Tricky maths question. Find base of equation given solutions.
  • Thread starter tigertan
    Base
10 replies · 3K views · last reply
tigertan
5x2-50x+125 (equation 1)
Solutions are x=5 and x=8
(x-5)(x-8)
= x2-13x+40 (equation 2)
What is the base of the number system??
Compare coefficients
1a=5b
-13a=-50b
40a=125b
The base must be greater than 8 since 8 is the highest solution..
Descriminant of (1) is zero. Only one solution
1a=5b
I don't understand what you're doing there. What are a and b?
How about taking the base to be a and writing out exactly what the equations mean in those terms, e.g. '125' becomes a2+2a+5.
Saying 1=5 in any bases is nonsensical. The form of your equation must be C*(x-5)*(x-8) in any base. Doesn't that tell you what C must be?
Yess whoops c=5
tigertan said:
Yess whoops c=5
Ok, so work it out in base 10 then equate it to the unknown base in (equation 1).
Still not sure how I'm meant to solve for the base?!
What's 5*(x-8)*(x-5) in base 10? The value of this expression doesn't depend on the base.
tigertan said:
okay shall give it a go!
Try and stay on the forums instead of using private messaging. If you tell me why it's base 13, I'll probably tell you it's correct.
looking only at the middle term, -50x of equation with unknown base, equating -5a=-65, we obtain a=13
That's correct. You can check it by showing you get the same result from the last term.
