songoku
- 2,522
- 395
- Homework Statement
- Large flat circular coil connected to a sinusoidal alternating voltage supply and a small flat circular coil placed at the centre of the large coil such that the planes of the two coils are coincident. The smaller coil is connected to a cathode – ray oscilloscope (c.r.o). State and explain how the trace on the screen of the c.r.o. would be affected if the small coil is rotated such that the angle between the planes of the two coils increases from zero to 90 degrees whilst maintaining a constant root mean square current in the large coil
- Relevant Equations
- Faraday's Law
My answer is when the small coil is rotated, there will be change in magnetic flux in it. Initially (before rotated), the trace in c.r.o will be sinusoidal. After it is rotated, the trace will still be a sinusoidal (but I am not sure whether the amplitude will be the same).
But the answer key is: the trace will go down to zero since when the angle is 90 degrees no field lines passing through the area of small coil so the magnetic flux is zero.
I don't understand why the trace will go down to zero.
Thanks
