Trapezoidal rule error bounds problem
  • Thread starter Thread starter mrwall-e
    Bounds Error
4 replies · 3K views
mrwall-e
a. Use the trapezoidal rule with [itex]n = 4[/itex] subintervals to estimate [itex]\int_0^2 x^2 dx[/itex].
b. Use the error bound to find the bound for the error.
c. Compute the integral exactly.
d. Verify the error is no more than the error bound.
Here, based on the problem, [itex]a = 0[/itex], [itex]b = 2[/itex], and [itex]N = 4[/itex].
[itex]T_N = \frac{1}{2} Δx(f(x_0) + 2f(x_1) + ... + 2f(x_{N - 1}) + f(x_N))[/itex] where [itex]Δx = \frac{b - a}{N}[/itex] and [itex]x_i = a + iΔx[/itex].
[itex]Error(T_N) \leq \frac{K_2(b - a)^3}{12N^2}[/itex] where [itex]f''(x) \leq K_2[/itex] for [itex]x \in [a, b][/itex].
[itex]Error(T_N) = |T_N - \int_a^b f(x) dx|[/itex].
a. I calculated [itex]Δx = \frac{2 - 0}{4} = \frac{1}{2}[/itex]. Therefore, [itex]T_N = \frac{1}{2}*\frac{1}{2}(0 + \frac{1}{2} + 1 + 2 \frac{1}{4} + 4) = 1.9375[/itex].
b. Since [itex]f''(x) = 2[/itex], I used [itex]K_2 = 2[/itex]. So therefore, [itex]Error(T_N) \leq \frac{2*(2)^3}{12(4)^2} = \frac{1}{12} = .0833[/itex].
c. [itex]\int_0^2 x^2 dx = 2.6667[/itex].
d. [itex]Error(T_N) = |1.9375 - 2.6667| = .7292[/itex], which is definitely outside the error bound.
What did I do wrong?
Thanks for any help, I really appreciate it.
You have five terms here, but by your definition of the trapezoid sum there can only be four terms in the sum, which indicates that you have incorrectly applied the definition. You used [itex]x = 0[/itex] as the first term but the first term in the sum is [itex]n = 1[/itex], not 0.
Sorry, the equation was wrong. It should be fixed now.
That is fine, but you've still computed the individual terms incorrectly. In particular, the third and fourth terms are incorrect.
That would do it.. such a stupid mistake, thanks!
