Transmission Grating: Determining the Correct Order of Diffraction
The discussion centers on determining the correct order of diffraction using a transmission grating. The participants utilized the equation nλ = d sin θ, with specific values of 600 nm for wavelength and 100,000 lines per meter for the grating. The confusion arose from the relationship between the number of lines (N) and the order of diffraction (m), leading to the conclusion that the correct answer is C, as confirmed by the mark scheme. The participants clarified that while doubling N halves d, the angles do not necessarily double when transitioning from one order to another.
  • Understanding of the grating equation nλ = d sin θ
  • Knowledge of diffraction orders and their significance
  • Familiarity with wavelength measurements in nanometers
  • Basic trigonometry related to angles and sine functions
  • Study the implications of varying the number of lines per meter in transmission gratings
  • Learn about the impact of angle approximation in diffraction patterns
  • Explore the differences between first-order and second-order diffraction
  • Investigate practical applications of transmission gratings in optical devices
Students studying optics, physics educators, and anyone interested in the principles of diffraction and transmission gratings.
maxelcat
This is a question we have been doing at school. The answer is C. I think A is correct as well.
I have used nλ=dsinθ and put in test values.
I guess I should be able to do this by just 'inspecting the question' but the sin confused me. So I put in some test values as below.
When I used 600nm for wavelength and 100,000 lines per meter the first order and second orders are at 3.4398 degrees 6.8921degrees. Doubling N then gives 6.8921 and 13.8865 degrees. This suggests that a is right... so what am I doing wrong please
I think you are confusing the number of lines ##N## with the order of a given line. Suppose you were to write the grating equation as ##d \sin \theta = m \lambda## where ##m## is the order of the line (here ##m=2##). The separation between lines, ##d##, is halved when the number of lines ##N## is doubled.
Thanks for your reply. I don't think i am confusing N and n. When N is doubled, d is halves like you say. Small n (or m if you like) is the feinge number. So ...
For fixed N then theta for n=1 seems to be half what it for n=2... ie a is right... which it isn't according to the mark scheme
But... i have sorted it now ... a is wrong because the angle doesn't necessarily double as you go from n=1 to n=2 - at small angles it approximately does, at larger angles (like in the diagram) it doesn't
So which answer do you think is correct?
C -according to the mark scheme!
(c) is indeed the correct answer. Do you see why?
