Trace, determinant, and eigenvalues 3x3
To compute eigenvalues of a 3x3 matrix using trace and determinant, it is noted that the approach differs from the simpler 2x2 case. The determinant being zero indicates that one eigenvalue must also be zero, but this does not uniquely determine the other eigenvalues. The discussion highlights that multiple matrices can share the same trace and determinant yet have different eigenvalues, complicating the process. It is emphasized that one must refer back to the specific matrix to accurately find the eigenvalues. The consensus is that while trace and determinant provide some information, they are insufficient alone for determining eigenvalues in larger matrices.
Dustinsfl
Use the trace and determinant to compute eigenvalues.
I know how to do this with a 2x2 but not sure how to do it with a matrix of nxn where n>2.
\begin{bmatrix}<br /> \frac{1}{2} &amp; \frac{1}{3} &amp; \frac{1}{5}\\ <br /> \frac{1}{4} &amp; \frac{1}{3} &amp; \frac{2}{5}\\ <br /> \frac{1}{4} &amp; \frac{1}{3} &amp; \frac{2}{5}<br /> \end{bmatrix} the det=0 and the trace=\frac{37}{30}
I don't think it's possible for n>2 cases, you can probably work out infinite number of matrices with the same trace & det, but with different eigenvalues
You can't use only the determinant and trace to find the eigenvalues of a 3x3 matrix the way you can with a 2x2 matrix. For example, suppose that det(A) = 0 and tr(A) = t. Then any matrix of the form:
<br /> \begin{bmatrix}<br /> a &amp; 0 &amp; 0\\ <br /> 0 &amp; t-a &amp; 0\\ <br /> 0 &amp; 0 &amp; 0\\ <br /> \end{bmatrix}<br />
has trace = t and determinant 0 with eigenvalues a and t-a. So you'll have to go back to the matrix to find the eigenvalues.
According to the book it can be done with this matrix.
Epiphany: since the determinant is 0, one of the eigenvalues has to be 0.
Now if we could just divide the determinant of the matrix by zero and get back \lambda_1 \lambda_2!
Then I got no clue, sorry.
  • · Replies 19 ·
