Triangle Inequality: use to prove convergence
9 replies · 3K views
binbagsss
Attached
I understand the first bound but not the second.
I am fine with the rest of the derivation that follows after these bounds,
I have this as the triangle inequality with a '+' sign enabling me to bound from above:
##|x+y| \leq |x|+|y| ## (1)
##|x-y| \geq |x|-|y| ## (2)
and this as the triangle inequality with a '-' sign enabling me to bound from below:
So for the first bound we have:
##|z-w| \geq |z| - |w| ##
since we have a strict less than inequality for |z| and a strict greater than equality for |w| , both of these are consistent and we indeed loose the equality option in the triangle inequality to get ##|z-w| > -R ##
I am stuck on the second bound however.
1) I ionly have a upper bound for a subtraction and not a lower via the triangle inequalities. can i get a upper bound from (1) and (2)?
i.e. are you allowewd to do ##|z+(-2w)| \leq |z|+|-2w| ##?
(even if I am, unlike the lower bound, where it turns out the bound we have on ##z## and ##w## are consistent with the triangle inequality, (enabling us to loose the equality and get strictness) there is contrast between the inequalities in this case. ( both items on the right hand side would need lower bounds (or one upper and one equality) but z has a upper bound).
Many thanks .
Yes that is a standard application of the triangle inequality.
Note that the lower bounds are to be expressed as multiples of ##|\omega|##. It is trivial to get such a lower bound for the second term on the RHS. The two inequalities given in the problem enable us to get a lower bound in terms of ##|\omega|## for the first term.
Ok thanks so from similar manipulations with (2) I see that ##|x+y| ## and ##|x-y|## have the same upper and lower bounds from the triangle inequality which makes sense when I think about what the mod function does and possible combinations etc.
That is fine.
I still don't understand this. Why is it trivial?
As I said in my OP there is contrast between the inequalities in this case. ( both items on the right hand side would need lower bounds (or one upper and one equality) but z has a upper bound.
We are looking for upper bounds, not lower bounds.
We want to find an upper bound for ##|z|+|-2w|## that is no greater than ##\frac52|w|##.
The second term is ##|-2w|## and we want to find an upper bound for it that is a multiple of ##|w|##. Given that an equality is also a upper bound, can you express ##|-2w|## as a multiple of ##|w|## and thereby have an upper bound for ##|-2w|##?
For the first term ##|z|##, the two inequalities you've been given are ##|z|<R## and ##|w|>2R##. How can you use those to get an upper bound for ##|z|## that is a multiple of ##|w|##?
No but the only information is ##|w|>2R##, ##|z|<R## , I can see clearly that the aim is to express in multiplies of ##w## and I'm pretty sure I said I UNDERSTAND the first inequality so unsure why everyone is replying to that, but anyway, given this all we know is ##|w|>2R## , it could be infinity, that's all we know? how do we bound that?
Put those two together to get an inequality relation between |z| and |w|. Then use that to get an upper bound on |z|+|-2w| (first converting the second term of that into a multiple of |w|).
I don't believe I'd have any issue with going from a bound between |z| and |w| to one of |z|+|-2w| . My issue in my previous still stands whether I am upper bounding - I assume this is what you meant by an inequality - |z|+|-2w| or |z|+|w| - as far as I can see z can be as large as it likes and so I can't see how we can upper bound anything involving an addition of z. Ta.
$$|z| < R < 2R < |\omega| \text{ ?}$$
Apologies typo, \omega can be as large as it wants
