Transformation of the metric tensor from polar to cartesian coords
The discussion focuses on the transformation of the metric tensor from Cartesian coordinates to polar coordinates and back. The user successfully derived the polar metric as [1 0; 0 r^2] but encountered issues when attempting to revert to the original Cartesian metric [1 0; 0 1]. The confusion arose from the misapplication of the transformation equations and partial derivatives. Ultimately, the correct approach confirmed that the Cartesian metric can indeed be recovered using the relationship between r and the Cartesian coordinates.
  • Understanding of metric tensors in differential geometry
  • Familiarity with coordinate transformations, specifically between polar and Cartesian coordinates
  • Knowledge of partial derivatives and their application in tensor calculus
  • Basic proficiency in LaTeX for formatting mathematical expressions
  • Study the derivation of metric tensors in different coordinate systems
  • Learn about the implications of coordinate transformations in general relativity
  • Explore the use of LaTeX for typesetting mathematical documents
  • Investigate common pitfalls in tensor calculus and coordinate transformations
This discussion is beneficial for students and professionals in physics and engineering, particularly those studying general relativity or working with differential geometry and tensor calculus.
mokrunka
I'm working on a problem that requires me to take the cartesian metric in 2D [1 0;0 1] and convert (using the transformation equations b/w polar and cartesian coords) it to the polar metric. I have done this without issue using the partial derivatives of the transformation equations and have come up with the metric in polar coordinates [1 0;0 r^2].
Just for grins, I decided to use the partial derivatives and convert back to cartesian using the polar metric, expecting to come up with the exact same thing I started with, namely [1 0;0 1]. Unfortunately, that is not what happened. Shouldn't this work? Can anyone help me in where my thought process is wrong here?
Note, this is not a HW question; I am a degreed engineer teaching myself relativity from a workbook.
It should work, yes, but you will need to post more details before we can give any feedback on where you might have gone wrong.
For example, in the attached word file, I've given the equation to convert the metric from primed (r, theta) to unprimed (x, y) coordinates. I have also listed the partial derivatives I've used.
In this file, you can see gxx will not (unless my math is failing me) give 1, which would be the gxx component of the cartesian metric in 2D.
Yes, it does. You have:
g_{xx} = \left( \frac{\partial r}{\partial x} \right)^2 g_{rr} + \left( \frac{\partial \theta}{\partial x} \right)^2 g_{\theta \theta}
We have (rewriting your equations slightly to make the math easier to see) ##\partial r / \partial x = x / r## and ##\partial \theta / \partial x = - y / r^2##, and the metric coefficients are ##g_{rr} = 1## and ##g_{\theta \theta} = r^2## (the latter may be where you went wrong in your math). Plugging everything in gives
g_{xx} = \frac{x^2}{r^2} + \frac{y^2}{r^4} r^2 = \frac{x^2 + y^2}{r^2} = 1
Ahhh, I failed to see that I could use r and (x^2+y^2)^.5 interchangeably. Thank you very much for this clarification!
As a side note, how are you able to type the equations directly into the post?
Edit: nevermind, I've just discovered Latex.
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 47 ·
  • · Replies 19 ·
