Trigonometry questions I'm stuck on
  • Context:
  • Thread starter Thread starter nicodemus1
    Stuck Trigonometry
6 replies · 4K views
nicodemus1
Good Day,
I'm stuck on two trigonometry questions.
One requires me to prove a trigonometry summation and the other requires me to find the general solution of the given equation.
1. I am required to prove the b/m
sin x + sin 2x + sin 3x + ... + sin nx = {sin (n/2)x sin [(n+1)/2]x}/ sin (x/2)
I've attempted to prove this using mathematical induction. However, I'm stuck and need help/ advice on how I should proceed further. Attached is the work I have done so far.
2. I have to find the general solution of the following equation:
tan (2x - pi) = sin x
I've been able to get till tan 2x = sin x. However, whatever I've done after that doesn't give me the correct solution, which is
x = n*pi or 2n*pi + 1.946
Your help/ advice will be greatly appreciated.
Thanks in advance.
Mathematics news on Phys.org
nicodemus said:
Good Day,
Thanks in advance.
Hi nicodemus, :)
1) Use the double angle formula for \(\sin(k+1)\theta\). Then you will get,
\[\sin x + \sin 2x + \sin 3x + ... + \sin kx+\sin(k+1)x=\sin\left(\frac{k+1}{2}\right)\theta\left[\frac{\sin\frac{k\theta}{2}+2\sin\frac{\theta}{2}\cos\left(\frac{k+1}{2}\right)\theta}{\sin\frac{ \theta}{2}}\right]\]
Now use the angle sum identity for \(\cos\left(\frac{k+1}{2}\right)\theta\) and simplify(Using Double angle formulas of Sine and Cosine) to obtain,
\[\sin x + \sin 2x + \sin 3x + ... + \sin kx+\sin(k+1)x=\sin\left(\frac{k+1}{2}\right)\theta\left[\frac{\sin\frac{k\theta}{2}\cos\theta+\sin\theta \cos\frac{k\theta}{2}}{\sin\frac{ \theta}{2}}\right]\]
Using the angle sum identity again, \(\sin\left(\frac{k+2}{2}\right)\theta=\sin\frac{k\theta}{2}\cos\theta+\sin\theta\cos\frac{k\theta}{2}\) you can get the required answer.
2) \[\tan2x=\sin x\]
\[\Rightarrow \frac{2\sin x\cos x}{\cos 2x}=\sin x\]
\[\Rightarrow \sin x=0\mbox{ or }2\cos x-\cos 2x=0\]
\[\Rightarrow \sin x=0\mbox{ or }2\cos^{2}x-2\cos x-1=0\]
Hope you can continue. :)
Kind Regards,
Sudharaka.
Good Day,
Thank you so much for your help.
However, I don't understand how you got this part:
[FONT=MathJax_Main]⇒[FONT=MathJax_Main]sin[FONT=MathJax_Math]x[FONT=MathJax_Main]=[FONT=MathJax_Main]0[FONT=MathJax_Main] or [FONT=MathJax_Main]2[FONT=MathJax_Main]cos[FONT=MathJax_Math]x[FONT=MathJax_Main]−[FONT=MathJax_Main]cos[FONT=MathJax_Main]2[FONT=MathJax_Math]x[FONT=MathJax_Main]=[FONT=MathJax_Main]0​
Could you please give a more detailed explanation?
nicodemus said:
Good Day,
You are welcome. :)
\[\frac{2\sin x\cos x}{\cos 2x}=\sin x\]
\[\Rightarrow \sin x\left(\frac{2\cos x}{\cos 2x}-1\right)=0\]
\[\Rightarrow \sin x\left(\frac{2\cos x-\cos 2x}{\cos 2x}\right)=0\]
Since, \(\frac{1}{\cos 2x}\neq 0\) we have,
\[\sin x(2\cos x-\cos 2x)=0\]
\[\therefore \sin x=0\mbox{ or }2\cos x-\cos 2x=0\]
Is it clear to you now? :)
Brilliant! It's crystal clear to me now.
Thanks very much!
Good Day,
I'm sorry about this but I'm still having trouble finding the general solution for this part
[FONT=MathJax_Main]2[FONT=MathJax_Main]cos[FONT=MathJax_Main]2[FONT=MathJax_Math]x[FONT=MathJax_Main]−[FONT=MathJax_Main]2[FONT=MathJax_Main]cos[FONT=MathJax_Math]x[FONT=MathJax_Main]−[FONT=MathJax_Main]1[FONT=MathJax_Main]=[FONT=MathJax_Main]0
I applied the Quadratic Formula and got cos x = (1 + 3) / 2 but I don't think it's anywhere near this: 2n*pi + 1.946.
What am I doing wrong?
nicodemus said:
Good Day,
Hi nicodemus, :)
The answer you have obtained for \(\cos x\) is correct. However you should solve for \(x\). First see whether both of these answers are possible for a cosine value. Note that \(cos x\leq 1\).
Kind Regards,
Sudharaka.
