing torsional deflection problems.
grunt58
I am confused as to why the force for T1 in the attached problem is doubled.
T1 = 4000 in-lb
The 3 inch section is resisting both loads.
The 2 inch section is resisting the outer load only.
Ahhh ok thank you.
