Trigonometric Identities algebra
The discussion revolves around proving a trigonometric identity involving sine and cosine functions. The original poster expresses difficulty with the algebraic manipulation required to simplify the expression and reach the desired identity.
  • Participants discuss various algebraic techniques, including multiplying by the conjugate and simplifying expressions. Some suggest using known identities to aid in the simplification process.
There are multiple lines of reasoning being explored, with some participants providing hints and guidance without fully solving the problem. The conversation reflects a collaborative effort to clarify the algebraic steps involved.
Participants mention specific algebraic manipulations and identities relevant to the problem, indicating a focus on understanding the underlying concepts rather than merely arriving at a solution.
Mspike6
hello.
i have a question about trignometric identities.. it's realtivly easy, but am struggling with the algebra in it ( Algebra + trig = Very confusing to me )
Prove that ..
[Sinx/(1+Cosx)] + [(1+cosx) / sinx] = 2csc x
i manged to get it to [Sin2x+1+2cosx+cos2x] / SinxCosx
but i don't know what to do after that
any help would be appreciated, even if hints or steps without actually solving it for me .
Thank you
Mspike6 said:
hello.
Prove that ..
Thank you
There's an identity involving sin2x and cos2x that might help get you a bit farther...
For the first term sinx/(1 + cosx), multiply everything by the conjugate of the denominator. It should be a lot simpler than what you tried doing. :smile:
That should actually be \frac{sin^{2}x+1+2cosx+cos^{2}x}{sinx+sinxcosx}
Simplify and then factor.
Woohoo got it ! ..
Sin2x + cos2x will be 1
so ..
it will be [2 + 2cosx] / [sinx + sinxcosx]
Cosx cancels each other
==> 4/ 2sinx
==> 2/sinx
==> 2cscx
Thanks a lot for the help guys :D
I have anther question...
Find the general solutions for the following equations.
2 cos2 x -1 =0
Soultion.
Cos2x = 1/2
Cosx= - or + Sqrt 2 / 2
The general solution is pi /4 +2nPi, 3pi/4 +2nPi , 5Pi/4 + 2nPi and 7Pi/4 +2nPi , where n is an integer
But why can't i just take the Double angle of 2cos2x ?
which will be, cos2x=0
The general solution is Pi/2 +2nPi and 3Pi/2 +2nPi where n is an integer..
Btw, that was an example from my textbook...the first solution is what the textbook stated, and the second solution is what i thought right ..
Mspike6 said:
Woohoo got it ! ..
so ..
==> 4/ 2sinx
==> 2/sinx
==> 2cscx
Mspike, don't make that mistake. The cosx don't divide out. Since you have already pretty much attained your answer, this is what should have happened:
\frac{2+2cosx}{sinx+sinxcosx}
=\frac{2(1+cosx)}{sinx(1+cosx)} The (1+cosx) in the numerator and denominator divide out.
=\frac{2}{sinx}
=2cscx
=\frac{2}{sinx}
=2cscx
Ahh!.
thanks for the heads up, and i thought i knew it :S
2 cos2 x -1 =0
Soultion.
Cos2x = 1/2
In your solution, you did not even mention pi/4. The double angle is as follows:
2cos^{2}x-1=0
cos2x=0
2x=pi/2
x=pi/4
That is only one solution, and you are still missing it. Check where you went wrong.
Am sorry for asking so many questions ,
how one should factor , tan2-sec-1=0
i think it will be something like, (x-1)(x2+1)
where x and x2 are trig
try using an identity involving tan2x and sec2x to replace the tan2x term.
Solve Tan2x-secx-1=0
Soultion
(Sec2x-1)-secx-1=0
sec2-secx-2=0
(secx-2)(secx+1)=0
Secx -2 =0
secx=2
x= Pi/3 , 5Pi/3
Secx+1=0
Secx=-1
x= Pi
X= Pi/3 , 5Pi/3, Pi
Is that right? am i missing something ?
Thank you :D
Soultion
(Sec2x-1)-secx-1=0
sec2-secx-2=0
(secx-2)(secx+1)=0
Secx -2 =0
secx=2
x= Pi/3 , 5Pi/3
Secx+1=0
Secx=-1
x= Pi
X= Pi/3 , 5Pi/3, Pi
Thank you :D
looks fine to me
Soultion
(Sec2x-1)-secx-1=0
sec2-secx-2=0
(secx-2)(secx+1)=0
Secx -2 =0
secx=2
x= Pi/3 , 5Pi/3
Secx+1=0
Secx=-1
x= Pi
X= Pi/3 , 5Pi/3, Pi
Thank you :D
Yup, if the domain was [0,2pi], then it is correct.
  • · Replies 28 ·
35K
