Transforming a uniform distribution into a binomial
12 replies · 6K views · last reply
bennyska
Let X~UNIF(0,1). Find y = G(u) such that Y = G(U)~BIN(3,1/2)
after a bit of searching/reading, i found how to do this with a continuous distribution (the problem i had was an exponential, so i took the inverse)... however, more searching has not led to any results for the discrete case, which i need for the binomial. any pointers would be definitely appreciated.
X is continuous whereas Y is not. This implies that G(X) isn't be continuous. Does that help?
no... how about one more hint?
Start by figuring out the cdf for Y.
well, for a binomial, with these parameters, the cdf would be .[tex].5^{3}\sum_{i=0}^{3}\left({3\atop i}\right)[/tex]
That expression is not the cdf. That's equal to 1. Try again.
[tex]F_{x}=Pr(X\leq x)=.5^{3}\sum_{i=1}^{x}\left({x\atop i}\right) for<br /> x = 0, 1, 2, 3[\tex]<br /> <br /> not sure if this tex will show up, but here's the pdf<br /> <br /> (also, basically .5<sup>3</sup>*SUM(from i=0 to x) (x choose i) )[/tex]
Close enough. The lower limit of the summation should be i=0, but other than that it's correct. It's easy enough to just write FX(x) out explicitly.
[tex]F_X(x) = \left\{\begin{array}{cl} <br /> 0 & \textrm{if}~x < 0 \\<br /> 1/8 & \textrm{if}~~0 \le x \lt 1 \\<br /> 1/2 & \textrm{if}~~1 \le x \lt 2 \\<br /> 7/8 & \textrm{if}~~2 \le x \lt 3 \\<br /> 1 & \textrm{if}~~3 \le x <br /> \end{array}\right.[/tex]
Does this give you an idea of how you might write Y=G(X)?
That should have been FY(y), not FX(x).
[tex]G_{X}(y)=\begin{cases}<br /> 0 & 0\leq x<1/8\\<br /> 1 & 1/8\leq x<1/2\\<br /> 2 & 1/2\leq x<7/8\\<br /> 3 & 7/8\leq x\end{cases}[/tex]
