Triangle Problem: Proving DC=AC
  • Context: Graduate
  • Thread starter Thread starter raul_l
    Triangle
The discussion centers on the Triangle Problem, specifically the assertion that the length of segment AC equals the length of segment DC. The user initially believes they have proven this equality using properties of similar triangles and the Pythagorean theorem. However, they are corrected by another participant who points out that the area calculations for triangle BDC are flawed, particularly regarding the definition of the altitude. Ultimately, the user acknowledges their mistake, confirming that the assumption DC=AC is incorrect.
  • Understanding of triangle similarity and properties
  • Knowledge of the Pythagorean theorem
  • Familiarity with geometric area calculations
  • Basic concepts of altitudes in triangles
  • Review the properties of similar triangles in geometry
  • Study the application of the Pythagorean theorem in various triangle configurations
  • Learn about the correct methods for calculating the area of triangles
  • Explore the significance of altitudes and their roles in triangle geometry
Mathematics students, geometry enthusiasts, and educators seeking to understand triangle properties and area calculations.
raul_l
Hi.
What's wrong here?
I'm pretty sure I did all the operations correctly so I must be making some kind of conceptual flaw.
(first see the attachment)
\triangle ABC \sim \triangle BDC
\frac{S_{ABC}}{S_{BDC}}=\frac{AB^2}{BD^2}
\frac{S_{ABC}}{S_{BDC}}=\frac{\frac{AC \times BE}{2}}{\frac{DC \times BE}{2}}=\frac{AC}{DC} \Rightarrow \frac{AC}{DC}=\frac{AB^2}{BD^2}
AB^2=BE^2+AE^2=BC^2-EC^2+(AC-EC)^2=BC^2-EC^2+AC^2-2AC \times EC+EC^2=
=BC^2+AC^2-2AC \times EC
BD^2=BE^2+ED^2=BC^2-EC^2+(EC-DC)^2=BC^2-EC^2+EC^2-2EC \times DC+CD^2=
=BC^2-2EC \times DC+DC^2
\frac{AC}{DC}=\frac{BC^2+AC^2-2AC \times EC}{BC^2-2EC \times DC+DC^2}
\frac{BC^2-2EC \times DC+DC^2}{DC}=\frac{BC^2+AC^2-2AC \times EC}{AC}
\frac{BC^2}{DC}-2EC+DC=\frac{BC^2}{AC}+AC-2EC
\frac{BC^2}{DC}-AC=\frac{BC^2}{AC}-DC
\frac{BC^2-AC \times DC}{DC}=\frac{BC^2-AC \times DC}{AC} \Rightarrow DC=AC
Mathematics news on Phys.org
The first thing you are doing wrong is not defining your terms! What is SABC? The area of triangle ABC? I am willing to assume that A, B, C are vertices of triangle ABC but what is E? The foot of the altitude on AC? If BE is the length of the altitude of triangle ABC on AC, what right do you have to assert that is also the length of the altitude of triangle BDC on BD?
Erm.. I figured all those things were obvious enough.
So yes, S[abc] is the area of ABC just as S[bdc] is the area of BDC.
E is the foot of the altitude on AC and therefore BE is its length. However, it doesn't say that BE is the length of the altitude on BD. BE is the length of the altitude on DC, because it forms a right angle with the extension of DC (right?). Therefore 1/2xDCxBE is the area of triangle BDC (which can be seen in the 3rd line).
I now it's not much fun to look through these equations but I would really appreciate it if someone could tell me where I have made a mistake. Because otherwise I would be proving that the length of a line segment is equal to the length of it subsegment (not sure whether that's the right word), in this case that the length of AC equals the length of DC.
What are you actually trying to do?
Good question :)
Sorry I didn't make that clear.
Actually, finding the mistake is the only objective here. A friend of mine showed this to me. He said that he had proven the "theorem" that the length of a line segment is equal to the length of its subsegment (by using a triangle), which was obviously a joke. However, he showed me how he had done that and asked me to find a mistake there. And so far I've got nothing.
If you look at the equations then they're all very simple operations, basically I've only used the Pythagorean theorem and a property of similar triangles. So to answer you question, the objective is to prove this "theorem" wrong.
I just found the answer to this problem.
In the last equation BC^2-AC \times DC=0 and therefore it would be incorrect to assume that DC=AC.
No, (1/2)(DC x BE) does not equal the area of triangle BDC. The height must be a line drawn to the vertex of a triangle.
EDIT: Nevermind. I just proved that I was wrong.
