Translation from vector calc. notation to index notation
8 replies · 3K views · last reply
JonnyMaddox
Hi, I want to translate this equation
[itex]R_{\hat{n}}(\alpha)\vec{x}=\hat{n}(\hat{n}\cdot\vec{x})+\cos\left(\alpha\right)(\hat{n}\times\vec{x})\times\hat{n}+\sin\left(\alpha\right)(\hat{n}\times\vec{x})[/itex]
to index notation (forget about covariant and contravariant indices).
My attempt:
[itex]R_{ji}x_{i}=n_{j}n_{k}n_{k}-cos(\phi)\epsilon_{lmj} \epsilon_{noj} n_{l}x_{m}n_{j}+sin(\phi)\epsilon_{pqj} n_{p}x_{q}[/itex]
The minus sign comes from [itex]\hat{n} \times (\vec{x} \times \hat{n})= -(\hat{n} \times \vec{x}) \times \hat{n}[/itex]
So is this right??
If you are not going to have any upper indices, it would be appropriate to restore the implied summations since the Einstein summation convention does not apply for indices which are all lower.
Looking at your expression though, the indices don't seem to match up very well between the left and right sides...
Also, I think your attempt at a solution, even after you have fixed the errors, would only be valid in Cartesian coordinates. In other coordinate systems, the dot product and cross product does not have such a nice form...
Hello !
Ok you are right, but in the book I use, tensor calculus is introduces first in cartesian coordinates and they make no distinction between upper and lower indices but introduce the Einstein summation convention. Could you be a bit more explicit what went wrong? I think that this is wrong [itex] cos(\phi)\epsilon_{lmj} \epsilon_{noj} n_{l}x_{m}n_{j}[/itex], but I'm not sure what to do about the n and o indices. Maybe I should put them to the left side somehow. And I read in some pdf that they put an additional basis into the epsilon tensor expression like [itex]\vec{b} \times \vec{c}=\epsilon_{jkl}b_{j}c_{k}\hat{e}_{l}[/itex] But shouldn't the expression be free of any reference to a basis??
JonnyMaddox said:
Hello !
Stick with Cartesian coordinates for now, restore the summations, and let's see what expression you end up with.
To get you started, the first term in the OP should read something like $$(\hat{n}(\hat{n}\cdot\vec{x}))_j=n_j(\sum_k n_k x_k)$$
Ok that's clear I think. Now the second term should be, since it is just a vector [itex]x_{k}[/itex]:
[itex]x_{k}= cos(\phi)\epsilon_{kln} \epsilon_{mjn} n_{l}x_{m}n_{j}[/itex]
Now this is a contraction of the n indices and summation on the l,m and j indices. Now how should I incorporate that in my above equation? Something like this [itex][R_{ji}x_{i}]_{k}[/itex] ?? I have no idea why there is contraction of the n indices but ok...
Ah I see, it's just [itex]R_{ji}x_{i}=n_{j}n_{k}n_{k}-cos(\phi)\epsilon_{jln} \epsilon_{mon} n_{l}x_{m}n_{o}+sin(\phi)\epsilon_{pqj} n_{p}x_{q}[/itex] . If this is right I'll try to convert it into upper and lower indices with metric tensors.
In notation with lower and upper indices and in all dimensions and geometry it is I think:
[itex]R^{j}_{i}x^{i}=n^{j}g_{hf}n^{h}n^{f}-cos(\phi)\sqrt{|det (g)|}\epsilon^{jln} \epsilon_{mon} n_{l}x^{m}n^{o}+sin(\phi)\sqrt{|det (g)|}\epsilon^{j}_{pq} n^{p}x^{q}[/itex]
Your first term should have an ##x## in it rather than 3 ##n##'s. I'm not sure about raising and lowering indices on the Levi-civita symbol since that will bring in factors of the metric. I can't recall the exactly correct way to take a cross product in such a notation.
