What is the total energy required to heat the material to 80 degrees?
The total energy required to heat a material to 80 degrees Celsius is calculated using the function f(T) = 1.28T, while the effect applied to the system is represented by g(T) = 378 - 3.16T. The time required to heat the material is derived from the relationship between these functions, leading to the equation h(T) = 153.1 / (378 - 3.16T). This analysis utilizes differentiation and integration techniques to determine the heating time as a function of temperature.
  • Understanding of thermodynamics and heat transfer principles
  • Proficiency in calculus, specifically differentiation and integration
  • Familiarity with mathematical functions and their applications
  • Experience using computational tools like WolframAlpha for mathematical analysis
  • Research the principles of thermodynamics related to heating systems
  • Learn advanced calculus techniques for solving differential equations
  • Explore the use of WolframAlpha for complex mathematical computations
  • Investigate practical applications of heating calculations in engineering
Engineers, physicists, and students in thermodynamics or applied mathematics who are interested in calculating energy requirements and heating times for materials.
Dafe
Hi,
a question at work popped up and it's been too long since I went to school :p
The total energy [Wh] required to heat the system to temperature T is given by f(T)=1.28T. The effect [W] applied to the system is given by g(T)=378-3.16T. How long does it take to heat the material to say 80 degrees?
Hope someone can help me out, thanks.
Here's my try. I'm using wolframalpha for the differentiation and integration...
<br /> \frac{dh}{dT}=\frac{d}{dT}\left(\frac{f(T)}{g(T)}\right)<br />
=\frac{d}{dT}\left(\frac{1.28T}{378-3.16T}\right)
=\frac{4.04T}{(378-3.16T)^2}+\frac{1.28}{378-3.16T}
So now I have the change in time required to heat up the material as a function of temperature. I integrate to get the time required:
h(T)=\frac{153.1}{378-3.16T}
Meh, at least it's an attempt :p
