Total energy when potential graph is given
The discussion revolves around determining total energy in a system where only a position vs time graph is provided, with an emphasis on potential energy in the context of simple harmonic motion (SHM).
  • Participants discuss the relationship between potential and kinetic energy in SHM, noting that at the crest of the wave, potential energy is maximized while kinetic energy is zero. There is uncertainty about how to proceed without additional information such as mass or a potential energy graph.
Some participants have provided insights regarding the characteristics of SHM and the need for mass to calculate energy. There is a recognition of missing information, particularly the potential graph and mass, which are critical for further analysis.
Participants note that the problem lacks necessary details such as mass and the spring constant, which complicates the analysis of energy in the system. The original poster acknowledges a miscommunication regarding the provided graph.
nhmllr
Total energy when positions vs time graph is given
(answer: -5J)
energy initial = energy final
At the crest of each wave, the particle has only potential energy, and at the middle of each wave the particle has only kinetic energy, and these values are equal. By looking at the slope when the graph crosses the horizontal axis, you can determine that it travels at 5m/s then. After this point, I do not know how to continue.
Disregard.
You said the potential graph is given. Where is it?
ehild
ehild
I'm sorry, I mis-titled the post originally. The potential graph is not given, only the position vs time graph is given
The motion looks SHM. But you need the mass of the particle.
ehild
ehild
I gave the entire problem. No mass was given, and nothing analogous to the spring constant was given. However, I think you can find the ratio of the two, as the period = 2π * sqrt(m/k) = 8. I don't see how that helps, though
You also know the amplitude, A=5 m. The energy of the SHM is 1/2 kA2. You need the mass.
You also need the zero point of potential energy. If it is SHM, the potential energy is zero at zero position, and it is never negative. Something is very wrong with the problem.
ehild
14K
18K
