Calculating Distance Covered by a Particle Using Displacement Vector
The discussion focuses on calculating the distance covered by a particle using its displacement vector, defined as ##\vec S = (5t - t^2) \hat c##, where ##\hat c## is a constant unit vector. Participants clarify that while determining the force vector and work done is straightforward through differentiation, calculating the total distance requires investigating the arc length of the displacement curve. Key insights include the need to differentiate the displacement function to find maximum displacement and the importance of integrating to find total distance covered over a specified time interval.
  • Understanding of vector calculus and differentiation
  • Familiarity with Newton's second law (F=ma)
  • Knowledge of work-energy principles in physics
  • Basic concepts of arc length in one-dimensional motion
  • Learn how to calculate arc length for a given displacement function
  • Study integration techniques to find total distance covered over time
  • Explore the relationship between displacement, velocity, and acceleration
  • Investigate the application of work-energy principles in particle motion
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking to enhance their understanding of particle motion and displacement analysis.
Nader AbdlGhani
The displacement vector of a particle of mass 50 gm. is given as a function in time (t) by the relation ##\vec S##=(5t-t2) ##\hat c## where ##\hat c## is a constant unit vector , s is measured in centimetre and t in second .Knowing that the particle started its motion at t=0
Find :
(1) The force vector acting on the particle and the work done by this force during the first five seconds of motion.
(2) The total distance covered during the first three seconds of motion.
##w=\vec F \cdot \vec S##
##F=ma##
The requirement number (1) is quite easy by differentiating vector s with respect to time 2 times we get the acceleration vector and we already have the mass , so we can get the force easily, but the problem is in getting the total distance covered , in my best attempt , I could only get the maximum displacement by differentiating vector s with respect to time and equal it with zero we will get 5-2t=0 so displacement is maximum when t=2.5 seconds , what should I do next ?
Hi Nadar:
What is the displacement at t=0?
What is the displacement at t=3?
How far did it move between t=0 and t=3?
Hope this helps.
Regards,
Buzz
I think you want to investigate the arc length of a curve. The curve in this case is one dimensional (lies along a straight line), can you think of a way to sum up the distance over time?
Buzz Bloom said:
Hi Nadar:
Hope this helps.
Regards,
Buzz
Thanks , The problem is with the distance not the displacement .
Nope .
  • · Replies 38 ·
  • · Replies 29 ·
  • · Replies 31 ·
