Optimizing Truck Speed and Freight Load for Cost Efficiency on Interstate Travel
  • Context: MHB
  • Thread starter Thread starter Ph4cm
    Calculus
This discussion focuses on optimizing truck speed and freight load for cost efficiency during interstate travel between Adelaide and Sydney, covering a distance of 1375km. The truck operates at a base speed of 110km/h with a fuel efficiency of 7km/L, which decreases by 0.1km/L for each km/h increase in speed. The total cost model is defined as C(v,n) = 1375(44.5/v + 14.9/(180-v-0.5n)), where v is speed in km/h and n represents additional freight units. The minimum cost occurs at approximately 114 km/h with no additional freight.
  • Understanding of cost modeling in logistics
  • Knowledge of fuel efficiency metrics and their impact on operational costs
  • Familiarity with calculus for optimization (e.g., derivatives)
  • Basic understanding of freight transport dynamics
  • Explore advanced cost modeling techniques in logistics using tools like Excel or R
  • Learn about the impact of speed on fuel consumption and efficiency in trucking
  • Research optimization algorithms for minimizing transportation costs
  • Investigate real-world case studies on freight optimization strategies
Logistics managers, transportation analysts, and anyone involved in optimizing freight operations and cost efficiency in trucking.
Ph4cm
A truck traveling interstate, driving at a constant speed of 110km/h, gets 7km/L efficiency and loses 0.1km/L in fuel efficiency for each km/h increase in speed. Costs include diesel ($1.49/L), truck drivers’ wage ($35/hour), and truck maintenance and repairs ($9.50/hour). This truck is mainly used for carrying freight between Adelaide and Sydney (1375km). Explain what would happen if the truck were able to maintain a constant speed over 250km/h?
 Is it reasonable to assume a constant speed for such a trip?
 (Find 2 sources)
 What factors affect the reasonableness of the model the most?
 Suppose that, for every extra freight container the truck carries, the fuel efficiency drops by 0.05km/L. Suggest what will happen to the optimum traveling speed as the load of the truck’s freight increases.
 Find a mathematical relationship between freight size and speed for which cost is a minimum. Discuss your findings.
I've figured out the cost model C= 1375*(801-2.96x)(x(18-0.1x)) (x is speed, C is total cost)
ducduy said:
A truck traveling interstate, driving at a constant speed of 110km/h, gets 7km/L efficiency and loses 0.1km/L in fuel efficiency for each km/h increase in speed. Costs include diesel (\$1.49/L), truck drivers’ wage (\$35/hour), and truck maintenance and repairs (\$9.50/hour). This truck is mainly used for carrying freight between Adelaide and Sydney (1375km). Explain what would happen if the truck were able to maintain a constant speed over 250km/h?
 (Find 2 sources)
What are your units for speed, the $x$ in your cost function?
I get cost as a function of speed, $v$, in km/hr ...
$C(v) = 1375 \bigg[\dfrac{44.50}{v} + \dfrac{1.49}{7-0.1(v-110)} \bigg]$
unit analysis of my cost equation ...
$ \$ = km\bigg[\dfrac{\$ /hr}{km/hr} + \dfrac{\$/L}{km/L - \frac{km/L}{km/hr}(km/hr)}\bigg]$
Yes the x in the model represents in km/h.
Actually i really needed help in the last two questions. I've solved the first 3 questions. And don't mind the "find 2 sources" one it was my annotation. Would you mind to give me the direction to solve the last 2 questions ?
simplified the initial cost function ...
$C(v) = 1375\left(\dfrac{44.5}{v} + \dfrac{14.9}{180-v}\right)$
minimum cost occurs at $v \approx 114 \, km/hr$ with no additional freightcost as a function of speed and freight, where $n$ is the additional number of freight units
$C(v,n) = 1375 \left(\dfrac{44.5}{v} + \dfrac{29.8}{180-v-0.5n} \right)$
$\dfrac{\partial C}{\partial v} = 1375\left(-\dfrac{44.5}{v^2} + \dfrac{29.8}{(180-v-0.5n)^2}\right)$
$\dfrac{\partial C}{\partial v}=0 \implies v = \dfrac{180-0.5n}{1+A} \text{ where } A = \sqrt{\dfrac{149}{445}}$
attached is a calculated table of values for $v$ as a function of $n$ (in the table, $x$ represents $n$ and $Y_1$ is speed, $v$) ...
Could you explain more about how you've got the cost function C(v,n) ?
Cause I've got a different answer:
C= 1375∗(1.4918.05−0.1v−0.05n+44.5v)
I have a better idea ... explain how you derived your function.
So the new fuel efficiency function is y(v,n)= 7-0.1(v-110)-0.05(n-1) = 18.05-0.1x-0.05n
Total cost for fuel: (1375*1.49)/(18.05-0.1x-0.05n)
Total cost for wages and repairs: 44.5*1375/x
Total cost for the trip: C(v,n) = 1375∗(1.49/18.05−0.1v−0.05n + 44.5/v)
Could you check if mine is correct ?
what does n-1 represent?
in the equation I wrote in post #4, $n$ represents the number of additional freight loads
Sorry it was my mistake, it should only be n like in your equation at #4. But i can't understand how did you get the 29.8 in the equation at #4. Would you explain for me a little bit more please ? That will really helps me
that's my mistake ... should be 14.9. I doubled the numerator and denominator to get the coefficient of $n$ to be 1 instead of 0.5. When I decided against it, I forgot to change the numerator back after I typed it.
corrected ...
$C(v,n) = 1375 \left(\dfrac{44.5}{v} + \dfrac{{\color{red}14.9}}{180-v-0.5n} \right)$
$\dfrac{\partial C}{\partial v} = 1375\left(-\dfrac{44.5}{v^2} + \dfrac{{\color{red}14.9}}{(180-v-0.5n)^2}\right)$...this last equation was correct (see the 149 in the radical?)
corrected ...
Thank you a lot for this help Skeeter, It really helped me with my work. You are a wonderful person.
