Trouble understanding Continuity
  • Thread starter Thread starter crispy_nine
    Continuity
crispy_nine
Hey folks,
I have this one problem that seems unclear to me:
Show that the function f is continuous at (0,0) for
f(x,y) = ysin(1/x) if (x,y) do not equal (0,0)...and 0 if (x,y) = (0,0)
I'm thinking though, as with single variable calc, f is continuous at (a,b) provided that f(a,b) exists right? Therefore the top function is not continuous at (0,0), correct? But then again it states that x and y never do equal (0,0). I think I don't understand the question. Could somebody rephrase it or give me a hint? Cheers
I think it would be good for you to start with the equivalent 1 dimensional problem, which is:
Let f(x) = x sin(1/x) for all x not equal to zero, and define f(0) = 0. Show that f is continuous everywhere.
crispy_nine said:
Hey folks,
No, even in single variables that is not right. f is continuous at (a,b) provided that (1) f(a,b) exists, (2) lim_{(x,y)\rightarrow (a,b)} exists, and (3)lim_{(x,y)\rightarrow (a,b)}= f(a,b).
Even from your mistaken statement that does not follow. f(0,0) certainly does exist. You are told that "f(x,y)= 0 if (x,y)= (0,0)". In other words that f(0,0)= 0.
Your reference to "the top function" implies that you think there are two functions here. That is incorrect. There is only one function.
No, it does NOT say "x and y never do equal (0,0)". It says that if x and y are not (0,0) then f(x,y) has a certain formula.
Suppose a function f(x) were defined by "f(x)= 2x- 3 if x is not 1, 2 if x is 1", what is f(1.001)? What is f(1)? Is that function continuous at x= 1?
Thanks for the helpful insight so far.
It is now clear to me that f(0,0) exists and is zero, so basically all I have to do to show that the function is continuous is prove that the limit of ysin(1/x) exists and is zero as (x,y) goes to (0,0).
Now, how is that possible if the limit of (1/x) does not exist as x goes to zero? Is l'Hopitals rule somehow applicable in this situation?
No one has said that lim(1/x) exists as x goes to 0!
What is being said is that (in your problem lim ysin(1/x) exists as x and y both go to 0 (independently) and (Crosson's one dimension example) x sin(1/x) exists as x goes to 0. What happens of x sin(1/x) for x very small? How large is "x"? How large is sin(1/x)? How large is their product?
Use the epsilon-delta definition of limit and the fact that |sin(z)| <= 1 for all z. It will be clear that delta=epsilon does the trick.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
