Trouble Identifying this Organic Unknown
  • Thread starter Thread starter stuartischees
    Organic
5 replies · 4K views
stuartischees
Alright, I've got a bunch of physical data and an IR Spectrum, but somehow it doesn't seem to match up with any compound I find through google. Even worse, I have a list of compounds it should be and there's still no obvious winner. Any help is dearly appreciated.
Clear, yellowish liquid. Fruity smell.
BP ~ 165.5C
Refractive index ~ 1.55 @ 20C
IR Specrtum:
Obvious OH shoulder, looks like a carboxylic acid
C=O band at 1703
Presumed C-O bond at 1204
Small band at 3064
Moderate bands at 2820 and 2850
Possible Unknowns:
Cyclohexanone
Bromobenzene
1-Bromobutane
2-Chloroethanol
Phenylacetylene
1-Octanol
Ethyl Benzoate
Propionic Acid
Benzaldehyde
1-Octene
Again, all help is appreciated!
Chemistry news on Phys.org
Smell suggests ester, are you sure about BP?
Well based on your IR readings you should be able to eliminate at least half the compounds on your list. I wouldn't go just on smell, but like Borek said, a sweet/fruity smell suggests an ester.
Are you sure this is a single compound, and isn't contaminated by anything else that would appear in the IR spectrum? (i.e. ester contaminated with alcohol or acid left over from synthesis)
This is a good point; I hadn't thought of this. Depending on the equipment you have available, you might want to cool it down enough to get a melting point, which can give you a general idea of the purity.
Handbook of Chemistry and Physics. You should be able to eliminate a ton of those from BP alone.
